05-02-2012, 10:42 PM | #5851 |
Member#: 159243
Vehicle:5/01 bugeye Hakt Ecu is back! |
Very interesting how many different opinions I read on p0000. Thanks for the insight.
05-02-2012, 11:05 PM | #5852 | |||
Member#: 64908
Vehicle:10.8 XT+9.2@155 GR+ 9.1/157mph 2015 STI |
98 RON Octane x 0.95 = 93.1 AKI Octane (US measure) 100 RON Octane x 0.95 = 95 AKI Octane (US measure) 98ron is 93 octane. His timing/boost shouldn't be close to what they would be on e85. Quote:
I have played with this in the past. It works well, but you need to be careful when mixing batches. I would give the guys in the UK a call about that, they like to do it Quote:
05-02-2012, 11:32 PM | #5853 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
You could contact clark turner too.....i believe he tuned a Texas Mile car that was running straight methanol on a gt40 i believe.
but like Jr said you need lots of injector....i believe the stoich AFR for methanol is 4:1.....so basically if you mess up once you're gonna hydrolock the motor. iirc the car that clark tuned burned somewhere in the 3-5 gallons in the mile. |
05-03-2012, 12:19 AM | #5854 |
Member#: 64908
To switch to straight Meth you will need A LOT of support stuff. I was kidding.. lol
I have tuned a few straight meth cars and the fuel systems are ridiculous.. Mechanical pump is a must to get it right, multi stage injection works best as well. Tuning it properly and making it all work is a bitch too. You do make some SERIOUS hp on it though. Serious like 275-300whp per cylinder on a 2jz |
05-03-2012, 06:10 PM | #5855 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
What are the symptoms of a blown turbo?
Well the other day I was doing some runs, I run 50-100mph in 4.8 seconds. I wasn't happy about it and told xluben that there has to be something wrong. I don't know how much I was making that day. So I drove the car again today and decided to see how much I was making. It only make 360whp and the boost was dropping like crazy upstairs from 26psi to 17psi. I though I had a vacuum leak or something. After work I started the car and a it was smoking a lot. I went for a short drive and when I got home I opened the hood. I found some oil over the intake manifold and on the inside of the hood. The engine sounds perfect, the turbo is not making any weird noises, the learning view is clean. Any ideas? I can't figure out where the oil is coming from, I am going to take of the intercooler and the turbo this weekend. |
05-03-2012, 07:07 PM | #5856 |
Member#: 248202
Vehicle:2013 WRX Sedan SWP |
Was it smoking from under the hood or out of the exhaust? I'm not an expert but is it possible your inlet has a rip somewhere?
05-03-2012, 08:43 PM | #5857 |
Member#: 193014
Vehicle:02 WRX WRB, 05 STI FPGreen E85 400+whp |
Clean all the oil off run it take a short drive then look to see where the oil is coming from
05-03-2012, 08:50 PM | #5858 | |
Member#: 133146
I did and I went for a short drive. It seems that when I hit boost the oil is squirting out from somewhere. The engine sounds super smooth irs so weird, I will figure it out. |
05-03-2012, 09:22 PM | #5859 |
Member#: 248202
Oil line turd out ?
05-03-2012, 09:34 PM | #5860 |
Member#: 36033
SCIC
why are you doing 100mph pulls with maxed out injectors?
you can try cleaning the motor off and zip tying rags or papertowels in spots to see if it catches the oil. you may be able to pull a CSI on the spray pattern and figure out where its coming from. might be squirting out of the pcv lines. turbos dont usually leak into the engine bay....mostly into the turbine/downpipe and burn out the exhaust. |
05-03-2012, 09:49 PM | #5861 |
Member#: 218151
Vehicle:2005 STi World Rally Blue |
just thought I would share this hope I put all the information that I am supposed to.
2005 STi 1) Your injectors size-ID1000 2) Injector duty cycle (if you have it)- N/A 3) Elevation-810ft 4) Turbo-VF39 stock motor, 08tgv deletes, perrin turbo inlet, warlbro 255, ID1000, Injen cai, cobb turbo back, AP, grimmspeed ewg 38mm, think that might be it. Not sure what % E85 I'm running, at the pump it states no less than 70%. 22psi 354hp 420wtq |
05-03-2012, 10:14 PM | #5862 | |
Member#: 17256
South East
Vehicle:18 Outback on the road.... |
05-03-2012, 10:16 PM | #5863 | |
Member#: 133146
Will that explain the drop of boost? here is the boost plot of two pulls that show the boost lost. And the here is the log of my 50-100mph run. It did it in 4.8sec with low boost and rich Code:
Time (msec) Coolant Temperature (F) Engine Load (Calculated) (g/rev) Engine Speed (rpm) Feedback Knock Correction (4-byte)* (degrees) Fine Learning Knock Correction (degrees) IAM (multiplier) Ignition Total Timing (degrees) Injector Duty Cycle (%) Intake Air Temperature (F) Manifold Relative Pressure (4-byte)* (psi relative) Manifold Relative Pressure (Corrected) (psi) Mass Airflow (g/s) Mass Airflow Sensor Voltage (V) Throttle Opening Angle (%) Vehicle Speed (mph) Innovate Wideband AFR (AFR Gasoline) 1402 190 1.19 3851 0 0 1 33 18.58 93 0 -0.15 71.4 2.84 100 37 14.2 1470 190 1.28 3824 0 0 1 25.5 21.21 93 0.35 0.29 79.96 2.88 100 37 14.86 1550 190 1.28 3890 0 0 1 25 21.58 93 0.77 0.58 78.72 2.9 100 37 13.96 1628 190 1.3 3956 0 0 1 25 23.63 93 1.18 1.02 87.13 2.96 100 37 13.08 1692 190 1.42 3960 0 0 1 24.5 24.5 93 1.74 1.6 90.58 2.94 100 37 12.52 1773 190 1.43 4069 0 0 1 24 24.78 93 2.27 2.18 92.43 3.06 100 37 12 1852 190 1.54 4063 0 0 1 24 26.87 93 2.97 2.76 101.93 3.18 100 37 11.77 1932 190 1.53 4118 0 0 1 24 27.23 93 3.64 3.48 99.69 3.1 100 37 11.79 2012 190 1.74 4248 0 0 1 23.5 31.24 93 4.44 4.21 120.09 3.28 100 37 11.72 2093 190 1.76 4243 0 0 1 23 33.49 93 5.42 5.22 124.71 3.34 100 37 11.66 2157 190 1.83 4373 0 0 1 22 34.93 93 6.43 6.09 126.25 3.36 100 37 11.66 2235 190 1.99 4408 0 0 1 21.5 39.12 93 7.55 7.25 143.62 3.48 100 39 11.33 2315 190 2.08 4494 0 0 1 21 40.63 93 8.97 8.56 148.65 3.52 100 39 11.29 2396 190 2.14 4630 0 0 1 20.5 45.78 93 10.49 10.01 167.42 3.62 100 39 11.29 2474 190 2.42 4695 0 0 1 20 49.4 93 12.23 11.61 181.01 3.68 100 39 11.3 2539 190 2.49 4814 0 0 1 19 53.71 93 14.1 13.49 193.02 3.8 100 39 11.32 2619 190 2.94 4893 0 0 1 18.5 64.5 93 16.21 15.38 227.05 3.96 100 39 11.13 2699 190 3.12 5017 0 0 1 17 70.64 93 18.29 17.7 240.28 4 100 42 11.22 2781 190 3.25 5132 0 0 1 16 78.92 93 20.46 19.73 278.47 4.16 100 42 11.08 2858 190 3.43 5268 0 0 1 16 85.48 93 22.03 21.62 297.97 4.16 100 42 11.02 2938 190 3.29 5408 0 0 1 16 86.53 93 22.81 22.64 295.65 4.24 100 42 11.04 3003 190 3.5 5540 0 0 1 16.5 94.56 93 23.21 22.78 329.14 4.32 100 42 11.08 3081 190 3.59 5679 0 0 1 17 89.84 93 23.3 22.78 315.03 4.26 100 42 11.29 3162 190 3.32 5740 0 0 1 17.5 95.52 93 23.55 22.78 336.23 4.32 100 48 11.39 3243 190 3.51 5922 0 0 1 18.5 97.28 93 23.22 22.78 337.02 4.34 100 48 11.52 3323 190 3.26 5982 0 0 1 19 93.16 93 23.13 22.78 331.47 4.34 100 48 11.5 3386 190 3.34 6092 0 0 1 19.5 97.47 93 22.81 22.78 347.35 4.36 100 48 11.5 3466 190 3.36 6225 0 0 1 20 94.63 93 22.69 22.78 333.05 4.32 100 48 11.61 3546 190 3.17 6338 0 0 1 21 93.7 93 22.41 22.49 355.41 4.42 100 48 11.52 3626 190 3.35 6536 0 0 1 21.5 99.41 93 22.35 22.35 360.27 4.42 100 53 11.57 3706 190 3.18 6594 0 0 1 21.5 91.95 93 22.28 22.35 341.79 4.38 100 53 11.69 3786 190 3.12 6768 0 0 1 22.5 101.07 93 22.26 22.35 358.72 4.42 100 53 11.69 3866 190 3.11 6792 0 0 1 23 96.17 93 21.54 21.91 342.58 4.34 100 53 11.66 3928 190 2.92 6892 0 0 1 23.5 92.62 93 21.3 21.33 349.73 4.4 100 53 11.83 4010 190 2.92 6985 0 0 1 24 90.06 93 20.36 20.46 335.44 4.38 100 53 11.58 4090 190 2.83 7061 0 0 1 24 88.88 93 19.93 20.02 324.38 4.32 100 61 11.6 4170 190 2.7 7248 0 0 1 24 92.78 93 19.81 19.88 333.05 4.34 100 61 11.47 4249 190 2.75 7337 0 0 1 24 92.35 93 19.37 19.59 325.15 4.32 100 61 11.36 4314 190 2.66 7348 0 0 1 24 79.95 93 19.17 19.59 304.93 4.34 90.2 61 11.27 4393 190 0.93 7624 0 0 1 33 4.84 91 2.42 7.4 323.58 4.4 20 61 12.32 4473 190 0.23 7339 0 0 1 26 14.21 91 -5.47 -3.92 39.12 2.4 12.94 61 20.33 4552 190 0.15 7102 0 0 1 26 4.59 91 -8.01 -7.55 23.49 2.16 12.55 67 20.33 4632 190 0.18 6861 0 0 1 26 4.39 91 -8.7 -8.56 19.55 1.84 12.55 67 20.33 4713 190 0.42 6622 0 0 1 45 8.48 91 -5.25 -9.14 17.85 2 26.27 67 20.33 4776 190 1.61 5838 0 0 1 48 33.09 91 4.57 3.92 135.2 3.34 98.43 67 20.33 4858 190 1.84 5026 0 0 1 25.5 40.74 91 6.83 5.95 151.21 3.5 100 67 20.33 4937 190 1.85 5424 0 0 1 24 48.03 91 7.97 7.55 168.15 3.62 100 67 20.33 5015 190 2.13 5244 0 0 1 23 50.35 91 10.2 9.29 177.48 3.7 100 72 11.77 5096 190 2.4 5431 0 0 1 22 56.77 91 12.08 11.32 193.88 3.88 100 72 10.91 5176 190 2.64 5344 0 0 1 21 65.76 91 14.39 13.78 234.22 3.96 100 72 10.73 5240 190 2.92 5447 0 0 1 20 70.89 91 16.7 16.11 242.27 4 100 72 10.83 5320 190 2.95 5460 0 0 1 18.5 82.48 91 18.92 18.43 280.62 4.18 100 72 10.75 5399 190 3.19 5612 0 0 1 18 82.62 91 20.46 20.02 278.36 4.16 100 72 10.58 5479 190 3.16 5620 0 0 1 17.5 87.52 91 21.42 21.18 300.29 4.24 100 75 10.6 5559 190 3.24 5718 0 0 1 18.5 89.26 91 21.88 21.76 311.89 4.22 100 75 10.61 5623 190 3.36 5711 0 0 1 18 86.74 91 22.27 22.05 301.84 4.26 100 75 10.79 5704 190 3.15 5817 0 0 1 18.5 91.83 91 22.28 22.35 318.17 4.32 100 75 11.04 5783 190 3.29 5840 0 0 1 19 90.96 91 22.47 22.35 309.57 4.28 100 75 11.04 5864 190 3.19 5914 0 0 1 19 87.36 91 22.24 22.49 314.99 4.3 100 75 11.07 5943 190 3.28 6016 0 0 1 19.5 92.4 91 22.21 22.35 324.4 4.32 100 75 11.13 6022 190 3.28 6002 0 0 1 20 91.87 91 22.19 22.2 321.24 4.3 100 79 11.08 6102 190 3.04 6050 0 0 1 20 92.94 91 21.99 22.05 329.93 4.32 100 79 11.14 6167 190 3.2 6108 0 0 1 20 92.52 91 21.87 21.91 339.41 4.26 100 79 11.14 6246 190 3.08 6211 0 0 1 20 87.86 91 22 21.91 321.26 4.34 100 79 11.13 6328 190 3.16 6298 0 0 1 20.5 93.1 91 21.94 21.91 337.82 4.36 100 79 11.1 6406 190 3.14 6287 0 0 1 21 88.52 91 21.9 21.91 323.62 4.3 100 79 11.19 6486 190 3.05 6323 0 0 1 21 94.42 91 21.91 21.91 340.2 4.34 100 83 11.2 6567 190 3.24 6456 0 0 1 21.5 95.04 91 21.93 21.91 343.38 4.34 100 83 11.25 6630 190 3.12 6494 0 0 1 21 91.44 91 21.91 21.91 326.76 4.36 100 83 11.23 6709 190 3.16 6484 0 0 1 21.5 96.84 91 21.91 21.91 351.32 4.4 100 83 11.19 6791 190 3.21 6604 0 0 1 22 91.58 91 21.85 21.91 328.37 4.38 100 83 11.16 6869 190 3.03 6690 0 0 1 22 97.54 91 21.93 21.91 352.99 4.42 100 83 11.19 6948 190 3.2 6754 0 0 1 23 97.97 91 21.9 21.91 352.19 4.4 100 88 11.14 7013 190 3.07 6676 0 0 1 22.5 92.57 91 22.12 22.05 341.79 4.4 100 88 11.14 7093 190 3.14 6824 0 0 1 23 98.99 91 22.21 22.05 352.19 4.38 100 88 11.16 7173 190 3.19 6875 0 0 1 23.5 95.34 91 22.22 22.2 344.96 4.38 100 88 11.36 7253 190 3 6836 0 0 1 23 99.17 91 22.27 22.2 357.09 4.38 100 88 11.26 7333 190 3.15 6904 0 0 1 23.5 98.68 91 22.28 22.35 355.41 4.42 100 88 11.48 7414 190 3 6915 0 0 1 23.5 94.41 91 22.36 22.35 343.38 4.4 100 93 11.47 7479 190 3.14 6985 0 0 1 23.5 98.93 91 22.53 22.35 365.21 4.44 100 93 11.47 7556 190 3.04 7025 0 0 1 23.5 97.41 91 22.61 22.49 357.14 4.44 100 93 11.5 7637 190 2.98 7141 0 0 1 23.5 99.65 91 22.62 22.64 362.78 4.44 100 93 11.63 7716 190 3.04 7296 0 0 1 23.5 101.83 91 22.74 22.64 364.37 4.46 100 93 11.45 7797 190 2.93 7136 0 0 1 23.5 97.43 91 22.92 22.78 356.25 4.38 100 93 11.64 7860 190 3.07 7225 0 0 1 23.5 101.73 91 23.01 22.78 365.2 4.46 100 98 12.5 7939 190 3.01 7340 0 0 1 23 101.78 91 23.11 22.78 358.77 4.36 100 98 12.1 8020 190 2.92 7300 0 0 1 23 104.35 91 23.18 22.78 379.61 4.48 100 98 11.97 8100 190 2.95 7442 0 0 1 23.5 96.74 91 20.42 22.78 374.43 4.42 78.04 98 12.69 8181 190 0.96 7442 0 0 1 33 4.76 91 -0.29 5.22 211.37 4.36 15.69 98 11.97 8261 190 0.41 7474 0 0 1 25.5 4.82 91 -6.8 -5.95 75.13 3.1 12.16 98 12.97 8324 190 0.23 7151 0 0 1 26 4.62 91 -8 -7.55 20.24 1.96 12.55 102 17.6 8404 190 0.17 6942 0 0 1 26 4.44 91 -8.8 -8.71 26.8 2.14 12.55 102 13.82 8484 190 0.16 6779 0 0 1 26 4.38 91 -9.14 -9.14 23.17 2.02 12.55 102 20.33 8563 192 1.38 6394 0 0 1 46 19.48 91 4.55 1.02 64.7 2.34 75.69 102 20.33 8644 192 1.86 5009 0 0 1 27 36.33 91 6.51 5.8 144.86 3.56 100 102 20.33 8708 192 2.07 5302 0 0 1 24.5 45.79 91 8.3 7.69 161.46 3.5 100 102 20.33 8788 192 2.08 5230 0 0 1 22.5 51.8 91 10.57 10.01 178.9 3.76 100 104 14.33 8868 192 2.48 5259 0 0 1 22 58.34 91 13.52 12.04 210.44 3.88 100 104 11.54 8946 192 2.93 5286 0 0 1 20.5 65.06 91 15.85 14.95 217.48 3.98 100 104 10.72 9027 192 2.99 5266 0 0 1 18.5 77.52 91 18.82 18.14 272.55 4.06 100 104 10.66 9108 192 3.3 5320 0 0 1 17.5 85.11 91 21.4 20.89 297.2 4.16 100 104 10.7 9171 192 3.29 5338 0 0 1 16.5 89.97 91 23.26 22.78 305.71 4.26 100 104 10.58 9251 192 3.54 5406 0 0 1 16.5 92.32 91 24.48 22.78 317.35 4.26 100 106 10.55 9330 192 3.6 5454 0 0 1 16 89.69 91 25.03 22.78 306.48 4.2 100 106 10.78 9410 192 3.51 5463 0 0 1 16 95.59 91 25.62 22.78 329.1 4.28 100 106 10.85 9490 192 3.59 5488 0 0 1 16.5 94.88 91 25.8 22.78 329.12 4.3 100 106 10.91 9571 192 3.42 5544 0 0 1 16.5 95.86 91 25.94 22.78 334.64 4.3 100 106 11.04 9634 192 3.65 5504 0 0 1 16 95.1 91 26.18 22.78 337.02 4.36 100 106 11.08 9714 192 3.64 5519 0 0 1 16.5 93.01 91 26.09 22.78 329.93 4.34 100 106 11.1 9794 192 3.5 5565 0 0 1 16.5 96.06 91 26.12 22.78 335.44 4.34 100 108 11.16 9874 192 3.65 5574 0 0 1 16.5 95.13 91 26.06 22.78 339.41 4.34 100 108 11.32 9953 192 3.5 5674 0 0 1 16.5 90.78 91 25.99 22.78 336.23 4.4 100 108 11.35 10017 192 3.64 5731 0 0 1 17 96.72 91 25.8 22.78 348.18 4.32 100 108 11.35 10098 192 3.6 5695 0 0 1 17 93.37 91 25.83 22.78 329.1 4.36 100 108 11.47 10177 192 3.52 5743 0 0 1 17 98.01 91 25.69 22.78 346.55 4.38 100 108 11.27 10257 192 3.64 5725 0 0 1 17.5 96.48 91 25.72 22.78 346.55 4.36 100 111 11.32 10337 192 3.65 5752 0 0 1 17.5 94.3 91 25.53 22.78 346.55 4.36 100 111 11.36 10419 192 3.68 5837 0 0 1 17.5 97.3 91 25.56 22.78 352.24 4.42 100 111 11.44 10481 192 3.58 5806 0 0 1 18 97.68 91 25.49 22.78 348.22 4.36 100 111 11.47 10563 192 3.46 5884 0 0 1 18 97.91 91 25.53 22.78 348.18 4.4 100 111 11.39 10642 192 3.66 5870 0 0 1 18.5 97.47 91 25.43 22.78 349.81 4.42 100 111 11.42 10721 192 3.65 5971 0 0 1 18 91.99 91 25.37 22.78 343.38 4.4 100 115 11.42 10800 192 3.66 5985 0 0 1 18.5 100.87 91 25.24 22.78 359.52 4.38 100 115 11.35 10864 192 3.58 5940 0 0 1 19 98.85 91 25.36 22.78 350.69 4.4 100 115 11.2 10944 192 3.48 6023 0 0 1 18.5 97.89 91 25.42 22.78 354.57 4.42 100 115 11.25 11023 192 3.58 6050 0 0 1 19 99.39 91 25.37 22.78 366.05 4.42 100 115 11.29 11103 192 3.6 6039 0 0 1 19 96.35 91 25.25 22.78 350.52 4.42 100 115 11.16 11185 192 3.52 6031 0 0 1 19 99.07 91 25.21 22.78 354.75 4.4 100 118 11.19 11265 192 3.54 6071 0 0 1 19 99.73 91 25.3 22.78 361.95 4.38 100 118 11.1 11328 192 3.41 6132 0 0 1 19 100.96 91 25.15 22.78 360.4 4.44 100 118 11.1 |
05-03-2012, 10:40 PM | #5864 |
Member#: 183480
South East
WELLL the wagon is down and out once again...it looks like my routine of the car hard breaking right before deployments continues (it literally breaks some major component within 2 weeks of EVERY deployment i go on)...snapped a rod in half and threw it right out the top of the block on the way home from work ...there no joke is a hole about 3" in diameter right under my throttle body linkage.
...haven't decided what i want to do yet...considering selling the car as is or parting it out and then starting the next project. i have lots of time while i am deployed to think about everything...really sucks. the clutch and PPG straightcuts literally only had like 1800 miles on them...block only had just shy of 10,000 miles on it . |
05-03-2012, 10:46 PM | #5865 |
Member#: 249068
South East
Vehicle:2010 WRX DGM Phatbotti Tuned |
Does this data read better on a spread sheet? I'm not into tuning and the language is some what alien but I'd like to learn some of this info.
05-03-2012, 10:54 PM | #5866 | |
Member#: 248202
05-03-2012, 11:09 PM | #5867 |
Member#: 183480
South East
...i feel ya lol...seriously though, i am kind of torn about what i want to do with everything. i love driving the car, but i was getting more and more serious recently about maybe selling it and starting a new project (really kinda want a newer legacy gt). this just kind of forces me into a decision a little sooner than if it hadn't of broken again.
i push my motors pretty hard so...i am not necessarily surprised that it broke, but more just surprised at what specifically broke. i was honestly expecting some of the weaker parts to let go instead of the rods, but... ...oh well i guess... if anyone is curious...as of right now, the number i am looking to get if i sold it "as is" would be about $8000...so...if anyone knows anybody in the market |
05-03-2012, 11:13 PM | #5868 |
Member#: 159243
what rods were they?
05-03-2012, 11:18 PM | #5869 |
Member#: 183480
South East
element tuning...i was in the right place at the right time and a 0 miles built shortblock kinda fell into my lap for a steal so...i went with it...if i would have had a choice i would have gone with something else, but...wasn't an option at the time...
05-03-2012, 11:42 PM | #5870 |
Member#: 159243
what do you suspect happened?
05-03-2012, 11:45 PM | #5871 |
Member#: 183480
South East
honestly, i think the rod just couldn't handle the amount of stress being put on them and took a crap...H-beams aren't really known for being the strongest rods out there. won't know for sure until i am able to get a better look at everything.
05-03-2012, 11:53 PM | #5872 |
Member#: 77470
Vehicle:04 sti 10.41@141 on e85@ 30psi--spinning |
it just snapped,the element rods are h-beams same as every h-beam out there(chinese)granted Phil does pick the nicer castings but they are still h-beams.A customer of mine had a worldone sb in his bugeye drag car and they use element rods and at the buschur race last year kicked a rod out the top.Once you get above 500whp its not if but when an h-beam will snap.
05-04-2012, 09:15 AM | #5873 |
Member#: 133146
I am sorry about your engine grover. Another H-beam bites the dust
05-04-2012, 09:16 AM | #5874 | |
Member#: 248202
Doom doom doom. Da doom doom doom da doom |
05-04-2012, 11:43 AM | #5875 |
Member#: 183480
South East
yeah...feces will occur and gotta pay to play i guess so...story of my life lol
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY | Motion Lab Tuning | Proven Power Bragging | 125 | 04-12-2010 02:57 AM |
jid2 Track Car - e85 ARMY | jid2 | Member's Car Gallery | 38 | 01-22-2010 10:44 PM |
The Honduran army is the bravest in the world... | wrxcelent | Off-Topic | 36 | 07-07-2009 08:21 AM |
Spacific E85 Tuning thread Here ? | discopotato03 | Engine Management & Tuning | 1 | 09-09-2008 11:01 AM |
Did anyone hear the one about the Italian army and the IRAQI satiation? | Asinine | Off-Topic | 3 | 09-20-2005 07:06 PM |
