Welcome to the North American Subaru Impreza Owners Club Wednesday February 21, 2018
Old 11-09-2000, 06:51 PM   #1
tomrichardson
Member#: 2672
1973 Porsche 914
Porsche Red
Question Subaru Engine block heater
I have an MY00 2.5RS and I ordered the Subaru engine block heater from my dealer. I was wondering if anybody has this and could tell me how to hook it up to the engine? I looked under the hood and couldn't see anything apparent that I would hook it up to. I also looked in the car manual, and it didn't have anything to say.
Any help would be appreciated!
Thanks,
Tom Richardson, Jr.
tomrichardson is offline   Reply With Quote
Old 11-09-2000, 10:04 PM   #2
Avenger
Member#: 1234
Post
The block heater will fit into one of the frost plug holes, little circle plates. Inorder to put the block heater in you will have to knock out the frost plugs and remove them. Oh besure that the coolant is drained and not too hot. Then put the block heater. I suggest that if you do not really need it, don't put it in. This is because they always leak in the future when they rust out.
PS I suggest you let a mechanic install it if it sounds to complicated.
Avenger is offline   Reply With Quote
Old 11-09-2000, 10:32 PM   #3
tomrichardson
Member#: 2672
1973 Porsche 914
Porsche Red
Post
OK, thanks. I think I'll be able to figure it out now.
Oh, I need it. Today when I went out to start my car it was 15 degrees F. I live in Hailey, Idaho. It gets pretty darn cold here in the winter.
Tom Richardson, Jr.
Old 11-10-2000, 05:59 AM   #4
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
Have a Nice Day?
15 F????
You call that cold???
I'm still wearing shorts until it hits single digits. Hell, my carbed isuzu pickup would even start first try at 15F
--Roy
LUME is offline   Reply With Quote
Old 11-10-2000, 07:07 AM   #5
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Post
There is an engine coolant plug on the drivers side bottom or the engine. You'll need a 14mm allen wrench to get it out. It's not a freeze out plug but something that needs to be unscrewed. Obviously you'll have to drain the coolant first. That plug is in there really tight. I tried using a 14mm bolt with 2 nuts jammed together but I still couldn't get the bugger out. The nuts kept moving. If you want to see the exactly what the plug looks like go here: http://www.azscooby.com
and look at the OEM oil cooler mod. I had to remove the same plug but on the oppisite side.
Peaty
[This message has been edited by Peaty (edited November 10, 2000).]
Peaty is offline   Reply With Quote
Old 11-11-2000, 01:30 AM   #6
Eric Gagnon
Member#: 46
2001 Jetta 1.8T
Cool
Tom,
Get one installed before the winter gets too bad. It was -4F today and the car fired up great. I have the engine block heater and a batter heater. Any ?'s e-mail me.
Eric
PS - Don't forget to unplug the car before you drive away.
Eric Gagnon is offline   Reply With Quote
Subaru engine block heater install - need HELP! Peaty Normally Aspirated Powertrain 3 11-13-2017 10:49 PM
Question: Reparing engine block heater cord John Callahan Alaskan Impreza Club Forum -- AKIC 14 11-21-2005 02:32 AM
Engine block heaters, do they work? SOneil0387 General Community 18 01-04-2005 12:19 AM
SOA engine block heater darioc Interior & Exterior Modification 4 12-07-2004 07:56 PM
Subaru Engine block heater brand new Bear Private 'For Sale' Classifieds 1 09-15-2003 11:18 PM
