Welcome to the North American Subaru Impreza Owners Club Friday December 6, 2019
Notices
Old 04-07-2016, 08:35 AM   #501
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by NSFW View Post
The charts are interesting, but not convincing,
Post 24
Looks like the 3576 spooled (or at least made boost faster), than the 3076.
The big seller for me with the 3576 isn't that spool up is similar, but that it has much lower backpressure (same power on less boost), and also MUCH higher power potential if down the road you want to turn up the boost or run E85.
KillerBMotorsport is offline   Reply With Quote
Old 04-07-2016, 09:41 PM   #502
CatfaceType-R
Member#: 81102
Originally Posted by Scuby04STi View Post
I understand that is the common statement used with these two turbos. But I have yet to actually see it shown with real data. Maybe I'm just not pushing mine enough yet to have found that "choke point" in flow, must be a sign I need to turn it up a tad. Lol
If you come across a link to those back to back tests toss me a PM. Please.
egt will also tell you a lot in this scenario
CatfaceType-R is offline   Reply With Quote
Old 04-08-2016, 01:23 AM   #503
spdracerut
Member#: 269226
The charts are interesting, but not convincing, since this was a catted 3076 versus catless 3576.
Also interesting, but not convincing:
I did say spool similarly, so within 100-150rpm, not the typical 500rpm change when going up a frame size on a 2.0-2.5L engine.
The on/off transient of the GT35 will be slower because the 68mm diameter turbine has roughly a quarter more mass than the GT30 60mm turbine (68/60)^2.
Without a doubt, the GTX3576 will make ~50whp more than the GTX3076 when the turbos are maxed out.
spdracerut is offline   Reply With Quote
Old 04-08-2016, 07:34 AM   #504
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ and hold it longer into the revs, more than making up for and spool differences.
Old 04-08-2016, 08:28 AM   #505
l0ud_sil3nc3
Member#: 423350
Originally Posted by KillerBMotorsport View Post
Post 24
I firmly believe the GTX3576 is hands down the best choice for the FA platform at the moment given the current restraints (HPFP, injectors etc. . .) Should be good for 650WHP maxed out on E85 I imagine once we can get it enough fuel but I bet on pump gas with stock HPFP, injectors it would be a fun setup to say the least.
And this is why I'm saving my duckets for your setup
l0ud_sil3nc3 is offline   Reply With Quote
Old 04-08-2016, 06:01 PM   #506
blurred
Member#: 47143
Originally Posted by spdracerut View Post
The GTX3576R has a better blade speed ratio match between the compressor wheel and turbine wheel compared to the GTX3076R. So, that results in significantly better turbine efficiency which allows the 3576 to spool about the same as the 3076 despite having less turbine pressure ratio to power the turbine. Of course, the bigger turbine frees up a lot of power up top. On the order of 50whp maxed out.
Here's some data from an Evo:
http://www.evolutionm.net/forums/evo...-gtx3576r.html
That's my tuner/builder. Here are some more in-depth posts on the subject from the Honda forums. Some good info in there
http://honda-tech.com/forced-inducti.../#post48062863
blurred is offline   Reply With Quote
Old 05-19-2016, 01:27 AM   #507
Kenmichi
Member#: 329599
2004 STI Aspen White
2015 Jetta TDI
I'm a little late to the party but I'd love to keep up with the latest on the Killer B gtx 3576 build and other similar builds. I've been contemplating what my next step will be with my holy header and this just might seal the deal.
Kenmichi is offline   Reply With Quote
Old 05-30-2016, 11:07 AM   #508
fatman13
Member#: 368465
Has anyone ran this kit with the gtx3576 I would love to see some numbers.
fatman13 is offline   Reply With Quote
Old 05-31-2016, 03:17 PM   #509
MazNJ
Member#: 388661
2013 WRX STI 5Dr
*Crosses fingers*
Doing this shortly. Will post results.
MazNJ is offline   Reply With Quote
Old 05-31-2016, 05:05 PM   #510
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We've sold kits with the GTX3576-R, but they've been to race guys and race guys don't tend to post a whole lot in nasioc, or forums in general.
Originally Posted by MazNJ View Post
*Crosses fingers*
We should have results right before WBM.
Old 07-12-2016, 02:44 PM   #511
Kenmichi
Member#: 329599
2015 Jetta TDI
So your honest suggestion would be, perhaps, a 3076 instead for weekend/street applications? I'd love to, down the line, be able to do more fun things with the car (AutoX for sure) but for now she's just a fun casually driven car.
I just like the potential the 3576 presents but if I'm not going to be maxing it out then maybe it is a waste/unnecessary.
Old 07-14-2016, 02:45 PM   #512
RoadKillDMD
Member#: 284792
2011 STI
Blurple
You'd be best off with the 3067 for your application. With this kit, if you desire more power down the line, it's an easy swap to a 3576.
RoadKillDMD is offline   Reply With Quote
Old 07-15-2016, 11:46 AM   #513
kevmo11
Member#: 403684
2006 sti
cgm
My gtx3576 spoolinator build will done by the end of the month! I'll follow up with dyno results!
kevmo11 is offline   Reply With Quote
Old 07-18-2016, 03:32 PM   #514
CTSparky
Member#: 282204
2011 5 Door STi
Plasma Blue Pearl
Please do. I'm anxious to hear results
CTSparky is offline   Reply With Quote
Old 07-19-2016, 08:41 AM   #515
Joebie
Member#: 270313
2014 STI Hatch
DEEGEE-EMM
In for results!
Joebie is offline   Reply With Quote
Old 07-19-2016, 10:15 PM   #516
kevmo11
Member#: 403684
2006 sti
cgm
Old 07-19-2016, 10:59 PM   #517
ShinjiML
Member#: 257231
2011 STI ShinjiTuned
Originally Posted by kevmo11 View Post
Looks like the link is broken?
ShinjiML is offline   Reply With Quote
Old 07-20-2016, 12:46 AM   #518
laxman2001
Member#: 268558
2008 STi
My 3067 kit with .63 hotside will be installed and tuned early August. Will follow up. Won't be quite as fast as some as I have Invidia headers rather than the awesome killer b ones, but we shall see.
laxman2001 is offline   Reply With Quote
Old 07-20-2016, 08:50 AM   #519
kevmo11
Member#: 403684
2006 sti
cgm
The link works via computer. Can you post pics thru the mobile app?
Old 07-20-2016, 09:49 AM   #520
kevmo11
Member#: 403684
2006 sti
cgm
Ig kevmo1122
Old 07-20-2016, 12:33 PM   #521
spdracerut
Member#: 269226
Ig kevmo1122
I can't even google to your instagram account. Might be some privacy setting or something which is why the picture won't link to NASIOC
Old 07-20-2016, 01:11 PM   #522
Joebie
Member#: 270313
2014 STI Hatch
DEEGEE-EMM
I just searched it on Instagram, worked fine.
Old 07-20-2016, 03:01 PM   #523
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I didn't see a plot. It does look like a spacer was added between the turbo flange and adapter?
Old 07-20-2016, 03:14 PM   #524
Joebie
Member#: 270313
2014 STI Hatch
DEEGEE-EMM
No plot yet from what I saw, but I think he said end of month was the goal.
Old 07-20-2016, 04:13 PM   #525
spdracerut
Member#: 269226
Here's the direct link:
https://www.instagram.com/kevmo1122/
I don't have instagram, so took a little extra effort to find the page.
