Welcome to the North American Subaru Impreza Owners Club Sunday December 8, 2019
Old 02-17-2008, 12:02 PM   #1
manxaru
Member#: 123021
Default V39 vs v30, spool up vs HP & torque
I am doing a budget build with an EJ257 block, 2.0 JDM heads, FMIC, and a stand-alone ECU with a full custom tune. (FYI- the exhaust is basically straight out of the turbo, no muffler. Intake is just a K&N bolted directly onto the snail.) My goal is be be close to 300WHP, but I'm not trying to go over. Torque and quick spool up is more important than peak horsepower for this build .
I have an option to go with a used VF30 or VF39 turbo. I don't have the budget for a better turbo at this time. I can go with 550cc or 660cc injectors as needed. (I think 550cc is ok for 300whp or under correct?)
If everything else stayed the same, and only the turbo was changed, what's the difference between the VF30 and VF39? Does one spool faster and the other make a little more peak HP? Any other differences? Is there a better VF or other choice I could pick up used for low$$?
Thanks!
manxaru is offline   Reply With Quote
Old 02-19-2008, 03:08 AM   #2
manxaru
Member#: 123021
Need to get my turbo bought.
Can anyone comment on the spool up and flow of the VF30 to the VF39, please?
Thanks!
Old 02-19-2008, 11:26 AM   #3
Turbo_Mike
Member#: 130276
2004 STi
JBP
The spool and the power difference is very minimal between the two. The 30 will spool a couple hundred rpm later than the 39, but make up for it with an addidional 10-15 horse on the upper end of things. Basically really doesnt make much difference. They are very close in size and performance. A VF34 is the ball bearing version of the 30, and that would spool sooner AND make more power than a 39, but again the difference is still only a couple hundred rpm and 10 ish horsepower. So stop worrying about it, buy whichever one's cheaper, and save up for a real turbo when you want to make some real power.
So for what you're asking... VF34 seems like the best choice functionally, and VF39 by the wallet.
Turbo_Mike is offline   Reply With Quote
Old 02-19-2008, 06:55 PM   #4
manxaru
Member#: 123021
Thanks Turbo Mike, that's exactly the info I was looking for.
Small differences = no problem for me, just wanted to make sure there wasn't something significant I was missing.
Thanks!
Old 02-20-2008, 11:12 AM   #5
Turbo_Mike
Member#: 130276
2004 STi
JBP
No problem, have fun with it!
GT35R .63 or GT30R .82? A data-driven debate on spool-up, top-end, & risk of surge ka mano Proven Power Bragging 123 12-24-2008 05:23 PM
HP & Torque graph for STi? Zoso STi Forum Archive 9 06-23-2003 02:19 AM
VF29 vs VF35 spool up QA Guy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-16-2003 07:37 PM
VF34 vs. VF29 spool up rpm Austin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 10-17-2002 08:45 AM
Hp & Torque curves Hayes Normally Aspirated Powertrain 0 10-13-2002 06:59 PM
