09-24-2016, 06:30 PM | #51 |
Member#: 130990
NWIC
Vehicle:06 Red Ltd.Wagon Dom 1.5xtr JJ tuned |
If you are talking about the very sudden drop at the very end, that is the rev limiter setting. Not to say it would maintain the hp for much longer anyway.
09-24-2016, 06:52 PM | #52 |
Member#: 343855
Vehicle:2005 Legacy GT Stg 3 |
Nothing wrong with flat! I'd prefer that to a sudden drop.
Guess its best to jump in and see how things go lol! |
09-25-2016, 08:24 PM | #53 |
Member#: 328635
NWIC
Vehicle:2004 STi GTX3076R Rally Blue |
Engine wise yours should be fine for your goals from what I gather from the bottom end. Only thing i didn't notice is if your doing oversize valves or porting? Both are very helpful for rpm baised power imo.
Like others have said the turbo likely wont hold uptop and the tune is key. My setup peaks at 7500-7900 depending on fuel choice and is similar to the motor you have described you plan to build in the thread with 1mm over valves and slightly lower cr at 8:1. Main thing I attribute my car holding power uptop to is the balanced engine setup and the gtx3076 im running. |
09-25-2016, 10:26 PM | #54 |
Member#: 343855
What fueling? Are we talking octane or e85? I'm curious as to what 93 octane gets you! That's what every station around here has, 87-89-93.
09-26-2016, 08:19 AM | #55 |
Member#: 56203
Vehicle:00 RSTI Coupe Twin Scroll 2.5XTR EJ207 |
Your going have an even harder time accomplishing your goals on 93....id go e85 if it's not too far from you or look into alky injection kits
09-26-2016, 10:17 AM | #56 |
Member#: 328635
NWIC
My 92 tune made peak power at 7500rpm and the 101 kept climbing until 7900rpm. I had a softer tune on 92 that gained more until 8k but that was 20whp ish less at peak than the current tune and 15-25whp across the board.
I stepped up injectors to ID1300's (ID1000's hit 100% at 8k) and changed a few things over last winter/this summer so I will toss it on a dyno and re-tune it again soon. |
09-26-2016, 04:21 PM | #57 |
Member#: 343855
Any dyno graphs ?
09-26-2016, 05:18 PM | #58 |
Member#: 328635
NWIC
Old ones in my build thread, the current ones I don't other than a VD I think. But I will send you the new ones when I hit the dyno again in a few weeks or so if you want.
Here is the VD I took last summer before I made the changes I mentioned in order to fix my lack of fuel up top: 92(blue) vs. 101(red) by Bret Stevens, on Flickr Car runs 11.6@118 with '04 STi gears (so it needs 5th above 112-114) and does 50-100 in 4.4 sec |
09-26-2016, 05:45 PM | #59 |
Member#: 1130
Vehicle:2013 STI Hatch DGM |
I find it interesting no one is talking about the appropriate sized a/r hotside on these turbos.
On my 3576, with its .85 hotside, it ran 615 whp and ran out of steam at 7kish. The motor is built around spinning over 8k. Pw intake manifold, large ports, large valves, big lift cam... But the back end of the turbo couldn't keep up. The 4088 has a .99 hotside. That should help. When I get done with its purpose, I will through a 3076 with a larger hotside, close to or over a 1.0 to get it to build/hold power up in the rpms. |
09-26-2016, 06:55 PM | #60 | |
Member#: 328635
NWIC
09-26-2016, 07:09 PM | #61 |
Member#: 1130
ahhhh. copy that. I figure that a hotside would be as equal as important as a hot cam. You can run a 272 with tons of lift and good springs, but the turbine just wont spin any more.
A proper hot side might just help force the way through them pesky valves. Anyone bring up proper oiling ability in a stock crankshaft vs the manley etc with the better oil holes? |
09-26-2016, 07:56 PM | #62 |
Member#: 38928
Vehicle:2004 153 MPH STI Silver |
Oiling: Interesting point. I did nothing to my new OEM crank and OEM bearings (including the rod bearings).
I preferred tight for engine longevity, but wondered. .0018 on the rods and .001-.0012 on the mains. I didn't feel I'm in a region that modifying the oiling system was required...although I don't know when that would be. |
09-26-2016, 08:01 PM | #63 |
Member#: 343855
I love that curve!
09-26-2016, 08:02 PM | #64 |
Member#: 343855
Turbos and injectors are bolt on's, so i'm not really worried. Most important thing is the longblock. Everything else is a saturday afternoon. I'm going stock tolerances for everything.
09-26-2016, 08:07 PM | #65 |
Member#: 343855
And that curve is on 1000cc injectors? Thats impressive. Can't wait to see it with 1300cc.
09-26-2016, 08:28 PM | #66 | |
Member#: 1130
I can't remember now. I'm certain it's been covered here somewhere. Something about the oilnot being able to move after a certain rotational moment. |
09-27-2016, 10:27 AM | #67 | ||
Member#: 328635
NWIC
I run a stock crank and oem oil pump, nothing special other than a gauge to keep an eye on everything and the dreaded mobil 1 5w-30 everyone on here claims is "basically water" LOL. No issues and been running it hard for 20k+ miles seeing 8k rpm everyday, hell most of my shifting is done up there. LOL |
09-27-2016, 05:13 PM | #68 |
Member#: 56203
09-27-2016, 05:59 PM | #69 |
Member#: 343855
just noticed!
09-27-2016, 07:02 PM | #70 | |
Member#: 328635
NWIC
Regardless VD is not the best example, as ill pass along the rolling dyno info once I get around to firing it back up and getting my re-tune. |
10-21-2016, 04:22 PM | #71 |
Member#: 328635
NWIC
Here are a few graphs from just two days ago on PSI's dyno (dynojet).
Pump 92@21psi: Pump_gas by Bret Stevens, on Flickr 101@24: (fixed the boost spike on another pull but saved the wrong one) 110_octane by Bret Stevens, on Flickr 116@26psi (in 3rd gear not 4th like the others clutch slipped once it ramped up boost): 116 octane by Bret Stevens, on Flickr These should help more than my VD stuff. |
10-21-2016, 10:13 PM | #72 |
Member#: 343855
For the 92 octane what was your idc? And this is 1300cc injectors?
10-22-2016, 11:15 AM | #73 |
Member#: 328635
NWIC
I can look into it once i switch back to pump gas, still need to enjoy the last of the 116 lol. Correct 1300's but the 1000's didn't limit anything before i swapped over i just didn't like being at the upper limits of anything. I really aimed for balance on my build and safe tuning limits.
10-24-2016, 10:09 PM | #74 | |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
I'm sure power will taper, but shifting gears drops wheel torque by quite a bit, so I'm not at all convinced that shifting at 7200 is accelerating me faster than staying in gear a while longer would. And even if it isn't faster for drag racing I'm sure it'll be more fun at track days to be able to stay in gear longer here and there. 4k-7k is a pretty small powerband, I don't know how people put up with bigger turbos. |
10-25-2016, 01:09 PM | #75 | |
Member#: 130990
NWIC
