Welcome to the North American Subaru Impreza Owners Club Wednesday May 5, 2021
Old 05-22-2020, 06:42 PM   #1
What could go wrong
Member#: 448908
Default Bell housing inspection hole cover?
I have an 09 WRX 5mt that just had some major surgery done. When I went to clean the engine bay (long story) I noticed I could actually see my flywheel exposed behind the intake.
I am assuming there is a cover that is supposed to be there, but was not reinstalled by the shop that did the work.
I would like to get a new one as Iím a clumsy **** and I am absolutely certain if I leave it exposed I am going to drop something in the bell housing at some point.
I looked around a few places and couldnít find a PN that seemed to match the slot, any help tracking it down would be great. Also while Iím at it, are there any other covers on the bell-housing I should check? Thanks!
What could go wrong is offline   Reply With Quote
Old 05-22-2020, 07:09 PM   #2
Haevn
Member#: 495950
Haevn is offline   Reply With Quote
Old 05-22-2020, 08:45 PM   #3
What could go wrong
Member#: 448908
Originally Posted by Haevn View Post
I donít know to be honest, may just order it to find out... it doesnít go on the front of the motor though, itís behind the intake. I came across this part already a few times but the term ďtimingĒ made me think it was for a portion of the timing cover... either way, thanks for your help!
Old 05-22-2020, 09:32 PM   #4
viper_crazy
Member#: 298403
2008 WRX Premium
Spark Silver
I'm not sure why it's called timing cover, but tow-may-tow toe-mah-toe, I guess??
If the cover you're looking for resides on the top side bell housing part of the engine on the passenger side of the block, that's the part you're after.
There are a few companies that make a metal bolt on version as factory ones tend to come loose and either fall off or fall in. The shop may not be to blame.
https://www.verus-engineering.com/sh...56?category=55
viper_crazy is offline   Reply With Quote
Old 05-26-2020, 01:07 PM   #5
What could go wrong
Member#: 448908
Awesome thanks!
Old 05-26-2020, 04:50 PM   #6
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
Interesting, didn't know there was a market for aftermarket replacement timing covers.
These are called "timing covers" because back in the 70's and 80's you would time your Subaru's engine based on the timing marks machined into the backside of the flywheel. Pull off the "timing cover," start the engine and twist the distributor to time the engine while you point your timing light into that hole.
Fast forward to about 1:15 to see the timing hole being used.
car_freak85 is offline   Reply With Quote
Old 06-04-2020, 01:50 AM   #7
CGM/WRX
Member#: 87133
1998 2.5RS V7 EJ207
Brilliant Red
Its also how you access the torque converter bolts on the cvt and auto trans vehicles.
CGM/WRX is offline   Reply With Quote
Old 06-27-2020, 10:44 PM   #8
What could go wrong
Member#: 448908
EA82 Distributor and Ignition Timing - YouTube
That is super interesting, thanks!
Old 06-29-2020, 09:49 AM   #9
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Thanks for the info. Love learning new things.
"Knowledge is power"
BlackFighter is offline   Reply With Quote
