Welcome to the North American Subaru Impreza Owners Club Thursday June 21, 2018
Old 09-20-2002, 07:19 PM   #1
Satellite
Member#: 18249
1995 Legacy
Steel Grey Metallic
Question KYB AGX and H&R Springs
Will this setup give me an level or close to level looking stance? I would really like the front to have the same tire to fender distance as the rear. I realize the front fenders have a larger arch, but I'm sure someone knows the right combination to making it look the same. Thanks for any help. Also, if I go with the AGX's, which I plan on, I've been searching the forum and I see to order 9x-01 Impreza AGX's, do I need to change any parts on my car to accustom these?
Satellite is offline   Reply With Quote
Old 09-21-2002, 05:00 PM   #2
noahr
Member#: 15434
98 legacy gt
caucasian
i just put agx's on with my eibach's and the car actually sits higher than it did before with the stock struts due to the spring seat heights. i will try and get some pics for you tomorrow. the car does not sit very low and has a nice, stiff ride. if you have not ordered the springs yet, would you consider ordering some whitelines and trading me for the eibach's? i love the springs but i want the car to sit a little lower.
noahr is offline   Reply With Quote
Old 09-21-2002, 08:24 PM   #3
Satellite
Member#: 18249
1995 Legacy
Steel Grey Metallic
sorry, i don't want to make my car higher, i really want it to be lower.
Old 09-21-2002, 09:29 PM   #4
mtnbkrcr
Member#: 5715
2001 2.5 RS
we install H&R and KYB on my bosses Legacy and it looks awesome. Sorry no pics. It is very level, however the front fender gap is bigger than the rear.
mtnbkrcr is offline   Reply With Quote
Old 09-22-2002, 03:58 AM   #5
legacyej22
Member#: 23385
I will be installing H&R's on my legacy Sunday, I'll let you know how it looks. Just slapped the WRX wheels on, looks awesome. It should make my car level because mine is FWD and isnt as heavy in the rear, so it wont lower it the full 1 inch. We'll see, I'll be sure to have pictures up as soon as my bumper gets back on.
Peace
Josh
legacyej22 is offline   Reply With Quote
Old 09-22-2002, 06:14 PM   #6
biggreen96
Member#: 12535
Low 06 5MT OBXT
92 EG33 Legacy Rally Car
Most of the pics of all the combos I have seen have the front still higher than the rear, I would suggest Ground Controls. The GC8 kit will work on our cars. Combine those and some AGX's and your Legacy will have a setup second to only Teins, cusco, JIC.
biggreen96 is offline   Reply With Quote
Old 09-23-2002, 01:03 AM   #7
2WD Bites
Member#: 19349
1999 Legacy GT Ltd
Black Granite Pearl
Default AGX's and Eibachs...
[IMG]http://groups.msn.com/_Secure/0NwAHACAStNdtTPwMidA6sra1GM3*0ys4t0P3izFNvT8VA*oUu WHeT*YW9w5U4EjS1fdKyqB*NPTnEr!xD4fD6w/DSCF0009.JPG[/IMG]
Sorry don't have the H&R's but this is the Eibach Pro Kit Drop and the AGX's.
2WD Bites is offline   Reply With Quote
Old 09-23-2002, 08:43 AM   #8
NICO TURBINE
Member#: 15445
1986 Leone STi EJ22T
JDM White
i have agx and eibach pro kit in an the car sits fine. i also had to use the spring plates that you get from the dealer 4 a impreza. my car sits lower in the front becuse i gutted the hole car out.
1 a/c is out all off it even in the car
2 power sterring is out
3 abs is out
4 in the car the carpet that was still wet from winter and it was summer and the carpet was soaked and i could salt my drive way 2 times becuse there was chunks off salt billed up under it
5 the tar black stuff under the carpet is out i thinks called sounddeffener
6 the hole trunk has nothing and i mean it just subaru factory paint in the trunk and the jahke
all in all the car is lower and it sits very nice i had that problem when i sarted out
NICO TURBINE is offline   Reply With Quote
Old 09-25-2002, 10:14 PM   #9
noahr
Member#: 15434
98 legacy gt
caucasian
what i meant was that the eibach's lowered the car farther than they advertised (1.7 or so inches) and the kyb's brought the car a little higher, but still significantly lower than stock. the h&r's will lower the car nicely and evenly with the kyb's but if you want the car really low, it probably won't satisfy you. the ground controls for the gc8 probably won't have a high enough spring rate for the legacy. the eibach/kyb setup lowers the car a little over an inch all around. if you can afford it get coilovers.
Old 09-25-2002, 10:18 PM   #10
subarugt
Member#: 11053
99 Legacy GT LTD
Rio Red
With the KYB AGX's you want to make sure you do not lower them a lot since they are really designed to run close to stock height. I have heard of some problems when using them in combo with springs that lower more than an inch.
subarugt is offline   Reply With Quote
NYC: Feeler FT KYB AGX shocks/H&R springs/GroupN top hats combo for rs suspension Flat4TW 1993 - 2001 Impreza Specific Parts 14 10-23-2009 02:33 AM
KYB AGX Struts H&R Springs Aspenrex03 SCIC Private Classifieds 6 10-17-2007 12:23 PM
02-03 KYb AGX w/ H&R springs cypha25 Private 'For Sale' Classifieds 14 05-17-2005 05:51 AM
KYB AGX & H&R springs SubaruPreza Brakes, Steering & Suspension 2 04-28-2003 12:07 PM
KYB AGX on H&R springs Steven Saunders Brakes, Steering & Suspension 5 09-26-2001 04:30 PM
