Welcome to the North American Subaru Impreza Owners Club Wednesday August 5, 2020
Old 04-27-2016, 01:45 PM   #176
NJReppin
Member#: 371530
2004 PBP 2.5RS
PSM 04 STi
Originally Posted by T-37 View Post
The threads in the rack are different, so you can't reuse the '04 inner tie rods unless you use an adaptor like TeamMoist was making. The outer tie rods are the exact same part.
So reuse my outers(fairly new, moogs) and trim the inners?
NJReppin is offline   Reply With Quote
Old 04-27-2016, 02:07 PM   #177
T-37
Member#: 175624
0304 WRX WRX
SY WRB
If you go the trim route, you'll have to trim the both inners and the outers. You should measure your current setup (the distance between the pivot joint on the outers), then trim the '15 ITR and OTRs until you can match that dimension and have a little room left to adjust both directions. You shouldn't have to reuse your outers, the new rack comes with outers (which are the same as your current outers, except brand new.) The only reason to reuse is if you are using bump steer correcting outer tie rods (whiteline, GT spec, etc.) Alternatively, if you use the adapters, and your '04 ITRs you should have your full factory adjustment range.
*disclaimer - This works on GD sedans, but 02-07 wagons and all 93-01s have a narrower track width that would require a shorter inner tie rod (using an adapter). There are just enough threads left for adjustment after trimming that it works for the GD, but further trimming in order to fit the narrower track would be impossible.
T-37 is online now   Reply With Quote
Old 04-27-2016, 02:26 PM   #178
NJReppin
Member#: 371530
2004 PBP 2.5RS
PSM 04 STi
Ok I was having some trouble comprehending all this at midnight last night lol makes more sense now..
Unfortunately team moist says they don't have any more adapters and don't have an ETA on when more are being made.. soo guess im forced to go the cutting route.
What's the deal with the PS lines being close to the subframe?
If you buy the custom fittings from the rs 25 forum everything fits nicely or its still an issue?
Old 04-27-2016, 02:43 PM   #179
T-37
Member#: 175624
0304 WRX WRX
SY WRB
It fits much better. Do not use the Fragola 14x1.5mm O-ring to 6AN Adapter. Use the Earl's adapter (p/n 9894DBHERL).
Old 04-27-2016, 02:57 PM   #180
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
The old RS25 write-up that complained of leaking lines was probably an install error (AN fitting sealing surfaces need to be *CLEAN*). I converted to -6AN lines on both the high and low pressure side, and have had zero issues/leaks.
mrsaturn7085 is offline   Reply With Quote
Old 04-27-2016, 03:05 PM   #181
T-37
Member#: 175624
0304 WRX WRX
SY WRB
UPDATE:
I've had a couple of o-ring failures at autox, so I decided to do a little further investigation into the problem. I noticed some difference between the stock P/S line vs. the Fragola AN adapter I was using.
I think the Fragola 14x1.5mm O-ring to 6AN Adapter was the culprit. I believe the hardline from the rack was bottoming out on the adapter so the o-ring isn't quite seating fully/correctly. I purchased 2 new adapters, one is an Earls and the other is a Russell.
Here is the stock line (notice the chamfered/tapered bore)
http://i.imgur.com/pLugFR2l.jpg
Here is the Fragola adapter (p/n 491970) (notice how there is no chamfer/taper to allow space for the hardline)
http://i.imgur.com/p57kJKcl.jpg?1
Here is the Russell adapter (p/n 640820)
http://i.imgur.com/S1fIkZ5l.jpg?2
Here is the Earl's adapter (p/n 9894DBHERL)
http://i.imgur.com/uRSWk6Wl.jpg?1
I believe either the Earl's or Russell adapter will work MUCH better than the Fragola, but I haven't test fit yet. The Russell looks like the closest to the stock line, so I'm leaning towards that one. I'm hoping to get it all back together by the autocross this weekend, so I will report back.
This is what I was referring to with the Fragola/Earls comment.
Old 04-27-2016, 05:54 PM   #182
NJReppin
Member#: 371530
2004 PBP 2.5RS
PSM 04 STi
Yea I made note of that in the first post.. okay thanks alot
So basically I need to buy the adapters/fittings/lines, buy a GR steering rack mount kit, buy the rack itself and then that's everything besides doing the mods and installing...
Not entirely too bad..
Looks like about a 900-1k job if labor is done in house...
Thanks alot for the rest explanation and help...
Really appreciate you not giving the usual "SEARCH" comment...
Again, thanks a ton!
Old 04-27-2016, 07:41 PM   #183
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
It is what it is...There are different ways to do it, and a few things that I would change in hindsight, but I was on a schedule and wanted to get it done a simply and cheaply as possible. There was nothing out there for the GD when I made this thread, so I wanted to give the people that were interested in doing this some insight as to how I got it done.
Don't take my statement for hate now....dats not what I said nor meant. In fact, the 3 or 4 writeups I've read showed me the path I wanted to take as each person's vision both detailed what they did and what they could have done through various forks in the road. My method, if it doesn't blow up in my face, will be slightly different than anyone else, net the same result, and fill in a few more gaps. 1-3 more installs and everyone should have all the various ways to skin this cat covered. I'm mainly happy to forge the GG/wagon path as, knock on wood, it should be identical to the RS path, but someone has to walk through the minefield to be sure.
Old 04-28-2016, 08:04 AM   #184
smoky
Member#: 221439
2004 STI
Look at post 122. This is on my 04 STI. I was able to reuse the whole thing by only adding about 1cm of thread to the 15 STI rack. Super easy to do.
http://forums.nasioc.com/forums/show...&postcount=122
Originally Posted by Unabomber View Post
I can tell you less than a week. Install slated for this Saturday. First install evAr on a 04 wagon AKA GG. Should (knock on wood) be same as a RS install. You can reuse 04 RS tie rods as long as you have the special M16 to M20 adapter. I have RS tie rods new as I'm not 100% sure Wagon tie rods are the same a RS tie rods, so I'll reuse mine if same and return RS tie rods. Look for full write up sometime early next week that is hopefully useful as I'm not entirely happy with the 3 or 4 writes ups currently on the internet.
smoky is offline   Reply With Quote
Old 05-08-2016, 05:15 PM   #185
MP_Gymkhana
Member#: 412296
2005 STi
Great write up, I followed this thread as a guideline for my install. I am just about finished on this install on my 05 STi. The 05-07 is actually a little more involved then the 04. I'm assuming being that 04 is 5x100 bolt pattern it shares the same front cross member as a WRX. Don't quote me on that, just an assumption.
That being said, the 05-07 needs a much larger hole cut open in the sub frame for the rack to go thru, as I originally cut a hole similar to the one pictured on here, and it wasn't even close. Also, on the 05-07 STi, the subfame support steering rack cover has additional mounting points on the underside of the subframe, which need to be trimmed on both sides a fair amount in order for the lines on the rack to clear them.
As for the spacer required, you will actually need 2 spacers. The 1st spacer as mentioned in this thread, as well as a smaller spacer which will fit in between the oem steering rack brace. You should also know, you cannot use the cusco steering rack brace, as it has a different shape, but the factory one works perfectly.
Another thing to mention, as for an aftermarket bushing kit. I went with the SuperPro Kit. Part#SPF2648K. That is the bushing kit for a 05-07 STi. No need to purchase 2 individual kits as the 05-07 STi does not have a passenger side D-shaped busing. I also cross referenced all the part# from Superpro, and the kit fits perfectly.
Ill try and get some pictures up for anybody that interested. Haven't seen anything posted yet of an 05-07STi Install, so if anyone plans on doing this, now you know what to expect. Good luck!!!
MP_Gymkhana is offline   Reply With Quote
Old 05-09-2016, 10:18 AM   #186
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
I was planning on upgrading to the GD STI crossmember at the same time as the rack install, so any pics you can provide would be very helpful.
car_freak85 is offline   Reply With Quote
Old 05-09-2016, 10:48 AM   #187
kennygunit
Member#: 249264
1969 Ford Mustang
Green
I plan on doing this swap over summer. Any details would be greatly appreciated! (Pictures would be awesome too!)
Quick Questions: Would a roll center kit for an 06 STI work with this rack?
kennygunit is offline   Reply With Quote
Old 05-09-2016, 12:21 PM   #188
klaas
Member#: 336000
2005 Impreza STi
I too would appreciate any more information and pictures regarding the 05 sti install.
I have this planned for winter time this year.
klaas is offline   Reply With Quote
Old 05-11-2016, 09:48 AM   #189
MP_Gymkhana
Member#: 412296
2005 STi
Sure I'll post some shortly.
No problem
Yes, aside from the fact you have to cut the inner tie rods shorter, the thread size is the same. I'm using the Whiteline roll center kit, fitment is good.
Yea if you guys can wait a couple weeks, seems like no one is in a rush for this install, I need to make another spacer and am getting some parts powder coated then I'll post a bunch of pics. No problem.
Old 05-12-2016, 03:04 AM   #190
Cruatchi
Member#: 353182
2005 Impreza WRX STi
+1 for more info on 05 STi install.
Since tie rods are being shortened, what will the impact be when doing alignments? let's say if one is trying to align to factory specs.
Cruatchi is offline   Reply With Quote
Old 05-14-2016, 05:53 PM   #191
kennygunit
Member#: 249264
1969 Ford Mustang
Green
Thank You! I'm a novice when it comes to changing anything steering wise, so the more detail you can add, the better!
Old 05-16-2016, 09:58 PM   #192
MP_Gymkhana
Member#: 412296
2005 STi
So I installed my rack on the weekend. Again, in a 2005 STi. I took some pictures for you guys planning on doing this swap. The Install isn't fully completed yet, as I still need to make a spacer, but this will give you an idea of what I have done so far.
In this image, you can see where I trimmed the support bracket on the subframe where the lower subframe brace/jacking point attaches too. You will need to trim these brackets on the L and R side of the subframe to provide clearance for the steering rack hard lines.
Here you can see how much I had to trim out of the subframe in order for the steering rack to fit up thru the hole.
Now that the rack is installed, you can see after trimming these brackets on the subframe, the hardlines on the rack actually sit above and kind of nestled in behind these brackets.
Kind of hard to tell, but after trimming the hole, the pinion input shaft body fits thru thru the opening nicely.
Here you can see where the hard lines fit up thru the opening after trimming the hole.
This shows the steering rack support bracket on the driver side. You can see where the first custom spacer is installed in the main hole thru the rack, and if you look behind it, or towards the center of the subframe, you can see the gap between the support bracket and subframe, this is where I will need to make the other spacer to fill the void.
Lastly, here's an underside look at the support bracket. You can see one bolt is missing where I will need to make a spacer. You can use the original bolt from the steering rack, on the side which now has a spacer as it is the proper length. I currently have a spare bolt from my ubrace holding the rack up where the spacer is, however it is only a grade 9 bolt, and is there temporarily. I will need to source a proper Grade 10.9 Bolt. But doing this install on the 05-07 STi you will really only need to purchase one Grade 10.9 M10x1.25x60mm Bolt to properly complete this install. There is no need to purchase the other bolt and or washers that is mentioned at the beginning of this thread as the OEM STi Steering rack support bracket makes up the difference in mounting the rack over the 04 STi install.
Ill try and get some more pictures once I fully complete the install, lmk if you have any questions, I don't mind answering them.
Old 05-17-2016, 08:48 AM   #193
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
Hmmm, it seems there are subtle differences in the subframes then? Those that installed the 15 STI rack can attest to that, correct? It seems the 05 STI front subframe will require an additional spacer as opposed to the one spacer needed for the (IIRC)06-07 WRX front subframe? Also the opening it cut larger, as well as trimming of the jacking plate mounting locations of the 05 STI.
Gymkhana, great job by the way. Thanks for sharing.
kenliu84 is online now   Reply With Quote
Old 05-17-2016, 01:47 PM   #194
T-37
Member#: 175624
0304 WRX WRX
SY WRB
05-07 should have the same front subframes whether STi or WRX.
02-04 WRX/STi should only require one spacer
EDIT: Incorrect info, see JarHarms post below
Old 05-17-2016, 04:37 PM   #195
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
MP, any chance you know how much the subframe and support brackets that were removed weigh in total?
WRX8XB is offline   Reply With Quote
Old 05-17-2016, 09:52 PM   #196
JarHarms
Member#: 138994
2006 WRX, 6MT, 5x114
TMIC, FP blue, ELH
>Front Cross Member info< Yea for 2006-07 the WRX and STI shared the same front cross member.
I'd be interested in some details/photos on the RHS side hardline connections. How do they fit, do they "sort of" line up with factory steering lines, any contact anything else in that installed area, need bending, etc. Basically can you use oem lines instead of fancy fabricated ones.
Does the 06-07 jacking plate fit back in place w/o touching the rack lines, body, or rubber boots?
Are "both" of your spacers 0.39" thick?
**In reality you could omit the 2nd spacer, leave out the 2006-07 style brace, use fender washers, and be same off as someone installing to an 04 STI or 2002-05 WRX. Or use the brace for added support.
JarHarms is offline   Reply With Quote
Old 05-18-2016, 02:56 PM   #197
mrsaturn7085
Member#: 375462
WR Blue
Originally Posted by JarHarms View Post
...for 2006-07 the WRX and STI shared the same front cross member.
The 2005 model w/added subframe bolting points is still the best one
This was a Spec C-only item in Japan.
I can't comment on the 2015 rack, but I can tell you that even the factory Group N 13:1 rack hard lines WILL contact the jacking plate slightly. Given this was a purpose-built design, it would not surprise me if the 2015 rack was the same (or worse).
Old 05-18-2016, 04:53 PM   #198
JarHarms
Member#: 138994
TMIC, FP blue, ELH
Default Install: 2015 STi 13:1 steering rack into a GD
Yes. I'm completely aware of that version.
Good to know on the LHS GpN rack. I suspect you are using the stamped one-piece version jack plate? I'd still like to hear from a 2015 rack user too.....
Old 05-18-2016, 08:03 PM   #199
Cruatchi
Member#: 353182
Similar to JarHarms, I want to know about the power steering lines too.
I'm still curious about the impact on your ability to do an alignment since the tie rods are shortened.
And one more question to add. How are you making your spacers?
Old 05-18-2016, 08:55 PM   #200
mrsaturn7085
Member#: 375462
WR Blue
Not anymore - I switched to the 2005 2-piece style for the larger jacking point and the ability to bolt a skid plate a little easier.
