Welcome to the North American Subaru Impreza Owners Club Sunday June 15, 2025
Old 03-05-2010, 09:45 AM   #1
moose00015
Member#: 180924
2017 Forester
Default key ring light, radio and clock are not working
I attempted to change the bulb to an led this morning. I had tested it before I went to reinstall it in the key ring itself. It worked then. I installed it and now the thing doesn't work. I pulled it out and swapped leds with the cigarette lighter one which works. Oddly enough the first led from the key ring works in the cigarette lighter, but the one from the cigarette lighter doesn't work in the key ring. Is there a fuse I could have possibly blow somewhere along the way?
Thanks
ETA: Now my radio and clock do not work either. Any thoughts?
moose00015 is offline   Reply With Quote
Old 03-05-2010, 10:49 AM   #2
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
fuse.
99subi is offline   Reply With Quote
Old 03-05-2010, 10:51 AM   #3
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Originally Posted by 99subi View Post
fuse.
This. Or that one led simply blew out or is defective.
CKxx is offline   Reply With Quote
Old 03-05-2010, 11:04 AM   #4
moose00015
Member#: 180924
2017 Forester
I just checked the fuses after checking to see if my dome lights worked. They didn't and I found I blew the clock room under the hood. I need to run and grab more fuses.
Craig, I had switched the LEDs to check that first. I thought I blew the LED at first too.
Thanks for the help.
Old 03-22-2010, 11:25 PM   #5
Linkseal
Member#: 102329
05 AW Piggy Gone
11 SP TOM'S IS-F
^ any update?
I got the same problem, instead, my Key ring light and center door lock not working, fuse for sure is fine...
Linkseal is offline   Reply With Quote
Old 03-23-2010, 11:29 AM   #6
06AZREX
Member#: 132244
2006 OBP WRX
2006 BMW 325i
It should be a fuse problem, just remember that a fuse can "look" good but in fact be bad.
06AZREX is offline   Reply With Quote
Help Needed: Key Ring light and Power Door Lock Not Working Linkseal Electrical & Lighting 2 03-24-2010 05:50 PM
Hvac controls are not working after radio install. Crow-sti07 Car Audio, Video & Security 3 07-07-2009 12:46 PM
Radio and clock stopped working. Help!!! 02turbosuby Electrical & Lighting 3 11-30-2006 01:13 PM
Radio and clock not working after cluster install jdm_wrx Electrical & Lighting 1 12-12-2005 03:56 AM
speedo and tach are not working properly ...lostwrx Newbies & FAQs 7 11-07-2005 02:21 PM
