Welcome to the North American Subaru Impreza Owners Club Wednesday December 1, 2021
Old 12-10-2004, 07:10 PM   #1
heavyDOODIE
Member#: 62981
me the victor!
Default Boost spike all the way to 20 psi
i just installed an sti top mount on my car the other day, and last night as i was pulling onto the onramp, the car started to spool up really quick. and then SLAM!!!!!-as if i hit the brakes. CEL came on right away. i figured it was something to do with the i/c.
so i unplugged the battery when i came home. this morning, i put it back on, checked the car out, and then took it for a test drive. this time i took it up a small grade, and gave it some gas, also paying attention to the boost gauge. the needle sweeped all the way past 15 to 20. so i tried it again going downhill, and same thing. it also picks up 12 psi at partial throttle(closed loop)
this worries me a lot. do any of you guys know a fix to this? or will the ecu manage this out on its own in time?
the only mods to the motor are an uppipe, catless downpipe, and the sti i/c. no engine management upgrades.
thanks in advance.
heavyDOODIE is offline   Reply With Quote
Old 12-10-2004, 07:13 PM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2017 BMW X5
Check the vacuum lines connecting the turbo, wastegate, and boost soleniod - chances are you knocked one loose.
cdvma is offline   Reply With Quote
Old 12-10-2004, 07:21 PM   #3
heavyDOODIE
Member#: 62981
me the victor!
will do, and thank you.
Old 12-10-2004, 08:31 PM   #4
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
The short vac hose with the restrictor pill can get pinched with the sti ic. More restriction= more boost/spike. Try shimming the ic up with some washers on the turbo side.
GDR is offline   Reply With Quote
Old 12-10-2004, 08:39 PM   #5
2Stroke
Member#: 36712
2003 WRX Wagon
^^^ What he said.
Having the wastegate actuator hose disconnected has the following symptoms:
Really fast spoolup with even moderate throttle opening. The car feels very fast until you hit fuel cut. Half throttle is just about as fast as full throttle.
Very high boost which climbs until you hit fuel cut (after ~2 seconds above 17.5 psi) and the CEL comes on. Fuel cut almost always happens between 3000-4000 rpm. Most common is 3100-3400 in 4th, or slightly higher in third.
CEL that stays lit until you've cycled the engine on and off 4 or 5 times. The code set is P0244.
Ask me how I know.
2Stroke is offline   Reply With Quote
Old 12-11-2004, 07:47 AM   #6
heavyDOODIE
Member#: 62981
me the victor!
yup, he was right. the first thing i saw when looking at the vacuum line was a small gash on the wastegate line. it was from the sharp corner of the i/c hitting the line.
so i just made a quick fix with some electrical tape until i can get a new one, and since the intercooler doesn't sit in the stock mount, i just put the screw back into the mount, under the i/c rubber mount- so it essentially jacks the i/c away from the vacuum line.
anyone know how much a line like that costs? or is it better to get a silicone one cut to length?
BTW- how do you know that 2stroke?
thanks you guys, you just saved me a gazillion dollars!!!!!!!!!
Old 12-11-2004, 09:36 PM   #7
2Stroke
Member#: 36712
2003 WRX Wagon
Having used more than one type of hose for that specific purpose, I'd suggest using hose specifically designed to carry vacuum and pressure on a turbocharged car.
My local dealer (Timmons) didn't have the Subaru piece, but since they also sell VW's, they had a spool of hi-temp, reinforced hose that was OEM stuff for the 1.8t engine. Anyway, I bought a couple feet and it's been fine for well over a year now.
Normal vacuum hose will work for a couple months, maybe more. Over time, it will get hard, shrivel, and crack due to the high heat of the turbo. I don't think you want to use silicone for this application.
Edit: This particular hose never sees vacuum, only pressure, from atmospheric up to whatever your max boost is. You'll also want to keep the length as short as practical. Excess length will cause boost spikes.
Old 12-11-2004, 10:57 PM   #8
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2017 BMW X5
There is a restrictor pill in the line before it is joined together by a T to go to the boost control solenoid - if that is the ripped line you must find a replacement that will hold that pill. If not, just replace it with equal diameter hose, I recommend silicone hosing as its durable.
Glad it was that easy
Old 12-12-2004, 05:09 PM   #9
heavyDOODIE
Member#: 62981
me the victor!
thanks again guys,
i was considering using silicone. i figure it has better heat resistance, and this was the line to the wastegate, above the compressor. so it sees a lot of heat.
now i just gotta get that hose, cuz who knows how ling this electrical tape will hold up - so far so good
WTB: 2005 STI Center console (from the AC controls all the way to the armrest) 1FSTREX Private 'Wanted' Classifieds 1 08-31-2006 05:46 PM
Pedophilia goes all the way to the top! Mr.Tickles Political Playground - Chaotic Neutral Edition 14 03-15-2005 01:28 PM
I think I'm going all the way to the dark side MattSEG Off-Topic 21 10-24-2004 05:13 AM
Do I have to remove the IC all the way to install Oil Temp in Front Gallery? Irishman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 10-11-2004 11:27 AM
Grinding noise with clutch all the way to the floor TrogDorWrx Transmission (AT/MT) & Driveline 4 07-31-2004 03:25 PM
