#1 |
Member#: 486819
Vehicle:2018 STI Pure Red |
![]() As the title states, I have a brand new 18' STI with the neon Brembos. I personally love the color and look, but there are two things that irk me. Number one being the brake dust, which is a simple enough fix, and number two is little rock chips that occur when pebbles bounce off inside of the rim and chip the caliper. Right now it's not bad; I have one little chip but I am looking for something of the same color (or as close as possible) to touch up the calipers.
Anyone have any recommendations and or links for touch up paint?
#2 |
Member#: 485973
Vehicle:2018 WRX STI Red |
![]() I have a Pure Red 2018 too and I was wondering this same question...
#3 |
Member#: 402977
SCIC
![]() I would start at the dealer and ask for a paint code...Subaru hasn’t provided paint codes in the past for calipers or wheels but it is worth a try.
If that doesn’t work go to an auto body/paint shop and have them mix you up something that will match and is high temp to withstand the heat from the brakes. If they mix up 1mL of paint you could do touch ups frequently if so desired There are already threads about the “neon yellow” calipers changing colors to gold after 1 track day similar to the gold brembos changing to brown on the gd models. So depending on your plans for the car either get them repainted/powder coated to any color you want or leave the little annoyance of paint chips there because they might not stay yellow. |
#4 |
Member#: 503611
![]() I just bought a 2018 STi with 15k miles on it and after a couple of days I noticed that the paint was chipping on both of the calipers. Particularly, the inner side of the caliper. Has anyone had this problem before?
#5 |
Member#: 486819
![]() I made this post a while ago, but ultimately the calipers paint has held up really well on mine. I had one or two very small nicks on the tops from wheel removal. I went to the hardware store and found a bright yellow / neon spray paint. Sprayed a good amount on a laminated service and put it on the nick like touch up paint. So far it's held up for months and blended it in.
#6 |
Member#: 98838
SCIC
Vehicle:2005 STi CGM |
![]() Anybody got any update on this? I'm wanting to powder coat my old rear 04-07 STi 2 pot calipers to match the 18+ yellow front I have. Tried to find out some sort of color code for these but no luck so far.
#7 |
Member#: 507120
Vehicle:2019 STI Silver |
![]() Following. I'd be curious to find out color codes for touch ups if needed down the road
#8 |
Member#: 512121
South East
Vehicle:2020 STI World Rally Blue |
![]() Following for later if needed, too!
#9 |
Member#: 239822
South East
Vehicle:2010 WRX pandiculation |
![]() Don't take this as fact, but Porsche uses a color code of '2M8' for their Acid Green. Eyeballing the color looks close, but I have no idea how close it actually is...
https://www.ebay.com/itm/Brake-calip...-/111393483537 |
#10 |
Member#: 496255
![]() I just picked up a set of the 18 STI 6/2 Pot for my 16 rex. The driver side front rotor got scratched by the rim when it was wrecked and totaled.
I have a local Metal finishing shop down the road from me I was going to see if they paint match as I was going to have them re powder coat the scratched caliper. Anyone think reaching out to Brembo would be any good? I know their against 3rd party painting. |
#11 |
Member#: 101117
NESIC
Vehicle:2005 Outback 3.0R Red |
#12 |
Member#: 516299
Vehicle:2019 STI ISM |
![]() Anyone have any luck? I've called my local dealer and they had no clue.
#13 |
Member#: 447001
Vehicle:2014 WRX White |
![]() I don't know if anyone has had any luck finding a good spray paint for these calipers. I looked around and there were some options from the UK and Australia, but nothing that I could find stateside. I think the closest I saw was Rustoleum Key Lime green, but it looks more green than the caliper.
I found two options that look close. ![]() The can on the left is MTN PRO Flourescent Yellow from sprayplanet.com. The can on the right is Fluro yellow from custom73.com. Obviously not caliper paint, but I'm hoping they will still work. I'm not looking to strip/repaint. I'm going try to wet sand the minimum amount to get STI logo off, hoping to retain as much of the color (or at least the primer) underneath the logo. Then spray a light coat of one of these two paints (if necessary), put on the Brembo decals, and cover with a hi heat clear. Should be able to give this a shot this coming weekend. Stay tuned for more pics. If someone has found another option for high temp acid green caliper paint in a spray can, please post. Last edited by atbwrx; 12-17-2020 at 03:03 PM. |
#14 |
Member#: 447001
![]() Found these two contenders at the local Fred Meyers tonight. Both are Krylon. I didn't see either color on the Krylon website. Lucky find.
#15 |
Member#: 447001
![]() Well got a chance to do the test spray today.
Surprised what a difference there was when the paint dried. Coming out of the can, they all looked like they were pretty close. ![]() And here's with the caliper. ![]() The Spray Bike Fluro Yellow from Custom73.com looks like a good match. I'll test spray on the caliper and post. Hoping for a good match. |
#16 |
Member#: 459287
VIC
Vehicle:1998 JDM Impreza STi V4 GF8 White |
![]() I used to think that brake calipers painted red were rather garish... until I finally joined the club. I have to admit though, I still haven't warmed up to neon/fluorescent yellowish-green calipers.
#17 | |
Member#: 431618
SWIC
![]() Quote:
#18 |
Member#: 447001
![]() My plan was to sand off the black STI decals and replace with black Brembo stickers. So I only sanded the raised diamond section on the rears. Everything else is the stock acid green. Will do the fronts later.
The stock acid green is pretty thin. Even being careful with 2000 grit it went through the primer in some spots. I got a chance to spray the Custom 73. It was a little on the yellow side when wet, and, probably because its only 50 degrees out, sprayed on like sand paper. Couldn't get it to lay flat even in a heated garage. ![]() Let it dry overnight, went lightly with the 2000 grit, then hit it with the rubbing compound. Cleaned it up and sprayed over with clear. The clear darkened the tint of the paint and it actually looks pretty close. I'm not going for OCD perfection here, I'm just looking for a color job that after having the brembo stickers put on, will look good from a couple feet away. ![]() Its pretty close, and would be fine for spot touch up I think. The picture makes it look dead on which it isn't so for the perfectionists I think you may still be looking at going to an auto paint store, ordering acid green, and doing the entire caliper. ![]() Last edited by atbwrx; 12-27-2020 at 10:45 PM. |
#19 | |
Member#: 447001
![]() Quote:
But when I opened the box with these, it was like "WOW!". So I thought I'd give it a go. Plus, being on a 2014 WRX Hatch, thought it would be a cool look since they didn't come stock on the car. |
#20 |
Member#: 459287
VIC
![]() Since your WRX is white, any color "clash" should at least be minimal. I'd like to see what the end result on the car looks like. Make sure to post a couple of shots with these calipers installed.
#21 |
Member#: 447001
![]() Here is a quick touch up on one of the front calipers. Sprayed some paint into a container and used a small sponge brush to apply. This shows the color difference before shooting the clear.
#22 |
Member#: 447001
![]() STI Brembos are now WRX ready.
#23 |
Member#: 516299
