Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Old 07-14-2017, 04:30 AM   #1
turbo222
Member#: 159817
2005 2005 wrx sti
black on black
Default 2000 RSTI EFR7163 E85 272 cams 541whp & 520tq
Event: Dyno
Ambient Temp: 99 F
Elevation: 1200ft
Weather: Dry, hot
Tires: NT01 275/35/18
Car: 2000 RSTI
Tuner: Yimisport
Dyno Info: Dynojet
Transmission: 2007 STI 6spd
Gear: 4th
Peak HP at RPM: 541whp
Peak Torque at RPM: 520tq
Baseline hp/tq for a stock on same dyno: 240/240
Target Boost: 28psi
Fuel: E85
Engine/Power Modifications:
Cobb Accessport Flex Fuel Tune
Outfront Motorsports closed deck Short block 9.1 compression, 1/2 studs
Full-race EFR7163 stock location kit
Front mount
Head rebuild with bowl blend and 1mm oversize valves
GSC 272 Stage 2 cams
Walbo 450lph e85 in-tank pump
ID2000
turbo222 is offline   Reply With Quote
Old 07-14-2017, 09:51 AM   #2
crazycam31
Member#: 54500
Aw man! This is the other turbo I was considering instead of the GTX3076r on my RSTI. We have very similar setups. Pics aren't working so I would love to see the car and plot. Nice numbers!!
crazycam31 is offline   Reply With Quote
Old 07-14-2017, 06:50 PM   #3
onefasazn
Member#: 45574
2004 CRP SG5 FXT
1998 Bright blue GM4
In for the pics and the dyno sheet. Photobucket fail.
onefasazn is offline   Reply With Quote
Old 07-14-2017, 07:18 PM   #4
wrxhard
Member#: 108091
Me too. Sounds like a potentially awesome setup.
wrxhard is offline   Reply With Quote
Old 07-15-2017, 12:06 PM   #5
Lance123
Member#: 301663
2004 JDM WRX Wagon
Photobucket has become such a **** site. Just lending a hand.
Nice Numbers!
2.0 or 2.5?
Lance123 is offline   Reply With Quote
Old 07-15-2017, 10:12 PM   #6
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
fun as hell
user1029 is offline   Reply With Quote
Old 07-15-2017, 11:51 PM   #7
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Originally Posted by Lance123 View Post
Nice Numbers!
2.0 or 2.5?
Its got to be a 2.5L
Old 07-16-2017, 02:03 PM   #8
motorbykemike
Member#: 273868
because its outfront closed deck
motorbykemike is offline   Reply With Quote
Old 07-16-2017, 05:52 PM   #9
Lance123
Member#: 301663
2004 JDM WRX Wagon
I'm almost certain it's a 2.5 as well, judging from the response - although I've seen other 2.5 on a similar setup with a slight bit more area under at lower rpms.
Outfront also close decks the 2.0 and the 3.0+ as of recently
Old 07-17-2017, 12:14 AM   #10
turbo222
Member#: 159817
2005 2005 wrx sti
black on black
Nice Numbers!
2.0 or 2.5?
Thank you very much! And yes it is a 2.5
That first one was supposed the Dyno Video...
Haven't been on the forums much in the last couple years to the car being down... But it back in full glory now. Loving it!
Old 07-17-2017, 12:32 AM   #11
turbo222
Member#: 159817
2005 2005 wrx sti
black on black
New pics added, trying to see if I can get the Dyno video up.
Old 07-17-2017, 12:33 AM   #12
turbo222
Member#: 159817
2005 2005 wrx sti
black on black
Originally Posted by user1029 View Post
fun as hell
Well said!
Old 07-19-2017, 10:44 PM   #13
secured-nor1
Member#: 11164
What size turbine housing there? What are the max duty cycles with ID2000s?
Any time slip,vbox data?
secured-nor1 is offline   Reply With Quote
Old 08-17-2018, 10:43 AM   #14
01RSTI
Member#: 490284
Default Nice to see it on the track
Originally Posted by turbo222 View Post
Event: Dyno
Ambient Temp: 99 F
Elevation: 1200ft
Weather: Dry, hot
Car: 2000 RSTI
Tuner: Yimisport
Dyno Info: Dynojet
Gear: 4th
Target Boost: 28psi
Fuel: E85
Front mount
ID2000
Have you calculated changes to the scrub radius due to the the added width of the suspension?
01RSTI is offline   Reply With Quote
