Tire & Wheel Forum sponsored by The Tire Rack |
04-28-2004, 01:21 AM | #1 |
Member#: 11102
Vehicle:02 WRX,05STi Sold 01 Boosted IS300 |
Any issues with wheel spacers?
Just curious why everyone is so afraid to run spacers with a BBK or Brembo setup's. Are there any problems you will run into w/ a spacer?
The reason I ask is because I had to use a 1/8th spacer to clear my Stoptech's w/ 18x7.5 Volk GTP's. I thought they would clear as I had read that most 18's do but these definetly hit....I ended scratching my calipers putting the first wheel back on. So, any problems with using a spacer??
04-28-2004, 04:54 AM | #2 |
Member#: 17397
BAIC
Vehicle:many '02 Rex,'13 FRS WRB, White |
V rex,
I personally don't run spacers, i would rather run wheels that are made to fit my car... or my particular setup. if you do get spacers, it would be nice to get hubcentric ones. good luck! SD |
04-28-2004, 11:36 PM | #3 |
Member#: 11102
How do I know if they are hubcentric?
I just don't understand what the big deal is. People always pass up on certain wheels because they will not clear their brakes...why don't they use a spacer? Are their any drawbacks besides them not fitting w/out them?? thanks |
04-29-2004, 04:29 AM | #4 |
Member#: 48936
SCIC
Vehicle:I Do Installs On The Side;) PM me for details! |
If your that unsure, You can probably get longer wheel studs to make up for the spacer.
05-18-2004, 08:18 PM | #5 |
Member#: 7194
Vehicle:2011 997.2 Turbo Black |
yup. Spacers are fine. If your going 3/4 inch or more then you just upgrade your studs. Sport/truckers have been using spacers for years and years to trick out their trucks. Lowered trucks are much heavier and harder on wheels/studs/ then your subaru and they do it w/o problems.
go for it. |
05-18-2004, 11:24 PM | #6 |
Member#: 11102
Yeah, i've been using the 1/8th spacers for a few weeks now with no problems. Loving the stoptech's.
05-26-2004, 09:42 AM | #7 |
Member#: 35695
NESIC
Vehicle:02 RST 98 Outback 92 Wrangler |
anyone have pics of the wheel spacers on their cars?
05-26-2004, 12:01 PM | #8 |
Member#: 2127
RMIC
Vehicle:09 STi dgm Cobb Stage 2 |
I got some 5mm spacers and ended up returning them. Most are not hubcentric so you get the the spacer balanced on the hub. You will get some vibration at high speeds if they are not perfectly centered. I would rather take the time to find wheels that fit!
05-27-2004, 06:12 AM | #9 |
Member#: 3055
Vehicle:my04 sti blue and gold |
also - using a spacer changes the effective offset. some have noted wheel bearing problems when the offset is incorrect.
mark |
05-27-2004, 11:07 AM | #10 |
Member#: 35695
NESIC
true that!
Any problems with 5mm spacers? | jaytheman | Brakes, Steering & Suspension | 1 | 01-29-2010 07:33 AM |
Any issues with phenolic spacers? | GlobalWaste | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 13 | 06-17-2008 09:23 PM |
is this a good deal? any issues with wheels or tires? | Mike Wevrick | Tire & Wheel | 6 | 11-08-2006 01:30 PM |
Any one have any issues with a TurboXS TBE in PA? | Soulofdarkness | Mid Atlantic Impreza Club -- MAIC | 18 | 05-02-2006 04:59 PM |
Any issues with stock turbo/injectors with Walbro pump? | wagon-wrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 01-27-2004 03:07 PM |
