09-26-2005, 07:38 PM | #1 |
Member#: 23676
NESIC
Vehicle:. |
Tiny det issue. Thoughts?
Ok so I am spraying alch/water from 6ishPSI up.
STI TXS TMIC stealthback VF39 untouched Alcohol injection kit, spraying mix of 50% water 50% denatured alch from abotu 6PSI up. So I am getting a TINY bit of det showing up in the upper end. There are a few things to keep in mind when reading this log 1. I have the knock threshold turned up. It is more sensative to det than a standard UTEC. 1 counts are engine noise at this point, or VERY light det that the UTEC never would have detected before. As such I have it set to only respond to a knock count of 2 or higher. 2. I have the MAP reading in ABSOLUTE, the gauge reads 1.3bar, which is about 18.7PSI. The det event is towards the bottom of this pull Code:
704 -12.0 1.1 1 00 00 +18.3 1.2 ECU. +0.0 ECU. 1.1 14.11 693 -12.0 1.0 0 00 00 +18.2 1.2 ECU. +0.0 ECU. 1.1 14.11 2142 -0.4 2.5 97 10 00 +28.4 12.5 ECU. +0.0 375.00 2.5 16.19 2161 +0.2 2.6 98 10 00 +27.9 12.7 ECU. +0.0 375.00 2.7 16.19 2161 +0.8 2.6 97 10 00 +27.4 13.7 ECU. +0.0 375.00 2.6 15.37 2216 +1.5 2.6 98 20 00 +27.0 14.3 +22.6 +1.1 375.00 2.6 14.33 2256 +2.1 2.7 98 20 00 +26.3 15.0 +22.0 +0.6 375.00 2.7 13.81 2262 +2.5 2.6 97 20 00 +25.2 15.1 +21.6 +1.0 375.00 2.7 13.62 2300 +2.9 2.7 97 20 00 +24.6 15.5 +21.6 +0.9 375.00 2.8 13.36 2345 +3.3 2.8 97 20 00 +22.5 16.8 +21.4 +0.9 375.00 2.8 13.20 2364 +3.7 2.8 98 30 00 +22.2 16.9 +20.2 +2.9 375.00 2.9 12.93 2352 +4.3 2.8 97 30 00 +19.4 19.9 +19.8 +2.9 375.00 3.0 12.67 2399 +4.7 2.8 97 30 00 +18.4 18.8 +19.8 +2.9 375.00 3.0 12.25 2489 +5.3 2.9 98 30 00 +18.0 20.9 +19.2 +2.9 375.00 3.0 11.76 2519 +5.7 3.0 98 40 00 +16.7 23.5 +18.0 +1.0 375.00 3.1 11.73 2536 +6.6 3.0 97 40 00 +16.7 22.6 +17.8 +1.8 375.00 3.1 11.73 2581 +7.4 3.0 98 40 00 +15.6 24.5 +17.5 +1.4 375.00 3.2 11.56 2658 +8.2 3.1 97 50 00 +15.1 26.2 +18.0 -0.3 375.00 3.1 11.43 2662 +9.2 3.2 97 50 00 +15.6 25.1 +17.6 -0.7 375.00 3.2 11.33 2759 +10.0 3.3 98 50 00 +15.5 27.2 +17.4 -0.5 375.00 3.3 11.45 2784 +10.8 3.3 98 60 00 +14.3 27.9 +17.0 -0.9 400.00 3.1 11.52 2808 +11.9 3.5 98 60 00 +14.1 32.6 +17.0 -1.9 400.00 3.4 11.33 2873 +13.1 3.4 96 70 00 +13.3 33.7 +17.0 -2.5 400.00 3.4 11.14 2939 +14.3 3.5 97 80 00 +12.9 36.0 +17.0 -2.3 400.00 3.5 11.06 2986 +15.3 3.5 98 80 00 +13.7 38.0 +17.0 -2.1 400.00 3.4 11.08 3030 +15.9 3.6 98 80 00 +13.4 37.4 +17.0 -2.3 400.00 3.4 11.14 3033 +16.4 3.6 97 80 00 +13.2 40.7 +17.0 -2.7 400.00 3.6 11.12 3192 +16.6 3.6 96 80 00 +13.4 43.6 +17.0 -2.7 400.00 3.5 11.12 3205 +16.8 3.7 97 80 00 +13.8 42.8 +17.0 -3.2 400.00 3.6 11.20 3290 +17.4 3.7 97 80 00 +14.1 43.7 +17.1 -3.4 400.00 3.5 11.27 3306 +17.0 3.8 98 80 00 +14.8 43.0 +17.2 -3.6 400.00 3.5 11.43 3373 +17.0 3.8 97 80 00 +15.0 45.8 +17.5 -4.0 400.00 3.5 11.52 3415 +17.0 3.6 96 80 00 +15.4 41.9 +18.1 -5.2 400.00 3.7 11.56 3475 +16.8 3.7 97 80 00 +16.4 46.8 +18.0 -4.4 400.00 3.6 11.68 3599 +17.0 3.9 98 80 00 +15.3 48.4 +18.3 -4.6 400.00 3.6 11.84 3603 +17.0 3.9 97 80 00 +15.2 50.0 +18.5 -4.8 400.00 3.5 11.84 3703 +16.8 4.0 97 80 00 +15.7 48.8 +18.7 -4.9 400.00 3.7 11.77 3728 +17.0 3.9 96 80 00 +15.8 51.3 +18.8 -5.3 400.00 3.7 11.89 3762 +17.2 4.0 97 80 00 +16.4 50.4 +19.3 -5.3 400.00 3.7 11.77 3809 +17.0 3.9 97 80 00 +16.6 53.1 +19.5 -5.4 400.00 3.7 11.77 3954 +17.4 4.0 97 80 00 +16.5 52.8 +19.5 -5.4 400.00 3.7 11.89 3940 +17.6 4.0 97 90 00 +17.2 53.2 +18.7 -4.5 400.00 3.8 11.92 3982 +17.4 3.9 96 80 00 +17.0 52.8 +20.0 -5.3 400.00 3.7 11.92 4065 +17.8 4.0 97 80 00 +17.1 54.6 +20.0 -5.3 400.00 3.8 11.81 4198 +17.0 4.0 97 80 00 +17.4 55.1 +20.0 -5.1 400.00 3.9 11.77 4177 +17.2 4.0 97 80 00 +17.4 57.5 +20.0 -5.0 400.00 3.7 11.81 4251 +17.0 4.0 97 80 00 +17.6 57.2 +20.0 -4.8 400.00 3.9 11.84 4317 +16.6 4.1 96 80 00 +17.6 57.5 +20.0 -4.9 400.00 3.8 11.80 4385 +17.0 4.1 97 80 00 +17.3 59.8 +20.4 -4.8 400.00 3.9 11.68 4420 +16.8 4.1 97 80 00 +17.6 56.4 +20.6 -4.7 400.00 3.9 11.65 4522 +17.2 4.1 97 80 00 +18.4 58.3 +20.8 -4.9 400.00 3.9 11.68 4516 +17.2 4.1 97 80 00 +19.3 61.5 +21.0 -5.0 400.00 3.9 11.77 4604 +17.0 4.1 96 80 00 +19.6 65.0 +21.3 -5.5 400.00 4.0 11.71 4629 +17.2 4.2 97 80 00 +20.5 63.7 +21.6 -6.0 400.00 3.9 11.62 4701 +16.8 4.2 97 80 00 +21.5 63.1 +21.9 -6.6 400.00 4.0 11.68 4701 +17.0 4.2 96 80 00 +22.1 63.5 +22.0 -6.8 400.00 3.9 11.81 4852 +17.2 4.2 97 80 00 +22.7 69.0 +24.1 -6.8 400.00 3.9 11.80 4873 +17.4 4.2 97 90 00 +22.2 69.8 +23.1 -5.9 400.00 4.0 11.68 4930 +17.4 4.2 97 90 00 +22.3 68.0 +23.8 -5.9 400.00 4.0 11.53 5020 +17.4 4.3 97 80 00 +22.8 67.2 +24.8 -6.7 400.00 4.0 11.56 5027 +17.6 4.2 95 80 00 +22.9 66.5 +25.5 -6.6 400.00 3.9 11.68 4982 +16.8 4.2 97 80 00 +21.7 69.2 +25.5 -6.7 400.00 4.0 11.73 5020 +16.8 4.3 97 80 00 +21.5 70.9 +25.5 -6.6 400.00 4.0 11.71 5224 +17.2 4.2 97 80 00 +21.7 70.1 +25.5 -6.3 400.00 4.0 11.67 5232 +16.6 4.3 97 80 00 +21.4 72.9 +25.8 -6.3 435.00 4.0 11.65 5324 +16.4 4.3 95 80 00 +20.7 68.6 +25.7 -6.3 400.00 4.0 11.61 5307 +16.1 4.4 97 70 00 +20.3 75.8 +25.5 -5.8 435.00 4.1 11.52 5437 +15.3 4.3 96 70 00 +20.5 70.9 +25.7 -5.8 435.00 4.1 11.52 5482 +15.5 4.4 97 80 00 +21.3 71.2 +26.2 -6.7 445.00 4.1 11.58 5420 +15.7 4.4 97 80 00 +21.7 73.8 +26.0 -6.4 445.00 4.1 11.68 5491 +15.7 4.4 97 80 00 +21.7 71.1 +26.5 -6.4 445.00 4.0 11.73 5509 +15.9 4.4 97 70 00 +21.6 69.5 +26.0 -6.1 445.00 4.1 11.76 5737 +15.1 4.4 95 70 00 +21.4 70.6 +26.0 -6.0 445.00 4.1 11.73 5767 +14.9 4.4 97 70 00 +21.7 75.3 +26.0 -6.1 445.00 4.1 11.62 5621 +14.9 4.4 97 70 00 +21.6 75.4 +26.0 -6.2 445.00 4.1 11.62 5707 +14.7 4.3 95 70 00 +22.0 75.9 +26.0 -6.2 445.00 4.1 11.65 5747 +14.7 4.4 97 70 00 +22.4 73.5 +26.0 -6.3 445.00 4.1 11.65 5941 +14.9 4.3 97 70 01 +22.8 76.6 +26.1 -6.1 475.00 4.2 11.67 5837 +15.1 4.4 97 80 00 +23.9 78.0 +26.8 -6.6 475.00 4.1 11.62 5787 +14.5 4.4 97 70 00 +23.7 77.6 +26.1 -6.1 475.00 4.1 11.61 5827 +14.3 4.4 97 60 03 +24.0 74.5 +14.4 -6.3 475.00 4.0 11.53 6016 +14.1 4.4 97 70 00 +23.7 77.6 +14.6 -5.6 475.00 4.1 11.56 5973 +13.3 4.3 95 70 00 +23.4 76.9 +15.0 -5.8 475.00 4.1 11.62 6006 +11.7 2.5 0 00 00 +23.1 9.3 ECU. +0.0 ECU. 1.9 11.65 5688 +5.5 1.4 0 00 00 +23.1 6.0 ECU. +0.0 ECU. 1.6 12.78 |
09-26-2005, 09:15 PM | #2 |
Member#: 45516
MAIC
Vehicle:MY04 STi Black |
I would try a hair less timing right in the 50-70 load columns at that RPM, maybe subtract like .3 or .5 from your map in that region. It's weird how you shift out of the higher load site for that brief second down to 60% even though you stay on the gas straight through...probably just because it was in a lower gear I assume? Anyway, yeah I'd try a **** hair less timing....
09-26-2005, 09:22 PM | #3 |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
Oh good. More endless columns of unlabelled "data."
09-27-2005, 09:19 AM | #4 | |
Member#: 37731
09-26-2005, 09:37 PM | #5 |
Member#: 25905
SCIC
Vehicle:2003 Silver Wagon Tuned with Enginuity |
If you turn down the boost 1psi up top, does the knock go away?
09-27-2005, 09:21 AM | #6 |
Member#: 37731
Code:
5787 +14.5 4.4 97 70 00 +23.7 77.6 +26.1 -6.1 475.00 4.1 11.61 5827 +14.3 4.4 97 60 03 +24.0 74.5 +14.4 -6.3 475.00 4.0 11.53 |
09-27-2005, 09:46 AM | #7 |
Member#: 29963
Vehicle:04 sti silver |
Looks like you are running two much timing, since you really arn't too lean and your boost is not that high.
09-27-2005, 09:56 AM | #8 |
Member#: 6124
MWSOC
Vehicle:2000 NFR AP1 S2000 '07 Honda FIT sport (5MT) |
Indulge my curiosity....
Set the 60-80 columns at row 5750 to -6... Then go logging. Jorge (RiftsWRX) www.ProjectWRX.com |
09-27-2005, 11:55 AM | #9 | |
Member#: 29963
Jorge, Are you thinking could be related to a >4% movement in his IDC's, or just to lean? |
09-27-2005, 12:19 PM | #10 | |
Member#: 6124
MWSOC
I'm thinking the tuna isn't updating fast enough. But a 4% change in IDC within 150 RPM tells me that for that brief period of time there's a DRAMATIC change in what happened in there. The only constant is a rather dramatic change in cross column mapping. So for grins, map them the same at that point. If that makes an improvement, do the same for 5500 and 6000. Jorge (RiftsWRX) www.ProjectWRX.com |
09-27-2005, 10:05 AM | #11 |
Member#: 27108
MWSOC
Vehicle:2004 STi 2004 A4 |
Wow... Look at the RPM bouncing all over the place up there...
...and it starts well before the "3" knock event. I wouldn't be so quick to dismiss that first "1" knock as just engine noise. |
09-27-2005, 10:30 AM | #12 | |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
strange. dave you don't see this or feel this while driving, do you? |
09-27-2005, 12:03 PM | #13 |
Member#: 32792
NESIC
how does your air filter and MAF sensor look? clean?
09-29-2005, 11:55 AM | #14 |
Member#: 23676
NESIC
Vehicle:. |
So you think going through the fuel maps and smoothing the numbers out a bit could help?
My map is really spotty at this point, as I have been tweaking this area, and that area, little changes at a time, far from what I would consider a "finished" map. WHich would explain the -6.3 to -6.1 jumps. I havent had a whole lot of opportunity to do any real tuning, so its been mini pulls here and there as I can. I also havent been putting a ton of effort into smoothing the a/f. More into just getting it into shape and getting it into the correct area. Once I have the a/fs nailed down into the correct range, then I will be concentrating on getting them smoother, which I suspect will go a long way. |
09-29-2005, 09:28 PM | #15 |
Member#: 26876
NESIC
Vehicle:1994 Camaro Z28 383 Black M6 |
Is the pump controlled by a progressive controller?
09-29-2005, 10:01 PM | #16 |
Member#: 23676
NESIC
Vehicle:. |
yes. The SMC controller is progressive, it starts spraying at 6.5-7ish PSI and is maxing flow at 15ish PSI
Similar Threads | ||||
Honda Accord Crosstour shows tiny problems in the IIHS | AVANTI R5 | Non-Subaru News & Rumors | 13 | 06-03-2010 04:21 PM |
Regarding the Tiny TXIC Tanks issue... | glilly | Texas Impreza Club Forum -- TXIC | 0 | 04-27-2009 12:18 PM |
Ram upgrade issue. Thoughts? | Notyab | Off-Topic | 3 | 11-09-2008 10:27 PM |
Det issues | bigmike25rs | Built Motor Discussion | 13 | 04-26-2008 03:09 AM |
EM only to fix '04 WRX det / CL->OL fueling issue? | Ketchup | Engine Management & Tuning | 5 | 05-13-2005 10:05 PM |
