Welcome to the North American Subaru Impreza Owners Club Sunday December 8, 2019
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 08-29-2005, 05:58 PM   #1
masubi
Member#: 94769
2005 Baja
Unhappy Baja Interchangeable parts?
Hi everyone,
This is my first post, since I just got my 05 Baja Turbo yesterday. I was curious what parts are interchangeable with other subarus?
Example:????
Engine parts same as WRX?
Exhaust same as?
Headlights same as?
This might make a good cross reference for all the other Baja folks that want to change or mod there cars.
Thanks,
James
masubi is offline   Reply With Quote
Old 08-29-2005, 11:06 PM   #2
Scoobaja43
Member#: 92667
2005 Baja T
Yea im wit u i would also like to know
Scoobaja43 is offline   Reply With Quote
Old 08-30-2005, 12:21 AM   #3
Hawk296
Member#: 14555
1995 Impreza L
Baja
Engine parts: FXT, STI share the same longblock so all things like pistons turbos, headers etc. will work
headlights-2000-2004 outback/legacy and jdm stuff like B4
the car is on the old legacy platform, so things that work on a previous gen. outback (suspension, brakes, wheels) will bolt right up to a baja
interior, andthing for a legacy, shifters are all teh same between 5 speed cars so a wrx short shifter will work on a baja.
any engine, trans, rear diff will bolt right in from across the line. (6 speed baja?)
its a subaru (AKA legos) so there are tons of things that are interchangable
Hawk296 is offline   Reply With Quote
Old 08-30-2005, 02:17 PM   #4
masubi
Member#: 94769
2005 Baja
Default Exhaust
What exhaust fits?
BTW: Thanks for the info so far... Lets keep it going.
James
Old 08-30-2005, 02:19 PM   #5
masubi
Member#: 94769
2005 Baja
You said brakes are same as previous gen outback... So could you use Brembos off WRX?
Old 08-30-2005, 05:02 PM   #6
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
'04 STI brake/hub setup will work also -- 5x100, if you are grabbing a whole setup from a salvage yard -- The '05 STI has a different lug pattern --> 5x114
Seats are interchangable for 2000 forward. Not 100% sure about the new body '05+ Legacy but the '05 STI seats will fit.
'05 STI steering wheels DO NOT fit. I would venture a guess that steering wheels that are not 00-04 Legacy/Baja may not be an easy fit because of the connection to the clock spring on the steering column. Baja has a short wiring tail connected to the back of the airbag but the STI's wire from the clockspring plugs directly in to the back of the wheel.
KYB GR2s rear shocks for the 00-04 Legacy are too short for the Baja, you will ride on the bump stops.
02_Forester is offline   Reply With Quote
Old 08-30-2005, 06:41 PM   #7
masubi
Member#: 94769
2005 Baja
I can't believe they went to 5x114. More wheels to pick from I guess. I would love to get a STI brake setup. I need to start looking for one.
Thanks for the help so far.
Old 08-30-2005, 07:02 PM   #8
mjalex007
Member#: 66022
2005 Baja Turbo
This topic has come up before. There was a list floating around, it's not complete, but a good place to start. Use search to find it.
mjalex007 is offline   Reply With Quote
Old 08-30-2005, 08:26 PM   #9
Hawk296
Member#: 14555
1995 Impreza L
Baja
stis switched over to the different bolt pattern when they got larger hubs, I guess it was a weak point on some 04s.
keep in mind, if you get the 04 sti brake setup you are also going to need wheels to clear those brakes. The bajas 6.5 inch wheels wont clear most big brake upgrades.
Old 08-31-2005, 05:33 PM   #10
masubi
Member#: 94769
2005 Baja
I want to get different wheels anyhow...
Old 09-20-2005, 05:11 PM   #11
masubi
Member#: 94769
2005 Baja
Smile Update - New question
Thought I would just put it under here, since it would help...
What intake and strut tower bars fit on the baja Turbo?
Old 11-05-2019, 09:38 AM   #12
Allwheeldriver1
Member#: 508061
is this the place to post all my 03 baja restoration issues. i am looking to get a parts car (legacy?) and thats why i found this thread. thanks
Allwheeldriver1 is offline   Reply With Quote
Subaru Interchangeable Parts list Darby Newbies & FAQs 194 10-31-2019 11:46 PM
WRX Parts, Baja Turbo Parts (Lots of pictures) uberspeed Engine/Power/Exhaust 42 10-30-2006 02:05 AM
interchangeable parts between RS and WRX Santo Domingo 2.5 RS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-10-2002 12:46 PM
Interchangable Parts between Legacy Turbo and WRX Dealer Xing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-02-2002 02:16 PM
Interchangeable Parts? jaybaroo Interior & Exterior Modification 1 10-14-2001 12:22 PM
