Notices |
#26 | |
n00b Moderator
Moderator Member#: 811
Vehicle:2000 RS-Ej20G It tastes like burning |
![]() Quote:
I predict if you push it past 18/19 psi you will run with the MAF pegged at 5v which could eventually lead to leaning out to the point that you melt a hole in your piston....all without an indication of knock. But feel free to prove me wrong! ![]() -Rob
#27 | |
Member#: 189923
W. Canada
Vehicle:1993 JDM WRX Black |
![]() Quote:
![]() I tried the diode yesterday, but the guy at the electronics store gave me the wrong diode that only produced an engine light. I will try ordering one of the net and see what happens. If not I'll pick up a defencer. |
#28 |
Member#: 201655
Vehicle:2001 TT Legacy GT-B Blue |
![]() im thinking ill run mine at 17-17.5 and leave just a small spot for error and spike in mine
#29 |
Member#: 189923
W. Canada
![]() Yuppers that's where I was trying to get mine or a tiny bit more and I hit cut in 4th and above randomly
#30 |
Member#: 201655
![]() keep us up to date on your solution and how far you take
#31 |
Member#: 189923
W. Canada
![]() I am just waiting on the diode. I have found the right one when it comes in I will try that then turn her up a bit more.
#32 |
Member#: 189923
W. Canada
![]() Diode is in. Boost is creeping towards 19psi up high and tapers back to 18psi right away. Tapering to 15psi by Redline. Much better
#33 |
Member#: 201655
![]() I cant wait to get home and do my install
#34 |
Member#: 498
South East
Vehicle:1981 jdm swapped gc sniklfritz |
![]() how dramatic is the power from stock i have ej20g with td05 front mount catless 3" blitz turbo back, gredyy type rs bov blitz intake on stock Z4 ecu and stock boost
#35 |
Member#: 189923
W. Canada
![]() Well lets say its not even comparible. I would bet an extra 60-80chp from where you are now maybe a bit less. Like leaving you in the dust different I don't know its hard to judge. I do know that when I had Rob's 440 tune I race my exact same car but stock and it was a beating.
#36 |
Member#: 498
South East
![]() damn im deff gona have to step up, what all do i need, robs eprom carl davy injector adapters some 550 injectors and a boost controller yeah?
#37 |
Member#: 189923
W. Canada
![]() I would recommend a TBE and a better IC for the 550 tune and this much boost. Other than those yes Phase 1 to Phase 2 injector collars, 550s and a MBC with Robs 550 tune.
#38 |
Member#: 201655
![]() Sniper do you think my ARC TMIC is going to be enough for the boost we are talking about or do have to step to a FMIC right away its in the works but in a few months let me know your opinion
10 days and i am home to do my swap |
#39 |
Member#: 189923
W. Canada
![]() It should be good. I am running a 02+ USDM TMIC on mine which is barely enough yours should be better than that.
#40 |
Member#: 201655
![]() My ECU worked like a charm this time rob your customer service it top notch and I want to thank you for your work and help on this. My car runs great now its nice having and extra 4-8 PSI of boost. before I was running like 10 PSI on Low and 13.5 on High now im running 14 on low and 17.5 on high. My best mileage to date is 21.5 but the newness of the tuning is still fun to play with. O yeah and the EVO X that I had to school is currently thinking twice before picking on a old looking cars from this point on.
THANKS AGAIN YOUR CUSTOMER SERVICE IS TOP NOTCH DO NOT KNOW WHAT ELSE TO SAY ABOUT IT!!!!! |
#41 |
Member#: 189923
W. Canada
![]() Mine is running strong as ever. It is starting to cool down to -10 C in the mornings here and all is well also. I may turn the boost down for winter though as in the snow traction is hopeless making this much power
#42 |
Member#: 180513
RMIC
Vehicle:Baby Baby C'mon! Looka Bomba! 99 JDM GM8 |
![]() ej25d fuel rails also work if you dont want to wait for fecker collars
#43 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
#44 |
Member#: 201655
![]() on the ej20G you need the collars to put in the 550CC STi injectors or those fuel rails instead of collars what ever way you chose to go with. Someone above asked the required parts list for this type of tune and he was told to use the collars but it was also being pointed out that you can just use those fuel rails instead of the collar kit
#45 | |
Member#: 180513
RMIC
![]() Quote:
they have been stolen ![]() |
#46 |
Member#: 201655
![]() thats what im here for bro also you can get collars and injectors from
http://www.deatschwerks.com/catalog/...php?cPath=0_21 They also have great customer service |
#47 | |
Member#: 832
RMIC
![]() Quote:
#48 |
Member#: 201655
![]() eh kinda i just re-read the hole post again before i put anything up keeps it fresh in my head thats probably why I saw the three posts or so above mine
#49 |
Member#: 189923
W. Canada
![]() Collars worked great for me. You don't even need the injector clips either as ours work fine.
#50 |
Member#: 201655
![]() I actually had to use the new clips with mine to get them to work
official Mark Jones Tuning review thread | AWDshenanigans | South West Impreza Club Forum -- SWIC | 45 | 11-12-2010 01:59 PM |
Rob's tune or PFC tune? | JDMFLCL | Pre-2002 Factory Turbo Powertrain | 25 | 04-09-2010 07:04 PM |
Defiant Autospeed tuning review. | Richardcranium419 | Texas Impreza Club Forum -- TXIC | 13 | 11-21-2007 06:28 PM |
Defiant Autospeed tuning review. | Richardcranium419 | UTEC | 0 | 11-21-2007 01:56 PM |
Tuning Day at Rob's (late pics) | Revision | Mid West Subaru Owners Club Forum -- MWSOC | 13 | 02-19-2001 09:07 PM |
