07-02-2007, 01:18 PM | #1 |
Member#: 58131
NWIC
Vehicle:05 STi 6,879 miles 04 Forester XT |
V8 6 speed into 1998 OBS questions
I'm about to install the 6 speed into my 98 OBS and would like to know run through a list of items to find out what else I will need prior to tearing the car down to find out I'm missing something.
The facts: Car: 98 OBS 5 speed, completely stock w/ 3.9 ring and pinion in the rear differential according to info I found on Nasioc for stock 98 2.2l 5 speed Imprezas. Transmission: JDM V8 6 speed 3.9 ratio and w/ 6 speed tranny mount Driveshaft: V8 6 speed driveshaft Clutch: Stock V8 that came with the tranny Flywheel: Stock V8 that came with the tranny Pilot Bearing: Stock V8 that came with the tranny Release Bearing: Stock V8 that came with the tranny Front Axles: Stock WRX with the female ends (tranny has the stubs) Front Hubs: Stock WRX From what I've read around here I'll need 4 quarts of tranny fluid. It also appears fluid brand is highly debated so we'll skip that portion of this discussion. We'll also skip DCCD discussion as I will be installing an aftermarket DCCD controller at a later date. I believe the parts listed are the heavy hitter parts I will need to install this into the car. I intend to install JUST these parts for the purpose of getting the 6 speed into the car, functionally running. (I have all of the remaining STi driveline parts short of the calipers and rotors which I am still undecided on, so the rest of the parts will be installed later.) The clutch and flywheel appear to be in functional condition to get me down the road. I will probably be replacing the input bearing and release bearing. 1) Will the 98 OBS starter bolt on to the 6 speed transmission and will it function correctly with the 6 speed flywheel or will I need to source a starter from a WRX? 2) Will the factory clutch slave cylinder bolt up to the 6 speed and function properly? 3) Is the factory 98 OBS pitch stop mount the same length and a direct bolt in when using the 6 speed? 4) I'm currently looking through the commonly known online wiring diagrams for the 6 speed as well as for the 98 OBS to see what I'm looking at for wiring. What else am I missing?
07-02-2007, 01:36 PM | #2 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
if you are still unsure about the diff ratio take off the cover its stamped in the ring gear
07-02-2007, 02:56 PM | #3 |
Member#: 29201
NESIC
Vehicle:BMW M3 Honda S2000x2 |
You will need the STi shift linkage. Its a different length and has the reverse lock out.
07-02-2007, 06:22 PM | #4 |
Member#: 141232
NESIC
Vehicle:02 v7sti wagon signal green |
The 98 OBS is a cable clutch. You will need a hydraulic pedal box .
07-03-2007, 07:59 PM | #5 |
Member#: 58131
NWIC
07-03-2007, 10:46 PM | #6 |
Member#: 29201
NESIC
The starter should bolt right up and work fine with the STi flywheel. I think I have an STi starter in my 5-speed RSTi.
07-03-2007, 11:22 PM | #7 |
Member#: 177
NWIC
there was a hydro clutch swap kit in the gc8 classifieds today
07-09-2007, 02:35 PM | #8 |
Member#: 58131
NWIC
back up top
I've purchased a pedal box and clutch master cylinder assembly so I should be back on track.
Are there any electronics surprises I should be planning for? Does anyone else have anything to offer? Any tips? Tricks for hoisting that large tranny up into the car? |
07-10-2007, 01:38 AM | #9 |
Member#: 36333
NESIC
Vehicle:98 RS GT30R, closed deck madnes |
07-10-2007, 10:59 AM | #10 |
Member#: 153626
Have a nice deal. thanks.
07-10-2007, 07:36 PM | #11 |
Member#: 66739
Vehicle:2002 WRX wagon silver |
yep RS and iirc the forester(just the 2.5l equipped/LSD models).
--keith |
07-11-2007, 01:36 AM | #12 |
Member#: 56345
Vehicle:1997 OBS Primer Grey |
07-12-2007, 09:51 AM | #13 |
Member#: 66739
i was gonna say impreza based chassis, and that'd kinda exclude the leggy, but didn't for some reason. anything with 2.5's seems to have hydro clutch and cable for 1.8/2.2l. but im aware of the leggy being hydro.
--keith |
V8 6 speed into 97' LGT - Which drive shaft? | morrocco88 | Transmission (AT/MT) & Driveline | 12 | 09-23-2009 11:21 AM |
JDM V8 6 speed with Brembo 2999.00$ USD | Lachute Performance | Drivetrain | 19 | 06-23-2009 01:48 AM |
2 questions about an STI 6 speed into an '02 wagon | Cyclops | Brakes, Steering & Suspension | 17 | 04-04-2008 04:03 PM |
Sti 6-speed into a GC questions??? | handyRS | Transmission (AT/MT) & Driveline | 0 | 06-13-2007 02:43 PM |
STi V8 6-speed and engine | Butt Dyno | Private 'For Sale' Classifieds | 2 | 09-12-2003 07:08 PM |
