Welcome to the North American Subaru Impreza Owners Club Monday December 9, 2019
Old 07-22-2006, 01:05 PM   #101
flycaster
Member#: 60142
2011 WRX
Grey
Originally Posted by ka mano
...bend over!
Won't be the first time, nor the last.
flycaster is offline   Reply With Quote
Old 07-22-2006, 02:20 PM   #102
Division By Zero
Member#: 7555
Originally Posted by flycaster
Aren't they also the largest distributor for Garrett turbos? (and if that's what you meant, just kick me.)
Haha....yeah that's what I meant. Garrett doesn't really have a wholly owned 'sales' arm. Well, they may own part of ATP or some of their named distributors but I don't think so. Instead, they've set up a network of aftermarket, oem, and various distribution points that they move their product through. Just look at their website and they're all displayed there.
It's a cluster fu*k of a system IMHO. There are too many layers and then those layers end up competing. Nobody can ever beat a distributorís price though if the distributor does not want that to happen. Generally, the distributors don't compete against there customers as there market and opportunity is large enough not to do that. Besides, their built in profit is much higher since they're direct to Garrett. Ultimately, distributors like ATP and Limit can and do guide Garrett in development on new products.
Division By Zero is offline   Reply With Quote
Old 07-23-2006, 11:17 PM   #103
rewt
Member#: 60794
2007 Solstice GXP
I was reading through this thread, and there is a lot of interesting information. After perusing the Garrett site, I decided to run through some of the equations presented on the site to see what turbo I could use to push a 2.0L motor to 500 HP...
Please note: I do not claim that any of these numbers are exact, or that I know what I'm doing. I was just trying to get a baseline of what I would need...
My math:
Wa = 500 HP * 11.9 AFR * 0.55 BSFC / 60 = 54.54 lb/min compressor (minimum)
Req. MAP = (54.54 lb/min * 639.6 * (460 + 130 degrees F)) / (0.92 VE * 7500 RPM / 2 * 122)
= 48.9 psig (34.2 psig)
PR = 3.72
(I estimated BSFC and VE based on information I found on the web, so I could definitely be wrong)
Now, the boost doesn't really bother me, but the PR does. Based on the PR and boost, a GT4088R is the only turbo I could find that would fit the bill. I was originally looking at a GT35R w/.82 AR ex housing, but according to the math, the PR I would need to run would blow up the turbo
What am I doing wrong? I tried to run the Req. MAP equation using a larger compressor, but the pressure ratios got even larger.
rewt is offline   Reply With Quote
Old 07-24-2006, 05:19 PM   #104
rewt
Member#: 60794
2007 Solstice GXP
bump for a response.
Old 07-25-2006, 09:43 PM   #105
shvrdavid
Member#: 86078
2005 Sti
4094R Twin Scroll
Everything looks right accept the Pr, you should have divided by 13.7 or so... The equations are starting points, and usually not right on... Not sure which turbo to tell you to use, I know a 30r .82 will max out at that on a 2.5 (WHP), but I would think you would need a little more on a 2.0... At least a 35r .82 would be my guess..
shvrdavid is offline   Reply With Quote
Old 07-25-2006, 09:53 PM   #106
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
You can play around with these calcs.
http://www.turbofast.com.au/javacalc.html
On a 2.0 engine at 30 psi you would need to rev to 7800-8000 rpm to make 500hp crank. In just about all cases it suggests the GT30/.82 turbo.
Whats interesting is that out of the two calculators I have tried they never suggest using the .63 housing on the GT30 turbos. They go from the GT25 440hp turbo(not a good performer on the Boxer motor) with a big turbine to a GT30 with the .82 and then to the 1.06 at very high boost pressures. FOr example choose 2400 for the 2.5ltr motor, Intercooler yes, gasoline, 24 psi. Then change to 26 psi and so on. Even on the 1.8 ltr motor it does not suggest using the small turbine housing. I ran the numbers on the flow rates of the .63 for turbine flow against compressor flow and the .82 and 1.06. The .63 is really much lower flowing. It points out that the GT series turbos like a big housing and that the turbine wheels themselves are not super high flowing. I compared online to the Mitsu turbos and found the turbine wheels to be larger, higher flowing and using smaller housings. Interesting to see how this works out to reality. THe Mitsu 6H wheel works pretty well in the tiny 7cm housing. Now granted we are all clipping it but it still works pretty well. But this shows how other turbos with a .5 AR and a GT wheel are not working well. Thats pretty much what the data tells us. Sorry off on a tangent.. Lol
Clark
AZScoobie is offline   Reply With Quote
Old 07-26-2006, 01:30 AM   #107
rewt
Member#: 60794
2007 Solstice GXP
is the 1.06 AR turbine housing worth it on the GT30R, or is it pretty much over-kill and only worth running on a GT35R?
Old 07-26-2006, 01:42 AM   #108
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
Originally Posted by PDXTuning
A twin scroll 35r might be the perfect turbo for both high and low end power. Has anyone tried one of these yet?
http://www.atpturbo.com/
CHeers
Tim
I'm actually big on broad power bands and will be looking into the twinscroll 30R...hope to have results within a few months...
building/specing the kit from scratch...
and garrett does make a "dual entry" 35R...
Old 07-26-2006, 02:52 PM   #109
AZScoobie
Member#: 8785
netcom.com
I run the GT35R with a 1.06 housing. I dont think its over kill. Comes on a bit late for my heads and cams. But I like it.
The Turbine housing choices are really there to match to the size of the engine. I have not run the GT30R with a 1.06 housing. My imediate thoughts are that this would work well on a large displacment engine running lower boost pressures. Meaning a V6 of some type. But since I have not tried it on an STI I do not know. I think most people, including me, would rather have the standard 35R with a .82 GT housing.
Clark
Old 07-27-2006, 03:32 AM   #110
silentbob343
Member#: 57307
I was looking at that on ATPs site, keep us posted.
Clark
Clark, was it you, or maybe another tuner on here, whos car was fairly dead below 5K? If it was yours what type of headwork are you looking at and how much will it improve?
silentbob343 is offline   Reply With Quote
Old 07-27-2006, 10:53 AM   #111
Division By Zero
Member#: 7555
I can vouch for the effectiveness of the twin entry. And maybe I'll save the info for another thread, but I converted my GT32 (twin scroll by design) to a 35R compressor wheel and a slightly different compressor cover (.60/AR 3" inlet). 4th gear pulls, starting at 3k rpms makes 22psi in the span of 900rpms. Too bad Garrett hasn't gone further with the GT32, i.e. making it in an "R" CHRA and offering an 82mm wheel for it. Its a great turbo and the turbine wheel is right between the 30R and 35R so its a great compromise. Next step is to fit the 82mm GT40 cover to it. That's where I finish modding this turbo
Old 07-27-2006, 11:38 AM   #112
Homemade WRX
Member#: 33782
96 in the garage
well, hopefully I can get the kit done and on a our shop RS or STi...my 2.0 just won't do it for now
Old 07-27-2006, 01:48 PM   #113
AZScoobie
Member#: 8785
netcom.com
I have big port heads and JDM Cams with a 1.06 AR housing on my Car. It is fairly dead below 5k.. It makes 14 psi by 4400 rpm and full boost (30) around 5200-5500rpm. So yeah. Pretty dead.. But its still making 280whp at 4k rpm Which on this mustang dyno is more then most STI's make tuned out max.
Rule of thumb.. 400+whp STI's gain 50-60whp with cam and slight port work.
Clark
Old 07-27-2006, 04:23 PM   #114
Division By Zero
Member#: 7555
Sounds like another one of those conservative tunes we're always hearing about
Old 07-27-2006, 04:31 PM   #115
AZScoobie
Member#: 8785
netcom.com
Lol.. My car knocks like mad. My breather system was run wrong. The Crank, heads and PCV are all tied together
I am like the hair dresser with the worst hair ever.. The construction worker with a ratty old house. The Detail guy with a Mud covered service truck... ha. I need to spend time on my car and tune but somehow I just dont want to.
C
Old 07-27-2006, 04:49 PM   #116
Division By Zero
Member#: 7555
You forgot the shoe repair guy On a serious note, how the hell did you tie the breathers together LOL (or were you kidding)?
Old 07-27-2006, 07:10 PM   #117
AZScoobie
Member#: 8785
netcom.com
I did not do it. An unnamed mechanic did it. Since its under the manifold I never saw it. It actualy took me a while to trace it all down. Its been like that for a while. I am going to fix that and retune the car with the new UTec software.
Clark
Old 08-15-2006, 12:09 AM   #118
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Default I have a question
So it seems that the GT35R .63 is generally disliked on the ej257 but does anyone have any idea how it would react to a ej207?
WRXRallyBlue is offline   Reply With Quote
Old 08-15-2006, 01:37 AM   #119
Homemade WRX
Member#: 33782
96 in the garage
I imagine in the higher rpm's it would be much happier with much less manifold pressure than the 257 but at a pay off of spool up.
dual AVCS would be a great benefit for this setup...
Old 08-15-2006, 12:40 PM   #120
AZScoobie
Member#: 8785
netcom.com
The 35R .63 is not bad on the 207 but to be honest I would rather have a 30R with .82.
Clark
Old 08-21-2006, 03:56 PM   #121
6foot6
Member#: 111506
WRB STi
Well, it looks like it eill be the .82 on either turbo for me. Now I just have to decide which one. Lots of good info in this thread. I learned a good amount more about turbos just reading it. So, thanks for the info guys. I just don't know if the extra power is important enough for the slight lag of the 35R. Everyone whos has the 35R .82 seems to think the extra wait is worth it though.
6foot6 is offline   Reply With Quote
Old 12-24-2008, 04:30 PM   #122
Dutch Devotion
Member#: 145985
Sorry for awakening the death
I'm building my 2004WRX into a brutal sleeper.
Just installed a full Sti type RA driveline (5MT DCCD) using the 4.444FD incl lsd front and rear (180r).
To complement this setup I'm going to build a 2,5STI engine (probably sleeved) with all jewelry possible into it (8500rev limit)
My goal is to have instant power with best throttle response (hence P&L TMIC like setup)
If I manage to get 450Nm all the way I would be very satisfied.
With all the way I mean 2800-7800rpm.
I know the GT3071R/0.63Ar will strugle to breathe above 6500rpm, but do you guys think it's possible to use the GT3076R (what AR ?) to get the [email protected] still boosting seriously under 3000rpm (1.2bar will do the job at those low revs I suppose ?)
I know the turbo is capable of giving me much more torque, but thats not what I'm looking for. I just like torque being flat all the way giving a lineair power increase towards the end.
Regards
DD aka Erik
Dutch Devotion is offline   Reply With Quote
Old 12-24-2008, 04:52 PM   #123
Swine
Member#: 16197
07 GX470 PearWhite
09 VMAX, 02 BMW R1150r
3076 with a .82 at minimum if you are wanting to be breathing well past 7k rpms.
Swine is offline   Reply With Quote
Old 12-24-2008, 05:23 PM   #124
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Regards
DD aka Erik
First, a 3076.82 will boost at 2k in 4th gear. How much do you want.
second, there's no use in 8500rpms with that turbo.
you won't get 450 nm at 2800. it's a 4 cylinder man.........
modaddict is offline   Reply With Quote
FT perrin gt35r turbo! 4 gt30r .82 Bankaiup Engine/Power/Exhaust 1 11-05-2008 08:09 PM
WTT: gt35r .63 housing for .82/1.06 housing JT's06sti Engine/Power/Exhaust 4 03-21-2008 05:04 PM
V39 vs v30, spool up vs HP & torque manxaru Built Motor Discussion 4 02-20-2008 11:12 AM
GT30R .63 VS GT30r .82 Subiemaddness Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 02-04-2008 01:32 PM
Top End & TMIC: Possible? thebigshow Newbies & FAQs 13 03-29-2006 05:49 PM
