Welcome to the North American Subaru Impreza Owners Club Saturday December 4, 2021
Old 07-19-2021, 02:49 PM   #276
Sgt.Gator
Member#: 374688
2005 STI
Originally Posted by RyanC View Post
What kind of tire was that, a Pirelli slick?
Glad to see the damage was only to the wiring! Although, I did cringe looking at the extent of the damage, that would be a real biatch to repair if you weren't dong a full on replacement.
Those Stoptech calipers are monstrous. I upgrade to the smaller Essex Racing AP kit this season and have been very happy with them, although I was surprised at how small the actual caliper is. Pads are huge, but the caliper itself quite a bit smaller than even the stock Brembos.
Hoosier race slicks. Not the A7/R7, the real thing.
The Stoptechs were installed by the original owner, Dirty Rice Racing. I installed the AP Racing setup on my LGT race car. I MUCH prefer the AP setup, but I can't justify making the switch. Except now AP/Essex offers the caliper with the quick change pad clips, which is fantastic for endurance race events. Changing the pads on the StopTechs in the hot pits is not easy or fast.
The AP quick change clips are sweet!
Sgt.Gator is offline   Reply With Quote
Old 07-21-2021, 03:57 PM   #277
Sgt.Gator
Member#: 374688
2005 STI
Default 818R Action Photos from May PIR Enduro Race
My helmet is just above the rear hoop because I didn't notice when we pulled the driver seat out to work on the fuel tank it didn't get put back in the same tilt bolt hole in the base. The stewards decided not to black flag me, but did meet me at my paddock space after the race about it!
The Radical SR3 is almost always the overall winner in our Enduro race.
Old 07-22-2021, 02:23 PM   #278
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Well it was also developed to be a racecar and not a kit car, so that isn't a surprise.
They had very different goals at the start of their designs.
Old 07-23-2021, 02:12 AM   #279
Sgt.Gator
Member#: 374688
2005 STI
The Blue Sake Bomber is back on track. Arcflash did an outstandingly quick job on the wire repair. We have put off the LINK ECU till November.
I'm heading up to ORP on Friday to instruct for Star Projects the day before the 24hours of Lemons race. My intent is to use the BSB for my part of the lead -follow exercise with my students. It should serve well for a test to be sure it's ready for competition.
Old 07-23-2021, 02:06 PM   #280
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Yeah I was lucky enough to get to experience one of the earlier ones. If you get a 818 even close to keeping up with one that would be a massively impressive task.
I need to look into those AP brakes more, always disliked that Brembo only offered larger fronts.
Scuby04STi is offline   Reply With Quote
Old 07-24-2021, 10:22 PM   #281
Scargod
Member#: 260314
2007 STI
silver gray metallic
I was at Watkins Glen for Factory Five's first NASA race with the 818 mule. It was much less than 400 HP.
John George ran away from everything in the feature race until the weak five speed broke.
I have custom engineered Stoptech Trophy brakes for my 818R. Huge brakes!
I wish someone would buy what I have. I guess I need to promote it and all I've put into my R kit.
I just ran my STI at Thompson Raceway Park, in CT. I had no help. Not loading, unloading, tire changes, etc. I ran competitive lap times. My 50+ hour, 470 HP engine, kept humming, up to 8K.
I'm just getting too old to do all I'm doing and keep building more cars, engines or finishing my 818.
Scargod is offline   Reply With Quote
Old 07-26-2021, 08:59 AM   #282
Homemade WRX
Member#: 33782
96 3MI Racing
That 818 has been in the works for a while. Come on Glyn, get the 'low maintenance' car done already
Old 08-10-2021, 12:42 PM   #283
Sgt.Gator
Member#: 374688
2005 STI
Next race is this weekend at Portland International Raceway. I'll be racing in the ST class on Saturday and Sunday. I'm forgoing the Mini Enduro. It's forecast to be 109 degrees on Thursday, hopefully a lot cooler by Sat/Sun. It will be another good test of our cooling setup.
Old 09-03-2021, 03:51 PM   #284
Sgt.Gator
Member#: 374688
2005 STI
One of my friends has done a video narration of a race at Pacific in the SCCA T4 class. Three cars are 86 platform FRS's (but you can imagine they are BRZs.). I raced against these same three guys years ago in Honda Challenge, now they are trying to convince me to switch to the BRZ. The driver is a multi year class champion so it's worth listening to his narration of what he is thinking, and what he thinks his competitors are thinking, thru the race. I learned a couple of good tips on the track.
Hope you enjoy it.
Old 09-14-2021, 02:40 AM   #285
Sgt.Gator
Member#: 374688
2005 STI
Default One last mod to the dry sump system
We made one last mod to the dry sump system, an A.R.E. Spintric. It separates the entrained air from the oil before the oil goes thru the cooler, sending the air to the top of the DS tank.
To test the new mod I went to ORP for a full day of stress testing the STI for the upcoming Cascade Festival of Endurance on Oct 16. After long periods on the track I would check the DS tank, no signs of air in the oil. And coolant temps were remarkably low, looking at my AP datalogs showed the highest coolant temp was 203 degrees for three seconds, 201 degrees for 35 seconds, and at all other times under 200!
The trans temp stayed under 200.
And to show how hard it was being tested the only problem that came up was the rear diff temp hit 275 degrees during the last session! ORP is especially demanding on the diffs because of all the turns and lack of long straights for a cool down. I don't expect the diff temp to be an issue in October at PIR, but we will be adding a pump and cooler to the rear diff over the winter.
Next up is dyno time for final race tunes, then one more trip to ORP for testing.
Good work Arcflash!
Old 09-14-2021, 10:36 AM   #286
Homemade WRX
Member#: 33782
96 3MI Racing
So does your pump lack a centrifugal AOS, or is your oil tank not doing a sufficient job or de-aerating the oil? I know several tanks on the market are pretty damn lazy designs just because they have a big name and most racers don't know any better.
Old 09-14-2021, 11:58 AM   #287
Sgt.Gator
Member#: 374688
2005 STI
The pump has no centrifugal AOS. The tank is a Peterson and has the centrifugal design, but it wasn't enough.
At PRI Gary is going to be showing a new tank that has the Spintric built into it. That will be a great design for anyone starting from scratch.
Old 09-15-2021, 11:37 AM   #288
Homemade WRX
Member#: 33782
96 3MI Racing
Ah. On the WEC/IMSA side we ran Daily with AOS and had great results.
On the NASCAR side (no BOP), we designed the de-aeration to be passive and in the tank.
But there will always be another gadget people can make to sell to racers.
Old 09-15-2021, 12:41 PM   #289
Scargod
Member#: 260314
2007 STI
How did you know that air was being entrained and/or causing a problem?
How do you know that the Spintric did the trick? I'm interested in how you evaluated the problem.
I remember that another 818 racer added a Spintric or similar device.
Since my son will be taking over the completion of the 818R and it will have a Dailey DS (along with Micah's destroker kit in the engine) I want to get him off on the right foot!
Old 09-15-2021, 02:24 PM   #290
Sgt.Gator
Member#: 374688
2005 STI
It's easy. While cold look inside the DS tank and note the color of the oil. The level is not as important as long as there is at least 1/3 of tank! The oil level will be low simply because the tank is higher than the engine and will gravity flow into the engine. That's why Cosworth in their install instructions wants you to spin the scavenge pump before you start the engine. I don't do that and so far it's been no problem.
Start engine, warm up to operating temp. Stop engine and take the cap off the DS tank, look down inside at the oil level or measure it with a dip stick.
Go out on track and run it hard for 10 laps. Come back in the pit and stop the engine, look inside the tank or measure with dip stick. If the level is significantly higher than before that isn't just the oil expanding thermally, there is air in it. You may note the color is lighter too. There will be bubbles on top. You may even see foam.
After I installed the Spintric all those things were significantly reduced.
And yes, Rob runs a Spintric on his 818 he bought from Chad who originally installed it. Now that he has added a third scavenge stage he is having great oil temp/pressure results too.
Old 10-05-2021, 05:10 PM   #291
Sgt.Gator
Member#: 374688
2005 STI
Default Last Race in 2021 - The Cascade Enduro
Our last race of the season is coming up October 16th at Portland International Raceway, the 46th Annual Cascade Festival of Endurance. It includes 2 hour, 4 hour, and 8 hour races all at the same time. We are entered in all three.
We think this is the last LeMans style start in North America.
In prep for the event we spent last weekend at ORP with final testing of the STI and getting wheel time for the drivers. This year we are partnering with 541 Racing to put two cars on the grid and share crews/drivers. We overlook the fact that they are bringing a BMW...
It is expected to be chilly and wet with showers forecast. Perfect Subie weather!
If you are interested in joining our crew please shoot me a PM.
There's no cost for spectators to attend. The LeMans start is at 12 Noon. We run into the darkness to race end at 8 PM. If you come out please drop by our paddock and say hello.
Old 10-05-2021, 06:40 PM   #292
BlueSTI4Me
Member#: 34361
04.7 STI
WRB IG @got2boostit2
Good luck at the race.
BlueSTI4Me is offline   Reply With Quote
Old 10-06-2021, 09:07 AM   #293
Scargod
Member#: 260314
2007 STI
I hope everything goes well and safely. I'm there in spirit... Wished I could co-drive!
Old 10-06-2021, 11:26 AM   #294
biknman
Member#: 47915
1996 GC8 FFR818r
19 Forest Touring
Sgt Gator,
Do you know if anybody will be streaming this race online?
Thanks and good luck!
Dave
biknman is offline   Reply With Quote
Old 10-06-2021, 12:28 PM   #295
biknman
Member#: 47915
1996 GC8 FFR818r
19 Forest Touring
New DS pump installed, lines to cam covers connected, and one of our new Colonel Red Racing oem 10mm pumps installed too. More on the oil pump as soon as I get my Colonel Red Racing vendor account reactivated.
Hey SGT Gator,
Can I ask what alternator you running in this pic? I'm on search for a preferable a 1 wire with at least 100amps (EMPS and all the cooler fans) for use with my 818r. Looked at the Powermaster Race series 8122 and the DC Power Eng but those are $400+ alternators.
Dave
Old 10-06-2021, 02:20 PM   #296
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Might have to talk the wife into swinging by for a few, always nice to see a subi on track. Regardless good luck, the rain will help a LOT!!!
Old 10-07-2021, 04:12 AM   #297
Sgt.Gator
Member#: 374688
2005 STI
Originally Posted by biknman View Post
Sgt Gator,
Dave
Only the timing and scoring on Race Hero or Race Monitor.
Hey SGT Gator,
Dave
The DC Power 180-HP. 180 Amps. Works great since 2017.
And thanks to everyone for the Best Wishes!
Old 10-07-2021, 02:36 PM   #298
Sgt.Gator
Member#: 374688
2005 STI
Brad Briscoe has entered their DP-01 Sports Racer, looking for an overall win. The drivers will be Dominic Dobson (former IndyCar driver), Andrew Evans (winner in class at the 12 Hours of Sebring), and Jim Froula (who owns RaceCraft preparing vintage cars), and John Hill (class winner at the 25 hours of ThunderHill, multiple time Conference Formula Ford Champion, and SCCA National Champion).
We're not competing with the Sports Racer class, but we have to be very aware that closing - overtaking speeds in the dry will be crazy fast. However if it rains hard and long anything can happen. Our team will be doing the Subaru Rain Dance!
Old 10-14-2021, 12:34 PM   #299
biknman
Member#: 47915
1996 GC8 FFR818r
19 Forest Touring
Didn't catch it. But I'm eagerly awaiting how it went for you and Dragonfly's 818r.
Checked:
http://cascadesportscarclub.org/road...cc-conference/
and
https://www.motorsportreg.com/index....F8DE660DDAFAA6
Dave
Old 10-18-2021, 02:37 AM   #300
Sgt.Gator
Member#: 374688
2005 STI
Default We Won the 8 Hour Cascade Enduro!
Team Colonel Red Racing pulled out a win at the 8 Hour Cascade Festival of Endurance!
We were entered in the 2 Hour, 4 Hour, and the 8 Hour. We knew the 2 Hour would be next to impossible with other top level cars in our class including a Superlite SL-C. But some of those cars would be moving up to the EU class for the 4 & 8 hour. Our only shot would be if it rained, hard. We were doing the Subaru pray for rain dance all week but alas, it was dry and 68 degrees. Perfect for the supercars. Not so for us to be racing them.
But in endurance racing it's not who smokes the fastest laps for 4 hours, it's who does the most laps at the end of 8. Sometimes the tortoise really does beat the hare!
First to drop out was our friends at Dragonfly, their Factory Five 818R broke a CV axle. We look forward to pitting our 818R against them next year. And good luck at the Thill25, we'll be cheering for you!
For the 4 & 8 hour the superfast car was a SVT Mustang with ginormous HP. In the curves we could easily stay with him because every time he slightly touched the accelerator the back end would go all over the place. But once the track straightened out he was gone! Then shortly after the 4 hour race his engine went bye-bye.
We continued to soldier on, eventually passing their lead and going into first place. Unfortunately at 6 hours we noticed some strange vibrations. We changed the front tires out. A little better but still there. We changed the rear tires out. That didn't help. At 6.5 hours our right front CV Axle called it quits. I was able to limp around back to the pits where it took a little bit to figure out the outer CV joint had broken completely inside the CV boot. However by then we were cemented in 1st place so rather than trying to swap in a new axle we called it a race.
Huge thanks to our Premier Sponsor, Subaru of Bend. Your support has been key to get us to this point. Thank You!
Also thanks to our tuner/fabricator and friends at Arcflash.
And thanks to the PacNW Subaru enthusiasts who came out to crew, ya'll did a great job and are welcome to crew anytime!
Video next week courtesy of Frontside Productions.
