06-21-2017, 12:47 PM | #1 |
Member#: 35944
South East
Vehicle:'03 EJ257/EFR/G4+ MBP |
Ej207 - GT30r Dyno 368whp
Event: dyno
Location: WPB, FL @ Pro's Tuning Ambient Temp: ~85 Elevation: 0 Weather: sunny Car: 2003 wrx Dyno Info: Mustang Transmission: 2004 sti 6 speed drivetrain Gear: 4th Peak HP at RPM: 367 @ 6700 Peak Torque at RPM: 310 @ 5800 Baseline hp/tq for a stock on same dyno: unknown Target Boost: 21 psi Fuel: pump 93 Engine/Power Modifications: stock v7 Ej207 engine rotated Gt3076r .82 Tial housing IAG uppipe/downpipe, GT Spec manifold all ceramic coated APS fmic Reverse IM coated Killer B upper coolant reservoir and overflow GS MBC/EBCS ID 1000's, Walbro 255, stock lines/rails Link G4+ ecu Innovate MTX-L Tial MVR Tial Q bov 2004 USDM 6sp transmission, flywheel, R180 oem sti clutch Spiider Auto DCCD This turbo came with the used IAG rotated downpipe/uppipe i bought on here. Knew it was a poor match to engine but wanted to see how it'd do. Definitely some room for improvement esp w/ avcs tuning but will probably sell this turbo and change to gen 2 3071 .63 or similar that better suits my setup and goals.
06-21-2017, 01:14 PM | #2 |
Member#: 301663
Vehicle:2004 JDM WRX Wagon Silver |
Picture doesn't load.
edit...works on mobile |
06-22-2017, 08:53 AM | #3 |
Member#: 56203
Vehicle:00 RSTI Coupe Twin Scroll 2.5XTR EJ207 |
Not bad power but like you said definitely room for improvement with some AVCS Tuning and other. Just curious why didn't the rev it out more. Even to 7500 would have made the graph look a lot better.
I had a similar setup but with a Bloush TS 2.5xtr and say full boost (20psi) around 4500 depending on gear. For a fun street car I agree on stepping down to smaller turbo. I'd even look into the gtx28s or the old gt3071 should do well. Maybe look into a gen II gtx2867 KB seemed to really like that turbo Last edited by Paul; 06-22-2017 at 08:59 AM. |
06-22-2017, 09:08 AM | #4 |
Member#: 301663
I agree that there is some response benefit to be had with the avcs tuning.
I had a FP green HTZ which is a journal bearing turbo that is larger than the 3076. I also have a ej207 V8 motor. I would hit 24psi on a 3 gear pull (5 speed box) at around 5k |
06-22-2017, 09:25 AM | #5 |
Member#: 35944
South East
There were quite a few similar runs, this is only one I have printout of. Did run it to 7900 but power drops off drastically over 7k.
This is with AVCS map literally zero'd out. I had basic setup done and configured for the GM IAT, new MAP sensor, and WB and driveable on a basemap to get to the shop. By the time I got there, let car cool down enough to change plugs, get set up on the dyno, figure out some boost control issues and other random things that popped up, it was already evening. Justin @ Pro's started building up the maps and I was pleased to get to where we left it at. May go back at some point to put more work in but also am happy just to be driving the car finally, even with it's tiny powerband, and will probably focus on choosing a different turbo. |
06-22-2017, 07:00 PM | #6 |
Member#: 68372
06-22-2017, 09:30 PM | #7 |
Member#: 343367
Vehicle:2002 rotated gt3076 |
Pretty solid set up. I just got a V7 207 and am running an almost identical set up to you. I will have AVCS wired tho. How does it feel on the street?
06-23-2017, 01:53 PM | #8 |
Member#: 35944
South East
It's fun on the street, feels better than you'd expect from the graph
06-23-2017, 02:22 PM | #9 |
Member#: 343367
