04-07-2002, 10:16 AM | #1 |
Member#: 12536
Vehicle:1999 forester GT 2.0 Turbo, green |
installing a limited slip diff,how hard??
is installing a rear LSD difficult???i mean,do you need technical know-how to do it,or is it a 'take one out,put one in' mod like brake pads???any special tools required??any instuctions anywhere??am i in over my head??
04-07-2002, 01:18 PM | #2 |
Member#: 6000
Vehicle:2000 GC8 STi V4 swap BRP |
Yourself with the proper tools and no lift should be able to do it in about 2-3 hours.
You will need a pile of metric sockets jacks and jackstands. Jack it up, pull a tire off. Pull the long bolt from under the hub out. It's about 12" long and goes front to rear, it holds the rear suspension to the bottom suspension arms. I found it easier to drop the entire rear suspension assembly. You may need to remove the exhaust from the midpipe back. Pull the plug from the diff and drain it. Unbolt the guard from the diff and unbolt the driveshaft and let it hang down. Remove the 2 bolts on the rear assembly. Remove the rest of the bolts holding the diff on the assembly (4 on the bottom). Pull the suspension you removed the longbolt from out from the car. This will pull the driveshaft from the diff on one side. It's a snap in affair so it may take some rubber hammer tapping. Push the diff forward to clear the 2 bolts on the top rear from the rear suspension assembly. It will fall down and you will have to give it a few taps to get the other rear axle out. Installation is the reverse of this, but make sure you snap in the axles properly otherwise they're going to leak and they won't be engaging the LSD unit inside the diff. So as you can see it's not so simple, but not impossible. -Michael |
04-08-2002, 04:53 AM | #3 |
Member#: 12536
thanks for the great reply/instructions this task sounds almost doable with your directions.ill post when its done
04-09-2002, 07:26 AM | #4 |
Member#: 8167
Vehicle:2001 ForesterS-Turbo Premium Silver |
Okami, doesn't your forester have an LSD as standard? Mine does.
Toerag |
Viscous limited-slip diff. question | SubaruImpreza_power | Transmission (AT/MT) & Driveline | 6 | 05-28-2002 01:53 PM |
Front limited slip diff??? | wrx182 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 09-28-2001 01:35 PM |
('93-'01) Stock rear limited slip diff. | brandon | Impreza Forum | 14 | 06-10-2001 09:28 AM |
limited-slip diff confusion | Benjamin Tang | Legacy Forum | 22 | 05-08-2001 12:52 AM |
4.444 Limited slip diff | byb555 | Normally Aspirated Powertrain | 8 | 10-26-2000 12:17 AM |
