Welcome to the North American Subaru Impreza Owners Club Friday December 3, 2021
Go Back   NASIOC > NASIOC Technical > Normally Aspirated with bolt-on Forced Induction Powertrain
Old 10-28-2010, 09:22 AM   #1
cdnsigop
Member#: 226535
1998 Impreza L (RIP)
Default EJ25D Cams with Boost 10-20+ psi
I have searched everywhere and am asking for help. I have nearly completed my budget build EJ25. Donor is a 99 Legacy Outback.
Build is a Phase 2 EJ25 block and crank, with EJ257 oem rods and pistons, Phase 1 EJ25D shim over bucket heads, an AVO 2.5 RS kit GT25 turbo and uppipe with an ebay Borla rep. dual port N/A header... I have the N/A EJ25D cams with the offset exhaust lobes...
What I want to know is how the stock cams will deal with big boost, as much as 20+ psi. It would be nice to hear from someone who has actually done this, as I do understand that N/A cams arent ideal for this...
cdnsigop is offline   Reply With Quote
Old 10-28-2010, 01:43 PM   #2
aoscjs
Member#: 255221
1997 Impreza L 2.2
Green
i know i havent turbo charged my car yet but that seems sketchy cause my friends 06 wrx that has quite a a bit of work and he only runs 16psi to 18psi so not positive but i wounldt try it
aoscjs is offline   Reply With Quote
Old 10-28-2010, 03:15 PM   #3
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
You would never get away running that much boost on stock heads with stock cams. You would only be able to run 10-12 psi with upgraded pistons. In order for you your heads to run more boost you would need to upgrade your cams and valvetrain.
07ImprezaMB is offline   Reply With Quote
Old 10-28-2010, 04:39 PM   #4
WagonMafioso
Member#: 222641
You can run 12+ boost with stock heads, subies out there running 20+ boost, and I am going to run soon 18psi on my SOHC heads, the limiting factor is pistons, NA pistons just don't cut it for boost.
WagonMafioso is offline   Reply With Quote
Old 11-02-2010, 10:25 PM   #5
sense of nature
Member#: 112759
2004 Stock OEM AsFu*
FoZZY SexyRP
^ This , I have done a 255 case w/ Sti internals, N.A heads & ran over 20 P.S.I. The cams kinda choke after 5 k tho
Old 10-09-2014, 10:29 PM   #6
rustylegasy5787
Member#: 379621
1995 legasy
green with a black roof
Default what year was the car
what year was the car and what kind of computer did you use .i wnt to do this same build i have a td04 sti top mount intercooler.2004 fxt block and piston rods and crank i was gonna pull sum heads off of a 98 wagon i found in my buddies junk yard have them port and polished triple cut valves slap them on and drop it in wit a few littil gauges boost gauge air fuel gauge oil pressure gauge fuel pressure regulator and the blow off valve what else do I need not looking to run a hole lot of boost 10 psi at moste .thank you im gonna keep reading this form
rustylegasy5787 is offline   Reply With Quote
Old 10-29-2010, 08:57 AM   #7
cdnsigop
Member#: 226535
Its not a question of whether Its possible or not. I have been running 17+ psi with water injection on an otherwise stock 1998 EJ22E. My question is how the EJ25D cams are with boost, lots of it, up to the 6500 RPM limit of the corresponding ecu...
No offence, but I dont care for the canned response of what the EJ engines can take boost wise, stock. Especially from people who have not done it. Because so far Ive proven those theories to be horse*****... Along with many other members on the board. Its just not a valid theory anymore.
Thanks anyway for the responses!
Old 10-29-2010, 09:41 AM   #8
Optical NZ
Member#: 120463
I havent done it, but looking at the lift and duration of them I would estimate that not much power would be made. Better to drop some wrx cams in there perhaps?
Optical NZ is offline   Reply With Quote
Old 10-29-2010, 09:50 AM   #9
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
it has been proven that our stock heads experience valve float past 6k rpms when boosted without upgraded valvetrain.
Old 11-05-2010, 10:20 AM   #10
2milehi
Member#: 81633
'98 RS-T
Can you site your facts cause I am running up to 6500 RPMs and I am not experiencing valve float (running about 15+ psi boost).
2milehi is offline   Reply With Quote
Old 11-07-2010, 11:17 PM   #11
cdnsigop
Member#: 226535
+1 for this... I ran a max of 20 psi with my EJ22e all stock, and no apparent float...
Either way, I am running these cams, got the shortblock assembled with the left side head, valves and cams installed. I used Cometic gaskets sprayed with Permatex copper gasket. Gotta tap the oil return boss on the right head before I can complete this build...
Old 10-29-2010, 01:02 PM   #12
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
i floated a valve with just cams and no boost before i got my springs and retainers.
olsen726 is offline   Reply With Quote
Old 10-29-2010, 01:07 PM   #13
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
Thanks for the back up olsen! lol
Old 10-29-2010, 01:14 PM   #14
eg33GC
Member#: 206851
56 Belair
Pro Street
The D heads are very similar to 20k/eg33 heads, and are pretty awesome. With port work, they will be able to flow very very well.
I think your primary issue will be the cam profiles- they have a little too much overlap for my tastes at a high pressure level. It is preference.
Another observation is that the cheap headers are very likely to crack with high EGTs. The Chinese replicas are 409 stainless if I recall, and that is not much better than mild steel as far as heat to strenght ratio. So expect to reweld them at the flanges at the least
Old 10-29-2010, 06:53 PM   #15
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
i will agree on having the replica headers crack. i have had mine on my car for well over 60k miles, (probably about 5k boosted) and i noticed that my turbo was taking forever to spool up... anyways long story short my borla rep's were cracked at one of the welds... but if you have anyone that can tig weld, it was a really easy 5 minute fix job.... and i have had my headers on my car for a long ass time ( not to mention i have bottomed them out on the road enough to dent the bottom of them) and they are holding most of the pressure from my heavy ass turbo.
Old 10-29-2010, 08:20 PM   #16
cdnsigop
Member#: 226535
Thank you very much for the thought out rather than canned responses. I really appreciate it. As far as the ebay header, I was thinking that I might be better off with a stock dual port exhaust manifold, but Im going to try this ebay header anyway... The ports arent overly large. I might even wrap the header and uppipe. Im trying to keep costs down, lol.
The cams....Im trying to "run what you brung". Back in my Honda days, I used to run big boost on the N/A cams all the time... DOHC ZC's and SOHC D16A6's. They made really good power for their size, and with 20+ psi I never noticed any problems with power falling off at the top..The only thing that really throws me off is those offset exhaust lobes on the EJ25D cams...
Old 11-01-2010, 10:47 AM   #17
PA-Outback2000
Member#: 161832
2000 Outback Limited
cdn... are the block and piston from an N/A or turbo car? u shouldn't run over 7psi on stock N/A block and pistons.
PA-Outback2000 is offline   Reply With Quote
Old 11-01-2010, 05:33 PM   #18
cdnsigop
Member#: 226535
The block is Phase 2 EJ25, with EJ257 pistons and rods.
Old 11-02-2010, 09:44 AM   #19
PA-Outback2000
Member#: 161832
so N/A?
Old 11-02-2010, 09:50 AM   #20
cdnsigop
Member#: 226535
LOL the bare block halves are N/A, but the EJ257 is the factory turbo 2.5 in the 2004- STi. So factory turbo pistons and rods. How do you get to be a Scooby Specialist without knowing what an EJ257 is??
Old 11-02-2010, 04:20 PM   #21
PA-Outback2000
Member#: 161832
it is based on # of posts i think, but i know enough. i get the EJ25x's mixed up sometimes. cams should be fine, but the heads may limit flow if they aren't done right or at all. u should think about different pistons depending how much over 20psi u plan to go.
Old 11-02-2010, 08:25 PM   #22
cdnsigop
Member#: 226535
lol man sorry, I was just busting your chops... I will be limited by my turbo, which is the AVO 320 GT25 (or GT28?) I believe (From the 2.5 RS kit). I will be leaving the heads bone stock but serviceable, except for new valve seals and resurface... I have been looking for the cams from an EJ20G/EJ20K, but not sure if the difference in power will be worth the money spent. I will be keeping the 6500 RPM limit, the GT25/28 turbo, the oem 2004 WRX TMIC, and the stock MAF. My exhaust is currently made up of an oem single port manifold to turbo (to be replaced with the borla rep dual port header), 2.5" downpipe to an oem 2004 WRX cat, to an ebay 3" catback, to a 2.25" reducer at the axle, to an oem 2005 STi axle back. My concern is that I dont truly have the flow on the exhaust side to let any cam really sing in the top end. Combined with my smallish turbo, and the WRX TMIC, and the low redline, this car is going to be more of a torque monster than it already is...
See where Im coming from with my question?
Old 11-07-2010, 04:40 PM   #23
stallion91
Member#: 221099
2005 Forester XT
Cayenne Red Pearl
i dont mean to hijack, but im looking to do the SAME thing
except, i was planning on getting Delta cam grinds for my SOHC, and i was going to use the stock EJ257 springs and retainers in my SOHC heads for a 7k RPM rev limit?
from what i gather from this thread tho, i should also machine my heads for bigger valve openings?
@ cdnsigop: i was wondering what type of ECU u were using. u said u wanted to keep costs down, and so do i (lol)
stallion91 is offline   Reply With Quote
Old 11-07-2010, 11:07 PM   #24
cdnsigop
Member#: 226535
I am using a 99 Legacy Outback 2.5 DOHC ECU, with a Greddy Emanage blue...
Old 11-10-2010, 01:06 PM   #25
ASF Machine
Member#: 236349
1993 Impreza
OD Green
STI springs are too short to use in an SOHC without a large spring seat shim.
ASF Machine is offline   Reply With Quote
Boost pressure starting at -20 psi, peaking at 5 psi...whats wrong? prophet03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-21-2010 08:26 PM
No boost over 20 PSI rainmanjam Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-10-2005 08:23 PM
Boost spike all the way to 20 psi heavyDOODIE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-12-2004 05:09 PM
Autometer Z-Series, Boost/Vacuum, 30 in. Hg/20 psi., 2 1/16 Mechanical Boost Gauge lstepnio Private 'For Sale' Classifieds 2 12-12-2004 12:11 PM
20 psi overboost on stock boost controller EricB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-21-2002 11:52 AM
