01-12-2007, 12:06 AM | #26 |
Member#: 73684
NWIC
Vehicle:2012 4Runner |
01-12-2007, 01:28 AM | #27 |
Member#: 7568
Nice Trunk. I am dreaming about it everyday |
01-12-2007, 02:25 AM | #28 |
Member#: 63399
Vehicle:1998 Land Cruiser TD Black |
nice setup...i guess if u put on a legacy gt u cannot really see the difference from the pics.
but if u put on outback, u could see the huge difference bfore and after.. anyway, nice setup..!! |
01-16-2007, 04:03 PM | #29 |
Member#: 16874
NWIC
Vehicle:2008 2008 Audi RS 4 2014 Audi S Q5 |
MitchGT: do you know the spring rates for those springs?
Jared |
01-16-2007, 07:57 PM | #30 |
Member#: 73684
NWIC
01-23-2007, 08:26 AM | #31 |
Member#: 102673
NESIC
Vehicle:2000 Legacy GT LTD Black |
Do I want to buy 1 or 2 of PN 20323FA000? Thats the Perches, do they come singly or in pairs, and are they diferent side to side?
01-23-2007, 11:55 AM | #32 |
Member#: 115154
Vehicle:2005 Outback XT White on grey |
02-20-2007, 12:06 PM | #33 |
Member#: 46534
Nice install. You got me thinking about doing something to my 2003 Legacy GT.
I have one question though. How much did you have to change your alignment after the upgrade? Could the factory hardware still be used to get a decent alignment setting close to stock? Or did you have to go about getting camber plates and cam bolts and such to correct it? |
02-20-2007, 01:28 PM | #34 |
Member#: 53625
Vehicle:00 16' FXT |
no need for aftermarket camber plates or bolts. You should be able to get 0 degrees front camber with the stock bolts. I was able to get -1.5 on my car once it was lowered. The rear camber is non-adjustable so you must take what you get, which in my case was -1.3 on the super low STi pink springs, but will be around -0.8 to -1 with H&r's, a "sporty," yet not tire-killing value. This is why I chose to get -1.5 up front so that the camber was pretty even f/r.
02-20-2007, 05:55 PM | #35 |
Member#: 138398
RMIC
Vehicle:04 WRX STI BLACK |
car looks awesome!!
02-20-2007, 08:18 PM | #36 | |
Member#: 73684
NWIC
ten80 got it right. |
02-20-2007, 10:52 PM | #37 |
Member#: 63399
u got only -1.3...lucky. mine was about -2.3. u could see obviously that my rear tire is tilt from any angle. :P
02-21-2007, 09:17 AM | #38 | |
Member#: 46534
They pointed me at this: 1005G-041-061 STI genuine parts. -25mm drop (1inch) and apprently it is specific for a SE sedan? Does anyone know or have heard of these before? www japanparts.com/db/partslist.php?dealer=1&car=8&middle=3&small=9 (scroll to middle of page) |
02-21-2007, 10:22 PM | #39 |
Member#: 46534
impressions of the GR2 shocks? Been doing some searches to see what aftermarket shock offerings there are for the BE legacy. It looks like there are two.
KYB GR2 Bilstein HD Can you comment on the overall ride quality of the shocks? Do they seem bouncy to you? |
02-22-2007, 05:24 AM | #40 |
Member#: 73684
NWIC
I can't say how the shocks affected ride quality because I never had them on with the stock springs. They are definately stiffer though. I love the ride of my car now but some find it a little rough.
02-22-2007, 06:11 AM | #41 |
Member#: 63399
it was ok. i wanted a much stiffer struts and springs than those combination.
however, my parents did not like it especially we always use the car to go on far far away roadtrip. :P |
02-25-2007, 10:24 PM | #42 | |
Member#: 74926
South East
Vehicle:2005 legacy sedan white |
and as far as bilstein, i've NEVER heard anything bad about them. they make good quality shocks too. |
03-06-2007, 02:41 PM | #43 |
Member#: 16874
NWIC
Full Replacement Parts List
Alright,
I'm getting things together to replace the failing suspension on my girlfriend's BE. I want to confirm the parts list, as I'm planning on having the strut/spring fully assembled prior to removal of the old. Parts needed: Part # 20325FA000 Front Impreza Rubber Seat (x2) 29443 H&R Springs 334273 KYB GR2 Front Strut 334274 KYB GR2 Front Strut 341275 KYB GR2 Rear Strut (x2) 20323FA000 Impreza Front Spring Perches (x2) 20375AA030 Rear Rubber Seat (x2) Can anyone confirm the above part #'s? thanks Jared |
03-06-2007, 03:12 PM | #44 | |
Member#: 65110
TXIC
Vehicle:2003 LSE Wagon Silver |
http://www.kyb.com/catalog/2006_passenger_car.pdf GR-2's depend on the year of your BE: 2003-04 ALL Front Right Hand 334445* 2003-04 ALL Front Left Hand 334446* 2003-04 ALL Rear 341275 x2 2000-02 ALL Front Right Hand 334273 2000-02 ALL Front Left Hand 334274 2000-02 ALL Rear 341275 x2 * New Part Number; Available Fall 2006 Regards, Jim Last edited by jpapanas; 03-11-2007 at 11:32 PM. |
03-06-2007, 03:48 PM | #45 |
Member#: 16874
NWIC
It is a 2001, so the numbers I posted are correct.
One thing I did forget to put on my list is the strut mounts. I want the cheapest ones I can get out of KYB, Subaru OEM or STi...any suggestions? I know the difference in performance and all that, and it doesn't really matter, I just want it to be at least OEM quality and CHEAP. thanks Jared |
03-06-2007, 04:01 PM | #46 |
Member#: 1964
RMIC
Vehicle:2012 Fit Sport 5MT Orange Burst |
KYB probably makes all three mounts. Tirerack probably has the KYB-branded ones. The Group N/STI mounts are still rubber, but you will get a bit more NVH with them and they might be a bit hard to track down for a BE/BH, though not impossible. I have a set of front mounts that I need to put on sometime, probably after finding some rears first.
03-06-2007, 04:46 PM | #47 |
Member#: 16874
NWIC
Also, are there dust shields and bumpers on both front and rear assemblies? Anyone have those part numbers?
Jared |
03-06-2007, 07:49 PM | #48 | |
Member#: 73684
NWIC
Yes there are, and I just carried them over from the stock set. I don't have the PN but if you PM Jamie she can probably get them for you. |
03-08-2007, 12:22 PM | #49 |
Member#: 16874
NWIC
Bump to the front page for any other feedback
03-17-2007, 08:29 PM | #50 |
Member#: 139830
Vehicle:2011 STI sedan SWP |
I need some help here even though it may not be the right thread...
I just installed whiteline springs on my BE last week. I used the stock struts and everything. I believe I need to get an alignment done asap, so I am wondering do I need to buy camber bolts for the rear as well or I should ask do they fit at the rear struts? I asked subaru's mechanic in dealership today..they said 02 legacy's rear dont have space for camber bolts but I would like to confirm what do I need to buy before I go for an alignment By the way, should I go for this setting? Touring Setup Front Camber: -1 Front Caster: Max Front Toe: 0 Rear Camber: -0.75 Rear Caster: N/A Rear Toe: 1mm Out Last edited by subaru_terrence; 03-17-2007 at 08:35 PM. |
Almost done with another mod (and install pics) 56K BEWARE | 2003Baja | Baja Forum | 2 | 09-23-2004 07:55 PM |
saw a gt2 today (couple of pics) 56k why not? | stuttgart | Off-Topic | 42 | 05-07-2004 06:16 PM |
New suspension woes...H&R+KYB | tora | Legacy Forum | 10 | 03-21-2002 07:30 PM |
H&R springs installed (before & after pics) | megatron | Brakes, Steering & Suspension | 46 | 12-20-2001 08:52 AM |
H&Rs+KYB AGXs on MY01 RS | moss | Brakes, Steering & Suspension | 15 | 11-22-2001 07:50 PM |
