#26 |
Member#: 461913
![]() I would call the dealership to check whether they have a sort of warranty on body rust. I know that major carmakers have 5, 10 years... so why not check.
![]() And yes, wish you luck in fixing this!
#27 |
Member#: 332534
Vehicle:2013 WRX Hatch |
![]() To my earlier point, Subaru acknowledged the issue and agreed to fix it (however I have a call with them today to determine how it would be fixed). They probably did not want to go through the warranty (below) because they would be on the hook if they did a topical fix and did not either replace the door or do an invasive repair (pictured earlier in the thread).
Does anyone agree/disagree this would fall into rust perf. warranty below? My car is new enough that I'd be willing to take them to small claims court. It's ridiculous. So the below is the Rust Perforation Limited Warranty: RUST PERFORATION COVERAGE for all models is 5 years, regardless of mileage. Subject to the exclusions listed in this warranty, defective original body sheet metal panels that are rusted completely through from the inside out (perforated by corrosion) will be repaired or, at the option of SOA or your Authorized SUBARU Dealer, replaced without charge to you for labor and materials. The following items are not covered: (1) rusting of the outside of the underbody (floor pan) or any other part of the vehicle except body panels; (2) rust resulting from alteration of any body panels; (3) rust as a result of damage to paint caused by normal road hazards such as stones or other debris; (4) body panel rust caused by abuse, lack of maintenance, or damage to the vehicle; (5) rust caused by sand, mud, salt, submergence of a body panel in water, exposure to industrial fallout, chemical fallout, tree sap, hail, or other causes beyond the control of SOA; (6) replacement body sheet metal panels and (7) other items listed under "What is Not Covered" (later in this section). Rust Perforation Coverage applies to perforation due to corrosion only. Perforation is a rust-through condition, such as an actual hole in a sheet metal panel. Cosmetic or surface corrosion, such as that caused by stone chips or scratches in the paint, is not covered under this warranty. In addition, SOA or your Authorized SUBARU Dealer reserves the right to decide whether painting the repaired or replaced panel to match the original finish is feasible. SOA will not, under any circumstances, pay for painting the entire vehicle solely to match paint color. Since your vehicle was designed and built to resist corrosion, use of additional rust-inhibiting materials is not necessary and not a requirement for coverage under this warranty. Whether to obtain such additional protection is your decision. |
#28 | |
Member#: 23390
Vehicle:2010 WRX STI SE WRB |
![]() Quote:
Any thoughts on drilling a drain hole on the inside of the door, at the bottom where the inside and outside panels separate? I think I'll try that and flood the cavity with rust stop, via the top hole that holds in the corner of the rubber door seal. Not ready to cut the rust out - looks beyond my bodyworking skills. - Harry |
#29 | |
Member#: 299478
E. Canada
Vehicle:2008 WRX Black |
![]() Quote:
#30 | |
Member#: 23390
![]() Quote:
I just injected two doses of 0.5 oz of rust stop into each front door, from the top corner hole. I'll see how much it slows down the rust. Turns out, the door cavity does have a drain hole - the excess rust stop drained out the drain hole at the bottom of the rear edge of door. - Harry |
#31 |
Member#: 221803
E. Canada
Vehicle:2010 WRX Limited 5DR World Rally Blue |
![]() Any updates from folks who have been pushing SOA/dealers? Seems like a fairly widespread issue.
#32 |
Member#: 202642
RMIC
Vehicle:08 Impreza,80Vette 68 Impala, 15 SantaFe |
![]() This is definitely interesting. My '08 2.5i (that I bought in Nov '07) is showing zero signs of corrosion both inside and outside of the doors. Granted I didn't peel back the black tape. My car has been parked outside since day one but I also live in a dry climate.
#33 |
Member#: 361325
E. Canada
Vehicle:2010 STi Dark Gray Metallic |
#34 |
Member#: 231777
![]() any success with this? I'm having the issue on both sides...
#35 |
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
![]() I would not be surprised if this rust(ing) is being caused and/or accelerated by deicing agents that are being used during the winter months on road surfaces in place of rock-salt, sand and/or equivalent.
#36 |
Member#: 276186
Vehicle:2011 STI stage 2 2012 Odyssey |
![]() My 2011 STi is doing the same thing. Both front doors in exactly the same spot. Really irritating issue on a 6 year old car!
#37 |
Member#: 344486
Vehicle:2013 WRX WRB duh |
![]() My 2013 wax has rust bubble on both sides under the vinyl. 4 years old ;<
#38 |
Member#: 23390
![]() Just got mine fixed. IAG (local tuner shop in MD) body shop ground the rust out of driver's side and covered with epoxy filler, primed and re-applied black vinyl.
Body shop manager thought the rust was happening because the internal channel gets too tight to let factory rust protection to get in there. Repair looks good ![]() I guess I'll just wait and see how it holds up. Harry Last edited by Harry; 01-28-2018 at 08:36 PM. Reason: grammar |
#39 | |
Member#: 221803
E. Canada
![]() Quote:
Mine is getting worse, thinking about getting it repaired. |
#40 |
Member#: 393179
![]() ![]() Same issue on my 2008 |
#41 |
Member#: 325507
NESIC
Vehicle:2010 Impreza 2.5 OBS 2 tone silver |
![]() Any updated on how everybody has been dealing with this issue? Anybody willing to share how much they paid to get this rust fixed?
#42 |
Member#: 23553
Vehicle:2005 STI - Insanity! 2014 WRX - Daily |
![]() I am having the same issue. Doesn't Subaru have a long rust warranty?
#43 |
Member#: 504432
#44 |
Member#: 123843
NESIC
![]() I still think that this can be attributed to winter deicers that are used.
None-the-less: "Rust Perforation Limited Warranty RUST PERFORATION COVERAGE for all models is 5 years, regardless of mileage. Subject to the exclusions listed in this warranty, defective original body sheet metal panels that are rusted completely through from the inside out (perforated by corrosion) will be repaired or, at the option of SOA or your Authorized SUBARU Dealer, replaced without charge to you for labor and materials. The following items are not covered: (1) rusting of the outside of the underbody (floor pan) or any other part of the vehicle except body panels; (2) rust resulting from alteration of any body panels; (3) rust as a result of damage to paint caused by normal road hazards such as stones or other debris; (4) body panel rust caused by abuse, lack of maintenance, or damage to the vehicle; (5) rust caused by sand, mud, salt, submergence of a body panel in water, exposure to industrial fallout, chemical fallout, tree sap, hail, or other causes beyond the control of SOA; (6) replacement body sheet metal panels and (7) other items listed under "What is Not Covered" (later in this section). Rust Perforation Coverage applies to perforation due to corrosion only. Perforation is a rust-through condition, such as an actual hole in a sheet metal panel. Cosmetic or surface corrosion, such as that caused by stone chips or scratches in the paint, is not covered under this warranty. In addition, SOA or your Authorized SUBARU Dealer reserves the right to decide whether painting the repaired or replaced panel to match the original finish is feasible. SOA will not, under any circumstances, pay for painting the entire vehicle solely to match paint color. Since your vehicle was designed and built to resist corrosion, use of additional rust-inhibiting materials is not necessary and not a requirement for coverage under this warranty. Whether to obtain such additional protection is your decision." |
#45 |
Member#: 513599
![]() Is this a common issue on Subaru
#46 |
Member#: 454773
Vehicle:2012 Impreza Sport Pearl White |
![]() My 12 Impreza has it on both doors, you can’t see anything on the outside but the edge of the door has a little rust spot where there is a hole.
The rust warranty only covers perforations (holes) which this is not. |
#47 |
Member#: 512930
![]() Just bought an 09 hatch and both front doors have the bubbling issue. I will def be getting an estimate sooner than later to get it handled smh.
#48 |
Member#: 443545
RMIC
Vehicle:2015 WRX Limited CVT Lightning Red |
![]() It’s like deja’vu. My ‘15 WRX built in May ‘14 is showing almost the exact same issues as my ‘08.
![]() ![]() Wow Subaru, just wow. |
#49 | |
Member#: 15934
Vehicle:2017 Jetta GLI Tornado Red |
![]() Not sure if this applies/helps, but saw this:
https://www.subaru.com/owners/vehicl...ties-2015.html Quote:
#50 |
Member#: 221730
![]() I have the same problem driver side pillar, i can see rust bubbling on the outiside and the inside, telling me its cancer.
I think its cheaper just to replace the door shell? with a salvage door in good shape? like 250-300$ thoughts? rt |
