Welcome to the North American Subaru Impreza Owners Club Sunday June 16, 2019
Old 05-22-2019, 10:06 PM   #1
CaliKid87
Member#: 501937
Unhappy 05 STi throwing CEL for Cat Deficiency
Hello all, new user here!
This is my situation...
I have owned my 05 wrx sti since I purchased it brand new. I slightly modded it with a Helix Cat'ed Downpipe and a Helix Turbo Back Exhaust from Gruppe-S back in 2008-2009? And it came with a Cel Light fix for the o2 sensor I believe (I didnt install it) but reguardless. It seemed to work and I never through a Cel light or anything for years UNTIL now! I had the car maintenanced several times and after the last one BOOM CEL light was thrown, and after reading the code it came up "CAT DEFICIENCY". Can I fix this by purchasing a "BETTER" 02 spacer etc? Like a 90 degree one? And another noob question, how many spacers or 02 sensors do I need to space away from the bung? Is there more than 1 o2 sensor I need to space? And finally, are all 02 sensor spacers I am seeing online capable of fitting? Are they all interchangeable in terms of their threading etc? I cant afford to FLASH the ECU or pro tune is at this point and YEARS ago I made the mistake of selling the OEM exhaust. I tried clearing the CEL and resetting the ECU several times and it will run fine with no code for 1-2 days but inevitably the CEL light returns and it throws the code now for some reason. The vehicle only has 60,000 miles on it and I have only put maybe 30,000 miles on the exhaust so no way is it a bad catalytic converter or sensor. PLEASE HELP! I passed smog with this exact setup 2 years ago when NO CEL light was on and with this exhaust, but I need to pass it for registration in 14 days. I cannot smog it for registration with the Check Engine light on.
Thanks for ANY and ALL help fellas! This forum is a MECCA of advice and excellent help!
CaliKid87 is offline   Reply With Quote
Old 05-23-2019, 10:25 PM   #2
awfulwaffle
Member#: 409332
2013 WRX
PBP
Whoever tuned your car for that downpipe can disable that code for you, assuming you got it tuned.
awfulwaffle is online now   Reply With Quote
Old 05-24-2019, 12:03 AM   #3
CaliKid87
Member#: 501937
No I never did a tune bc I was short on money and I still cannot afford one at the moment either. I explained it in my long ramblings above...
Old 05-24-2019, 12:44 PM   #4
awfulwaffle
Member#: 409332
2013 WRX
PBP
No answer for you on spacers since I've always just disabled my O2 codes. Maybe you can try finding someone local set up to tune open source (Tactrix or VAG-COM cable) who can pull the ROM from the ECU, disable the code, and then flash it back. May not happen within your timeframe, though. If you want to drive to Detroit I'll do it for you
