10-09-2010, 05:17 PM | #1 |
Member#: 163662
TXIC
Vehicle:2005 815 AWHP GD STi Mineral White Metallic |
Not enough fuel
Okay, built motor and everything is set up correctly. Only problem left is that my car isn't getting enough fuel to start. We check the plugs after attempting to start and there is barely any fuel on the plugs... One thing that came to mind is that the evac line near the feed & return hard fuel lines near the firewall is capped off. Does that vacuum line need to be ran or can it be capped?
Any help is appreciated
10-09-2010, 05:40 PM | #2 |
Member#: 5810
Vehicle:2001 S366 2.5RS |
Sure you have the fuel lines back on the rails correctly?
10-09-2010, 06:19 PM | #3 |
Member#: 163662
TXIC
I'm pretty sure, it's the agency power kit. We have the top lines from the block going to the front side of each rail and the bottom lines to the top middle of the rails.
Does the evac vacuum line NEED to be hooked up? |
10-09-2010, 07:47 PM | #4 |
Member#: 234397
Vehicle:2004 WRX STI WRB 15 DGM FXT |
i read this on two threads awhile back that it needs to be hooked up for the regulator but i don.t know where i read it, search regulator-relocation or aftermarket installation-why not try it?
10-09-2010, 10:13 PM | #5 |
Member#: 112759
Vehicle:2015 Stock OEM AsFu* 3.6r OMG S.C'd |
I would say the lines are reversed
10-09-2010, 10:36 PM | #6 |
Member#: 77470
Vehicle:04 sti 10.41@141 on e85@ 30psi--spinning |
the vapor return line by the m/cyl does not need to be hooked up, like above you have the lines at the firewall hooked up backwards I'll bet.
10-09-2010, 10:58 PM | #7 |
Member#: 163662
TXIC
You mean tge fuel send and return lines?
10-10-2010, 01:14 PM | #8 |
Member#: 153880
RMIC
Vehicle:03 Evo VIII 2011 STI |
The evap stuff doesn't matter but your FPR needs a vacuum source if thats what your asking about.
Similar Threads | ||||
Slight boost creep, not enough to hit fuel cut, should I be concerned? | Rizen | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 8 | 11-28-2007 11:22 AM |
Weird fueling issue. Not enough fuel, add a pump now insanely rich???A/F weirdness. | Defiant Autospeed | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 21 | 11-19-2007 04:30 AM |
Not Enough Fuel / Timing Question | bluesube2000 | Engine Management & Tuning | 1 | 11-21-2005 09:51 PM |
Enough fuel for 20psi? | rupert | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 06-20-2003 03:58 PM |
Enough fuel for 19.6psi on VF35? | rupert | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 06-17-2003 12:15 PM |
