Welcome to the North American Subaru Impreza Owners Club Thursday March 4, 2021
Old 08-30-2020, 06:28 PM   #1
Fishie31
Member#: 366436
2020 WRX STI
WR Blue
Default Keeping my forever Subie clean
So I bit the bullet last month and picked up a huge upgrade from my current car. Enter the 2020 STI .
So, I want to start washing my own car again, and apparently I wasn't doing it right forever ago. Plus with my last car I just get the cheaper $10 wash every 2 months or so. Anyhow, I am shopping for supplies with Chemical Guys and wanted to see if I missed anything there:
1. Dirt traps for the buckets
2. Wash mitts
3. Citrus wash
4. Quick detailer spray/drying aid
5. Inner clean
6. Microfiber cloths (2-3)
7. Wheel cleaners
8. Brushes
9. Spray wax?
I am just doing basic washes once every 2 weeks and perhaps a professional detail once every 6 months until I learn enough about detailing to do it myself.
Any thoughts on what I should add/remove? Thanks!
Fishie31 is offline   Reply With Quote
Old 08-30-2020, 07:38 PM   #2
JP Chestnut
Member#: 504432
Check out Larry at AmmoNYC in YouTube for some really practical techniques. Check out Matt at Obsessed Garage for maximal, often unnecessary, fussiness.
JP Chestnut is offline   Reply With Quote
Old 09-03-2020, 03:12 AM   #3
ProjectN64
Member#: 454737
2005 STIpsm
2013BRZswp2017IMPREZAlrp
Get a claybar to decontaminate when after a wash you still feel gritty paint,foam pads to apply waxes by hand (you'll still get very good results without a machine) get a polish with very low abrasives, I've had good luck with "meguiars ultimate polish", then you need a good sealant to protect all the hard work after a thorough detail which I'd recommend "wolfgangs sealant" very good and worth the price. As for interior I hate glossy finishes that might even leave a greasy feel, I suggest "meguiars quick interior cleaner" for dashboard,door panels, and steering wheels. Make sure you get some weathertech floor liners too I have them in both my cars and they're definitely worth. Good luck
ProjectN64 is offline   Reply With Quote
Old 10-03-2020, 08:31 PM   #4
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Since it’s your forever subie don’t forget to rust proof it so your hard work in keeping the paint clean isn’t for nothing when it starts rusting holes through the paint in 10 years.
Fluid film will slow it down significantly assuming you are somewhere they salt.
https://m.youtube.com/watch?v=2yT69lYcEtE
DieselDorf is offline   Reply With Quote
Old 10-04-2020, 12:42 AM   #5
subaru_gc8
Member#: 29292
2004 WRX wagon
you can either get the ppfed or just ceramic coat it. it will make it alot easier to clean when you need to
subaru_gc8 is offline   Reply With Quote
Old 10-05-2020, 01:58 AM   #6
Fishie31
Member#: 366436
2020 WRX STI
WR Blue
Thanks. I got Weathertech immediately after I brought the car home. I also ppf'd the entire front end since that usually has the most impact. Going to buy some stuff from Chemical Guys soon.
Thank you all for the recommendations.
Old 10-06-2020, 09:40 AM   #7
D-rock240
Member#: 284221
2011 WRX GV SSM
2013 MacLeod
Originally Posted by DieselDorf View Post
Since it's your forever subie don't forget to rust proof it so your hard work in keeping the paint clean isn't for nothing when it starts rusting holes through the paint in 10 years.
Good advice for the rust belt, OP is in So Cal
D-rock240 is offline   Reply With Quote
Old 10-06-2020, 10:17 AM   #8
sluflyer06
Member#: 111641
2020 CWP STi
RIP - 06' WRX w/ 6spd
Citrus wash is a stripper, I would only use that before you wax or apply any kind of ceramic, etc. For normal washes a neutral pH/something gentle or you'll strip the wax right off every time you wash it.
I'm about to try a product called "the last coat" on my 2020 STi, its a @home ceramic that get's good reviews, with about a 6 month life. Otherwise I use a touchless 1/4 mile from my house for standard washes, dry it myself with griots drying towels, and hand wash wheels and calipers frequently. After drive I'll use speed shine (quick detail spray) to remove any bugs on the front, and use your window cleaner of chocie. I like Griot's ultra premium aersol glass cleaner with their 2 sided cloth.
sluflyer06 is offline   Reply With Quote
Old 10-06-2020, 12:24 PM   #9
oichan
Member#: 492327
19 WRX 16 STI
17Mk7R 20Supra 20Forester
For me, the cars I am preserving long term do not use a hose to wash. I only use waterless wash at best if not just QD after a drive on a dry day.
Even on my daily driver (WRX) unless filthy dirty with mud or salt, I do not pull out my hose and just use waterless wash. It is far easier to work with than pulling out my hose (even though I have those Rolls Royce of a hose and reel by Eley) equally less damage to paint using proper 2 bucket wash, and no risk of water or soap stains.. and keeps the inside of doors and nooks all dry.
I use the Griot's SprayOn Car Wash, but there are other products out there that work about the same. I use dedicated fluffy MT towels and follow up with a quick mist and wipe (polymer based Prima Hydro) to reinforce the polymer on the paint and glass, all seals. It goes by very fast.
oichan is offline   Reply With Quote
Old 10-06-2020, 01:37 PM   #10
JP Chestnut
Member#: 504432
Originally Posted by sluflyer06 View Post
For normal washes a neutral pH/something gentle or you'll strip the wax right off every time you wash it...
Otherwise I use a touchless 1/4 mile from my house for standard washes...
If you care about PH neutral washing, I'd skip the touchless
Originally Posted by Internet
When operating touchless wash systems, it is especially important for equipment to use chemistry specifically developed for touch-free cleaning. Chemical solutions for touch-free cleaning can include stronger acids and alkaline chemicals as well as different surfactant chemistry to overcome the wash’s absence of friction.
https://www.carwash.com/touch-free-carwash-chemistry/
Old 10-06-2020, 05:15 PM   #11
sluflyer06
Member#: 111641
2020 CWP STi
Yes, I'm actually aware touchfree uses a mix of high and low ph soaps to do what they do, unfortunately working full time and I have a toddler and a baby on the way, my time is finite. Before we had a kid I religiously hand washed my cars, ironic now that we have a house with a garage, I don't often have the time to spend 60 minutes washing the car 1+ times a week, when there is a really good touchless 1/4mile from my front door. I'm going to be trying a ceramic product soon and they claim it will hold up ok to it, probably will re-apply every 6mo.
I said what I said just so that OP knows, citrus washes are typically used to prep for wax/seal applications.
Old 10-07-2020, 01:13 AM   #12
splash_runner
Member#: 517952
2020 WRX
MGM
cost for their micro fiber towels. such a good deal and imo very high quality.
splash_runner is offline   Reply With Quote
Old 10-07-2020, 05:56 PM   #13
Aoshi1
Member#: 519147
2005 WRX STI
Aspen Silver
Great tips, these are all good advice, especially clay bars.
Aoshi1 is offline   Reply With Quote
Old 10-14-2020, 10:11 PM   #14
wilmington_steve
Member#: 519343
2016 WRX
I just recently applied McKee's 37 daily driver ceramic coating to my WRX and my wife's Forester. It states it lasts up to 3 years and was fairly easy to apply. It took me about 5 hours to do the job by myself. I would recommend 4 additional microfiber towels. The two they provided were not enough. I would also recommend waxing it after the next wash as well. There were enough materials in the kit to do 2 vehicles.
wilmington_steve is offline   Reply With Quote
Old 10-15-2020, 02:12 PM   #15
oichan
Member#: 492327
19 WRX 16 STI
If on a lighter colored car you can get away with Mother's Clay2.0 (I think it was called). It's a synthetic clay pad. I just use distilled water as lube and clean contaminants off my white WRX (daily driver).
It's super easy to use and just rinse the tool with water after you're done, no need for gloves or anything.
On darker colors I use Griot's clay as it is super soft. Synthetic clays can marr the finish and leave ghostly holograms... If you're going to polish your car no big deal, but I like to keep my steps and process all simple. With Griot's clay you'll want to wear disposable gloves and use their SpeedShine QD as lube.
Old 10-16-2020, 10:30 AM   #16
lisprost
Member#: 519328
Default Nice
It looks great!
lisprost is offline   Reply With Quote
Old 10-16-2020, 01:55 PM   #17
Fishie31
Member#: 366436
2020 WRX STI
WR Blue
Yeah, I realized that after I posted that. I think I am going to check out Adam's stuff and getting a foam gun as well.
Thanks again for all the tips and tricks y'all. Maybe if I get really good at this I can start doing my own detailing since I have more time now while working from home.
