Welcome to the North American Subaru Impreza Owners Club Wednesday November 14, 2018
Old 04-08-2002, 06:37 PM   #1
PapaG
Member#: 7734
2017 Gti
Default A warning to those with boost control and no tuning
Ok,
Here is my story. I recently installed an EBC, it is the first generation AVC-R. This unit also shows you your injector duty cycle. At stock boost levels I was running about 91-92% peak duty cycle a bit before redline. At first I thought this was very high, but I have since confirmed with Shiv and others that it is a normal level for the WRX. My next step was to install the colder plugs and pulley from my stage zero kit (I will install the rest later). At this time I decided to install the solenoid to the boost controller and check it out. I set my boost level to 1 bar. All was good until I looked at my duty, it peaked at 100%! This is no good. I turned it down to .9 bar and I was peaking around 97%. I finally settled down to .85 bar and my peak was around 93%-94%, not too much higher then stock. The stock boost controller would spike me to 1bar and then bleed off to maybe .8 bar by redline. With the ebc holding a high boost to redline I was seeing what are IMHO dangerous duty cycle numbers. I am hoping that the addition of the unichip, and leaning the fueling out at the top end will cure these high numbers. I will also be installing an EGT gauge shortly. I just wanted to give a heads up to those running high boost at redline to watch out, because on the stock fueling your injectors are probably wide open like mine were.
Steve
PapaG is offline   Reply With Quote
Old 04-08-2002, 07:03 PM   #2
mitch808
Member#: 10228
2002 Subaru WRX
100% does not mean bad. Injectors can go up as high as 110% or more. There are other more important measurments rather then duty cycle.
mitch808 is offline   Reply With Quote
Old 04-08-2002, 08:13 PM   #3
Z1 Performance
Member#: 9327
Thanks Mitch..beat me to it!
And using the AVC to measure duty cycle.....don't treat it as gospel, as its far from it.
You need a proper datalogger than shows IPW to calculate the IDC
adam
Z-1 Performance
Z1 Performance is offline   Reply With Quote
Adding boost with meth injection and no tune OK? nicholam Water/Methanol Injection, Nitrous & Intercooler Cooling 20 02-18-2008 01:53 PM
FMIC with stock everything and no tune? 03twrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 07-26-2006 11:05 PM
Warning to those with turbos larger then IHI's XtianLA Proven Power Bragging 29 04-13-2005 02:25 AM
Question to those with Boost guages. QwikRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-23-2003 03:51 PM
Warning to Those With DrawTite Hitches REHeck General Community 18 08-13-2003 09:42 PM
