#1 |
Member#: 31900
![]() I just installed a 1820 and now it is time to drive it, how should I go about "breaking in" the new turbo? I don't really have any idea of how to. If I break it in like the motor break in says to the turbo will not really have time to spool. So I'm not sure if I should do that for a little bit, then up it another 1000 rpm for 100-200 miles, and so on till it has gotten a few hundred miles on it.
ThankS for your help MCL
#2 |
Member#: 34672
Vehicle:2003 wrx WR Blue Pearl |
![]() You don't need to break in a turbo.
Breaking in a motor is done to let the rings seat properly. There's nothing in a turbo that needs that kind of attention. Just drive. |
#3 |
Member#: 23676
NESIC
Vehicle:. |
![]() Is htis true? I just installed a VF22 today and I want to be sure before I go boosting my brains out
![]() So is it true? turbos done need a break in period? I would think they wouldnt, or very minimal if any. |
#4 |
Member#: 31216
Vehicle:03 GDA |
![]() heffergm is right, there is no need to break in the turbo. Feel free to go boost your brains out man.
#5 |
Vendor
Member#: 20483
![]() Hmm I suppose that's a matter of opinion. Turbos have seals as well. I would recommend running lower boost for a short period of time using short bursts. Well, that's what I heard from FP a long time ago. I wouldn't think it would really take long anyways. It will depend on your type of turbo I suspect (bearings and seals).
Mark www.Quantum-Racing.com |
#6 |
Member#: 14141
Vehicle:2002 Impreza WRX |
![]() The other issue is to pre-oil the turbo the first time you start the car after the new turbo is installed.
Remove the cam and crank sensors so the engine will crank without running. Crank the engine for 10 - 15 seconds ( 2 or 3 times for 5-7 seconds so you don't overheat the starter). That will force pressurized oil up to the new turbo and push any air bubbles out of the bearings. Put the sensors back on and go driving. Larry |
#7 | |
Member#: 23676
NESIC
Vehicle:. |
![]() Quote:
Pulled the ECU fuse ![]() |
#8 |
Member#: 4811
NESIC
Vehicle:2014 Focus ST NESIC track Ho #35 |
![]() as far as break in goes- Deadbolt included a little "break in" clause saying to take it easy without full, prolonged boost for the first 250miles
speed safely Brian ![]() |
#9 | |
Member#: 4181
Vehicle:2003 Lancer Evo 8 It's Blue, ok? |
![]() Quote:
#10 | |
Member#: 22135
Vehicle:17 WRX World Ralley Road Rash |
![]() Quote:
#11 | |
Member#: 23676
NESIC
Vehicle:. |
![]() Quote:
how do I have stage 4 if I dont have a utec? ![]() ![]() ![]() |
#12 | |
Member#: 3357
Vehicle:2002 WRX Black |
![]() Quote:
new turbo break-in prior to protune? | redrexmeister | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 08-03-2009 10:02 PM |
question about new turbo break in | gero704 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 04-29-2009 12:07 AM |
turbo break in? | dan avoN7 | Newbies & FAQs | 6 | 03-26-2004 01:38 PM |
Turbo break-in worthwhile? | pace | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 04-28-2002 01:00 PM |
Turbo break in... | DeliciouSpeed | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 09-14-2001 02:28 AM |
