Welcome to the North American Subaru Impreza Owners Club Tuesday June 19, 2018
South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 01-31-2005, 09:35 PM   #1
me_and_my_wrx
Member#: 45198
'07 Outback
Default Help me figure out what is wrong??!?!
So I had this really loud noise after doing some work:
see here : http://forums.nasioc.com/forums/showthread.php?t=708733
Now I've tightened everything and can't find a leak, but my car is now louder than it was before......sounds just like one of those whistles you get from the quarter machine that looks like a jet engine " wshhhshshhshshshshhhhhhhh....." only with maybe a metallic sound built in, and I'm not building normal boost, but I think that may be because of the freshly reset ECU, because I still got 15psi in 5th on the ride home, normal max boost is 16.5-17 psi. I didn't fiddle with the pcv valve because it looked good, but I loosened the intercooler and retightened everything. I didn't pull it all the way back off. Could the OEM Y-pipe crack at all? It was cold when I was putting it back on. What does a 'bad' turbo sound like???
me_and_my_wrx is offline   Reply With Quote
Old 01-31-2005, 09:44 PM   #2
2pt5RS
Member#: 10853
2013 BRZ LTD
Satin White Pearl
uppipe gasket leak?
2pt5RS is offline   Reply With Quote
Old 01-31-2005, 10:00 PM   #3
WJM
Guest
Member#:
ummmmmm.........loose nut behind the wheel?
Might want to check the boost fluid.
Old 01-31-2005, 10:06 PM   #4
billzebub
Member#: 40248
2003 WRX
Midnight Pearl (black)
Originally Posted by 2pt5RS
uppipe gasket leak?
What is described sounds exactly like my uppipe gasket leak. Scared me so bad I thought my turbo was toast and ended up buying one from deadbolt.
billzebub is offline   Reply With Quote
Old 02-01-2005, 08:18 AM   #5
me_and_my_wrx
Member#: 45198
'07 Outback
hrmmm, I re torqued everything last night,and it seems worse, I'm going to pull the intercooler off and investigate the y-pipe tonight. It is a loud whistling whirring sound, a leak of some sort is what I suspect, but gawd is it scary sounding.
Old 02-01-2005, 08:40 AM   #6
crazyhorse
Member#: 19502
2010 Impreza with no
scoop. =(
If it blew the gasket out torqueing it down isn't going to help...
Check your EGT and O2 sensors... one of them might have backed out a bit.. that'll do it every time.
crazyhorse is offline   Reply With Quote
Old 02-01-2005, 10:13 AM   #7
Templar
Member#: 483
2010 RSV4
Aprilia Racing Black
You could also check the welds on the Up pipe. We recently had a car with an older Perrin up pipe come in that one of the welds had cracked on.
Templar is offline   Reply With Quote
Old 02-01-2005, 11:49 AM   #8
me_and_my_wrx
Member#: 45198
'07 Outback
I guess I'll have to look at those gaskets then. It just seems weird that I would have no problems at all, then all of a sudden after taking the IC off to change the PCV valve and bleed the clutch that this would happen. HappenStance.......sorta like a circumstance that just happened.
Old 02-01-2005, 11:57 AM   #9
thrdeye
Member#: 24569
2004 Mazda RX8
Titanium
Steve,
Gimmie a call and we can meet up and look/listen at it.
thrdeye is offline   Reply With Quote
Old 02-01-2005, 12:01 PM   #10
crazyhorse
Member#: 19502
scoop. =(
Check the sensors first
Old 02-01-2005, 12:51 PM   #11
me_and_my_wrx
Member#: 45198
'07 Outback
Chris, I'll give you a call tonight.
and I'll check the sensors again.
Old 02-01-2005, 07:57 PM   #12
dropmech
Member#: 41477
2006 Tahoe that
will pull your bumper off
I had the same sound and it ended up being a lose DP/turbo connection.
dropmech is offline   Reply With Quote
Old 02-02-2005, 09:05 PM   #13
DeadBolt Enterprises
Vendor
Member#: 34272
2005 STi
Crystal Grey
Just curious, did you use the factory stamped brackets that brace the turbo/uppipe to the block? I have seen on a couple of cars (including our race car) where the uppipe was not a really good fit with the stock stamped bracket. We installed everything, then when we tightened down the bolts on that bracket it pulled the uppipe upwards just enough to cause a leak. We would up having to use a 1/8 inch thick washer underneath the bracket to shim it up so that it would not pull the uppipe out of place.
DeadBolt Enterprises is offline   Reply With Quote
Old 02-03-2005, 10:23 AM   #14
me_and_my_wrx
Member#: 45198
'07 Outback
Yes I did use the factory brackets, and I used factory gaskets coated with a heavy amount of copper spray(I love that stuff) . The setup has been fine for a good 4 months now. I'll look at the bracket and see. When I installed it all I loosened the turbo, then tightened the up pipe to the turbo, then tightened it to the manifold, torquing in a sequence gradually increasing till tight. I then bolted on the downpipe and the rest of my exhaust. I really think it is the OEM y-pipe(Putting it on the pry tab closest to the turbo snapped off) So I've got a friend who has an extra I'm gonna slap on, I'l keep you all posted.
Built Motor Inside? Help me figure out what is in my motor! turboge Built Motor Discussion 24 02-10-2010 01:21 PM
My car is at Exeter Subaru, and they cant figure out what is wrong with it. Thoughts? RChampion New England Impreza Club Forum -- NESIC 32 03-03-2008 03:15 PM
Wagon Owners' Help Me Figure Out what is going on. Erconcepts Brakes, Steering & Suspension 9 04-14-2007 01:57 AM
Need help figuring out what is wrong with car roybfr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-17-2006 01:06 PM
help me figure out what this noise is Canadian 2.5RS Normally Aspirated Powertrain 5 03-08-2003 11:11 AM
