03-10-2006, 11:36 PM | #1 |
Member#: 107739
Vehicle:04 Ej20 |
04 wrx, cel flashing. utech installed
i noticed my cel flash today i think 3 times. it was when i got on the throttle pretty hard in 1st gear. what could that mean. i have the TXS up pipe,and TXS tbe. im at 2nd stage on the utech,i think my abc is three turns from fully seated.
03-11-2006, 12:58 AM | #2 |
Member#: 66044
Tri-State
Vehicle:2004 WRX/1994 Miata |
the cel flashes when there is knock.
03-11-2006, 01:54 AM | #3 |
Member#: 2998
VIC
Vehicle:2002 WRX WRB |
the basemaps are poo. Get it tuned. They run pig rich and are designed for 93 octane. My AFR dipped into the 9's on the stock stage 2 basemap.
03-11-2006, 10:56 AM | #4 |
Member#: 107739
Vehicle:04 Ej20 |
utech
so then does it mean i damaged anything then, would it be safe to wait one more month ,thatway i can get it tuned when i get my super 16...or do i really need to get it tuned now...?
03-11-2006, 11:35 AM | #5 |
Member#: 106917
The exact same thing happens to me.
03-11-2006, 11:46 AM | #6 |
Member#: 78074
MAIC
Vehicle:2005 STi Aspen White |
the abc should be 2 turns
03-11-2006, 01:34 PM | #7 |
Member#: 2998
VIC
the number of abc turns open depends on your car, each is different. Some can run without it, some need it opened up 5-7 turns for example.
Just drive gently until you get it tuned or you tune it yourself, epsecially if you are getting det on the stock stage 2 map. If you're not running at least 93 octane for starters you need to remove some timing. Have you done any logging? Remember the UTEC is not really a set and forget like the AP or ECUTEK. So after loading the basemap, close the abc fully, then do some logged runs (using logger #1) and see what your numbers are like. The boost map needs to be tuned for starters then work from there. So in summary, dont "got on the throttle pretty hard in 1st gear" until you're sure what the UTEC is doing! i.e. datalogg. |
03-11-2006, 04:30 PM | #8 |
Member#: 107739
Vehicle:04 Ej20 |
aaahhh.. thankyou...!
Similar Threads | ||||
04 STi: CEL + flashing cruise light + rattly exhaust + <3psi boost | Dirty25RS | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 04-19-2010 05:07 PM |
04 WRX - Going to be installing STAGE 1... Real Time vs Base map Question. | Jeenyus | AccessPort | 10 | 12-27-2007 02:44 PM |
04 WRX rear strut bar install help | 04REX85 | Newbies & FAQs | 5 | 11-30-2005 11:01 AM |
02-04 WRX Cel Fix | wrxwhip | Private 'For Sale' Classifieds | 0 | 08-03-2005 04:12 PM |
Stock 04 WRX, CEL - O2 sensor, slow response... | Spectre186 | Service & Maintenance | 4 | 06-22-2005 06:06 AM |
