Welcome to the North American Subaru Impreza Owners Club Tuesday December 7, 2021
Old 09-22-2021, 10:06 PM   #1
alexosenov
Member#: 494121
06 Hawk
Default Oversized compression ring on standard bore
Hey, guys!
My builder screwed the ring gap on one if the compression rings like by a lot.........
Bore and piston size : 99.5mm
Luckily or unluckily I have the same brand and model old pistons which are 99.75mm. Can we reuse the compression ring 99.75 on a 99.5 bore and piston?
alexosenov is offline   Reply With Quote
Old 09-23-2021, 11:47 AM   #2
xtremewlr
Member#: 525652
2006 STI
WR Blue
If your engine builder can't answer this question for you, then you need to find a new engine builder.
You have to size down the larger ring to fit your bore size and get the correct gap.
xtremewlr is offline   Reply With Quote
Old 09-23-2021, 01:54 PM   #3
rtv900
Member#: 428511
2016 STI
That's pretty close
just widening the gap will only work to a point
In theory the ring won't be perfectly round in the wrong bore, but obviously if it's super close it will be so close to round it may not matter
If I were building an engine I certainly wouldn't rig up a ring for a different bore because why do that on such a cheap part
rtv900 is online now   Reply With Quote
Old 09-25-2021, 03:27 PM   #4
alexosenov
Member#: 494121
06 Hawk
Bought new ones. The ring won't be a perfect circle , the gap would need to be bigger aaand worse of all is it will not sit deep enough in the piston skirt .
Old 09-26-2021, 01:29 PM   #5
silverton
Member#: 331131
2001 2.5RS-T
Silver..thorn Metallic
trying to use the wrong sized rings will most certainly turn your engine in to a hand grenade with the pin pulled. only a matter of time before the piston breaks.
silverton is offline   Reply With Quote
