Welcome to the North American Subaru Impreza Owners Club Saturday March 6, 2021
Old 05-19-2020, 02:34 PM   #1
Jonnathan
Member#: 4003
2000 RS-WRX
BRP
Default clear coat buffed right off.... what to do
so I have some spots on my old brp paint that are a bit flakey, but now have a new issue.... I had some stuff fixed on the car, but noticed when they polished it up, the clear coat has been buffed right off in a few spots... too thin, or too much polishing, and won't shine anymore...
are there any quick fixes for this ? or does it need a re-paint ?
Jonnathan is offline   Reply With Quote
Old 05-19-2020, 06:25 PM   #2
lefty o
Member#: 512654
2019 wrx
red
there are supposedly some clear coat restorers out there, may help if its a few small thin spots, but most likely long term your in for new paint.
lefty o is offline   Reply With Quote
Old 05-19-2020, 07:19 PM   #3
Jonnathan
Member#: 4003
2000 RS-WRX
BRP
thanks for the info. may try looking for those restorers first...
Old 05-20-2020, 12:06 PM   #4
oichan
Member#: 492327
19 WRX 16 STI
17Mk7R 20Supra 20Forester
If it's a small enough spot with a solid parting line you can do it yourself to paint/clear coat the area. I do it all the time on aftermarket parts including splitters, lips, diffusers, etc. and they turn out very well.
You can source clearcoat rattle cans off the shelf, if not I order from places like paintscratch dot com or similar. The trick for clear is to do one rich coat using the fan nozzle and borderline dripping to get the nice shiny shell. Then after a few days come back with some light compound (if you end up with runs I'd use some 2000 and 3000 grit sanding block to flatten) and smooth it all out.
What were you using to polish the paint? Hope no old t-shirt, compound by hand or using a cotton pad and direct drive.. I only use real mild stuff like ScratchX and either orange or red foam pad depending on the depth of the imperfection, going over it either gently by hand or using random orbital.
oichan is offline   Reply With Quote
Old 05-20-2020, 08:59 PM   #5
subaru_gc8
Member#: 29292
2004 WRX wagon
how do you know the clear coat has been taken off? can you supply pics?
subaru_gc8 is online now   Reply With Quote
Old 08-26-2020, 12:28 PM   #6
Hollums2k
Member#: 518070
Time for a paint job!
Hollums2k is offline   Reply With Quote
Old 08-26-2020, 12:30 PM   #7
JP Chestnut
Member#: 504432
Time for a visit to whoever burned through the clear coat.
So many people watch youtube videos of detailing, get a polisher, and go to town on other people's cars without knowing what they're doing. It's really shocking what some people think they can charge others for.
JP Chestnut is offline   Reply With Quote
Old 09-29-2020, 03:47 PM   #8
veaux
Member#: 518990
vinyl wrap it yourself for less than a grand?
veaux is offline   Reply With Quote
Old 10-11-2020, 10:00 PM   #9
Baru-barage469
Member#: 518883
Seems reasonable
Baru-barage469 is offline   Reply With Quote
Old 10-11-2020, 10:25 PM   #10
Psleeper82
Member#: 519241
2006 foresterHYBRID
GOLDEN ORANGE
was wondering why the off shelf stuff ceramic coat polish helped with normal wear but the scuffs i lightly sanded never got that shine again i have to track down some this clear coat spray and give it a shot
Psleeper82 is offline   Reply With Quote
Old 10-22-2020, 11:32 AM   #11
dr.andras
Member#: 519591
Wrapping can be challenging, usually doesn't look good if the paint underneath isn't in good shape
dr.andras is offline   Reply With Quote
Old 10-25-2020, 10:20 PM   #12
07eye
Member#: 519638
Should try vinyl wrapping a part of the car as a test. See how it looks.
07eye is offline   Reply With Quote
Old 01-12-2021, 11:50 AM   #13
m016324
Member#: 521623
I've had luck with the rattle can clear coat too for smaller areas. I've had good results with both KBS Coatings Clear Diamond Finish and Eastwood 2k. KBS is about twice as expensive but didn't take as much finishing work.
m016324 is offline   Reply With Quote
Old 01-16-2021, 12:36 AM   #14
LouieR503
Member#: 514424
2003 WRX wagon
Honestly a repaint, or a wrap. But with wrapping you have to sand down areas with missing clear coat like that
LouieR503 is offline   Reply With Quote
Old 02-03-2021, 01:20 PM   #15
2017WRXCBC
Member#: 522122
Default nice
oof
2017WRXCBC is offline   Reply With Quote
