10-26-2004, 12:02 AM | #1 |
Member#: 53774
SCIC
Vehicle:1995 Impreza Dirty. |
transmission compatability question
i need to know if a 1995 wrx transmission will work a 02wrx. is the diff compatable? i know there are four holes/studs on the old transmission and eight on the new but will they mate??? thanks in advance.
10-26-2004, 12:34 PM | #2 |
Member#: 4800
TXIC
Vehicle:1990 Legacy & OB XT AWD 6MT EJ22T AWIC Swap |
The center gear reduction will more then likely be different then the USDM 02+ WRX's, and not have the 1:1.1 stepper. So you will need to find a rear diff with the appropriate final drive ratio to match whatever the 1995 transmission had.
10-27-2004, 11:24 PM | #3 |
Member#: 34929
Vehicle:2004 sti 07 Lexus Breakwater Blue |
trans
does it have a dccd?
if yes-all the ver.4 with dccd I-I-I have delt with have been 4.44. it will bolt-up to the 02 engine and do just fine. before installing trans put a 10x1.25 helicol in hole where the lower starter bolt goes-then use a short bolt on the bottom to hold the starter in place. |
11-09-2004, 08:08 PM | #4 |
Member#: 74223
Vehicle:1995 impreza |
No it does not have dccd.
11-16-2004, 06:14 PM | #5 |
Member#: 53774
SCIC
its just a regular wrx trans. my main question is if anyone knows what the final drive on the jdm trans is???
Legacy GT transmission compatibility question.. | Roundabout | Transmission (AT/MT) & Driveline | 3 | 06-28-2008 08:29 PM |
transmission compatibility | homestar_kevin | Transmission (AT/MT) & Driveline | 10 | 03-05-2008 09:29 AM |
Impreza transmission year/compatibility questions. | Blugin | Transmission (AT/MT) & Driveline | 7 | 04-10-2003 04:20 PM |
RS/WRX transmission compatability | d00f | Transmission (AT/MT) & Driveline | 0 | 12-16-2001 12:02 PM |
