Welcome to the North American Subaru Impreza Owners Club Thursday November 14, 2019
Old 06-27-2008, 10:57 PM   #1
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Cosworth, TSR70, MZM Tune
I wanted to gather all these posts and pictures together for some time and compile a journal so they would all be in one place and easy to find.
-Dasani
A little bit of history - I usually do the work myself on my own projects and below are two examples.
This is a street Mustang that ran 8.66 at 162mph and it was powered by a stroked 5.0 liter and Vortech supercharger. It was truly a street car - I campaigned it in the True Street class where the rules required you to drive 50 miles and then make 3 back-to-back passes, who ever had the fastest average of the 3 passes was the winner. The rules only allowed for a rear tire change after the 50 mile trip - no changes to anything else; no adding fuel, no raising the hood, no cooling down, etc. I was the True Street National Champion for 3 consecutive years in the mid 1990's with it. I also won a few Fun Ford Street Outlaw races and a couple of the Muscle Mustangs Magazine Shootouts during that time.
The 1989 Ford Mustang LX:
I was burnt out after spending 4 years criss-crossing the states while racing the Mustang, so I sold it along with my Saleen Mustang, and bought an S10. I swore to myself that I wouldn't modify the S10, but after about 6 months, I started swapping out the 4.3 liter V6 for a 5.7 liter LT4 V8 from a Corvette. The LT4 was modified with the usual hot rod gadgets - ported heads, bigger valves, cam, etc. The truck was great fun and I ending up running 11.50's with it while hazing the rear tires the entire quarter mile.
The 1999 Chevrolet S10 Xtreme:
I sold the S10 because it basically stayed in the garage - the last year I had it I only put 700 miles on it.
Dasani is offline   Reply With Quote
Old 06-27-2008, 10:57 PM   #2
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
(Last Update June 21, 2008)
Current Pictures:
Engine
- Accurate Machine Works Oil Catch Cans
- APS 3.5in Turbo Back Exhaust
- APS 80mm Cold Air Intake
- APS Billet Aluminum WRX Fuel Rails
- APS Braided Stainless Steel Fuel Rail Lines
- APS Braided Stainless Steel Power Steering Lines
- APS DR725 Front Mount Intercooler
- APS Dual Vent Bypass Valve
- APS Split Pulse Header
- APS Split Pulse Header Exhaust Shields
- APS TSR70 Turbo
- Cosworth 274 Exhaust Camshafts
- Cosworth 278 Intake Camshafts
- Cosworth Big Valve Cylinder Heads
- Cosworth Billet Steel Crankshaft
- Cosworth Billet Aluminum Timing Belt Guide
- Cosworth Connecting Rod Bearings
- Cosworth Cylinder Head Studs
- Cosworth Forged Pistons
- Cosworth H-Beam Connecting Rods
- Cosworth Head Gaskets
- Cosworth Main Bearings
- Cosworth High Pressure/High Volume Oil Pump
- Cosworth Piston Rings
- Crucial Racing 160 Degree Thermostat
- Crucial Racing Ported Stock Throttle Body
- Crucial Racing Radiator Caps
- Custom Automatic Intercooler Sprayer
- Custom Harmonic Damper
- Denso IKH24 Spark Plugs
- HKS 1000cc Fuel Injectors
- HKS A/F Knock Amp
- HKS F-Con V Pro Engine Management
- HKS Twin Power DLI Ignition Amplifier
- JDM WRX Tumble Generator Valve Deletes
- Koyo Aluminum Radiator
- KS Technology 3mm Phenolic Intake Spacers
- MZM Performance Braided Stainless Steel Fuel Lines
- MZM Performance Braided Stainless Steel Wastegate Lines
- MZM Performance Brake Line Heatshields
- MZM Performance HKS F-Con V Pro Tune
- MZM Performance Ecutek Reflash
- MZM Performance Fuel Pump
- MZM Performance Turbo Blanket
- Roger Clark Motorsports Titanium Exhaust Cam Pulleys
- Samco Silicone Radiator Hoses
- Sard Adjustable Fuel Pressure Regulator
- STi Kevlar Timing Belt
- System One Fuel Filter
- Tial 44mm Wastegate
- Thermotec Intercooler Piping Heatshield
- Unorthodox Racing Aluminum Alternator Pulley
- Unorthodox Racing Aluminum Power Steering Pulley
Drivetrain
- ACPT Carbon Fiber Driveshaft
- Carbonetic Carbon Triple Plate Clutch
- Driveshaft Shop Front Axle Shafts
- Driveshaft Shop Level 5 Rear Axles/Hubs/CV Joints
- Kartboy Front Shifter Stay Bushing
- Kartboy Rear Shifter Stay Bushing
- Kartboy Shifter Lever
- Kartboy Transmission Crossmember Bushings
- SPT Short Shifter Mechanism
- Turn In Concepts Shifter Linkage Bushings
- Turn In Concepts Shifter Pivot Bushings
Chassis
- Cusco Motor Mounts
- Cusco Rear Subframe Brace
- Cusco Transmission Mount
- Happi Motoring Fender Cowl Braces
- Kartboy Billet Aluminum Engine Pitch Mount
- Kartboy Exhaust Hangers
- Kartboy Rear Differential Crossmember Bushings
- STi S204 Front Performance Damper
- STi S204 Rear Performance Damper
- STi JDM Transmission Under Panel
- STi Spec-C Titanium Strut Tower Brace
- Turn In Concepts Rear Differential Bushings
- Whiteline Rear Subframe Locking Bolts
- Whiteline Steering Rack Bushings
Suspension
- Cobb Tubular Front Sway Bar
- Cobb Tubular Rear Sway Bar
- Ohlins 25 Way Adjustable Front Struts
- Ohlins 25 Way Adjustable Rear Struts
- Perrin Front Sway Bar End Links
- Perrin Rear Sway Bar End Links
- Racecomp Engineering Front Camber Plates
- STi JDM Spec-C Front Spring
- STi JDM Spec-C Rear Springs
- STi Group-N Rear Strut Mounts
Brakes
- Goodridge Stainless Steel-Braided Brake Lines
- Hawk HPS Front Pads
- Hawk HPS Rear Pads
- The Brakeman 2 Piece Front Rotors
Interior
- 2004 WRX Black Carpet
- 2004 WRX Katzkin Leather Covered Rear Seats
- 2006 STi Center Console
- 2006 STi Steering Wheel & Air Bag
- 2006 WRX Armrest Extension
- 2006 WRX Limited Leather Door Panels
- 2007 STi Limited HVAC Controls
- Autometer Triple Gauge Glove Box Mount
- Autospeed Billet Aluminum Dead Pedal
- Bazooka 8in Subwoofer Tubes
- Defi Dash Triple Gauge Mount
- Defi Exhaust Temperature Gauge
- Defi Fuel Pressure Gauge
- Defi Link 2 Gauge Controller
- Defi Oil Pressure Gauge
- Defi Oil Temperature Gauge
- Defi Water Temperature Gauge
- Infinity Kappa Perfect 6.1 Front Speakers
- Infinity Kappa 42.5i Rear Speakers
- Kenwood DDX-7017 Head Unit
- Kenwood KDH-C710 Hard Drive Unit
- Kenwood KNA-DV4100 Navigation Unit
- Recaro Sport Black Leather Front Seats
- Redline Automotive Leather Armrest Extension Cover
- Redline Automotive Leather Emergency Brake Boot
- Redline Automotive Leather Shifter Boot
- Rockford Fosgate Power 851 Amplifier
- Rockford Fosgate Power 1001BD Amplifier
- Solar Gard Window Tint
- STi CDM Black Floor Mats
- STi JDM Automatic Intercooler Sprayer Switch
- STi S204 Hazard Button
- STi S204 Shifter Trim
- STi Spec-C V-Limited Shifter Knob
- Turbosmart e-Boost 2 Boost Controller
- Valentine One Radar Detector
Exterior
- 2005 STi Headlight Housings
- 2005 STi Front Emblem
- 2005 STi Rear Emblem
- 2006 STi Rear Diffuser
- 2006 STi Side Under Panels
- 2007 STi Limited Rear Wing
- 2007 STi Limited Trunk Lid
- Autospeed Billet Aluminum Front Bumper Trim
- BBS RE 18x8 Diamond Black Wheels
- Car Service Hiro Battle Hawk Carbon Fiber Hood
- Carbign Craft Alternator Shroud
- Clearshield Vinyl Front Bra
- Cusco Stainless Steel Hood Pins
- Gruppe-S Carbon Fiber Radiator Shroud
- GT Spec Carbon Fiber Rear Bumper Heat Shield
- Hella Xenon Blue High Beam Headlight Bulbs
- Kartboy Billet Aluminum Battery Tie Down
- STi S203 Wheel Center Caps
- STi Spec-C V-Limited Front Lip
- STi Spec-C V-Limited Rubber Under Lip
- Trust Aluminum Lug Nuts
- Yokohama Advan Neova 235x40x18 Tires
Old 06-27-2008, 10:58 PM   #3
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
(December 28, 2005)
Well, at least for me, the combination of the Ohlins fixed perch struts and STi JDM Pink springs is absolutely perfect.
I drove on the stock set up for a little over 4000 miles before the legendary STi 'bobble head' syndrome irritated me enough to make some changes. I changed all the strut mounts to STi Group N hardened mounts and changed the stock springs to Tein H-Techs.
It was a nice setup and I put a little under 27000 miles on it, but the 'bobble head' monster would rear it's ugly head once in a while on certain roads and drive my crazy.
It took me a few months to convince myself to spend the money for the Ohlins struts. They are expensive, but they have 25 adjustments for bump and rebound together, plus they are rebuildable. So I put in the Ohlins struts and STi JDM Pink springs along with a pair of RCE Camber Plates in the front.
After getting everything in and setting the struts at 10 clicks from full soft, I took the car for a ride and all I could say was 'WOW'! It is a totally different car. I really expected it be a harsher ride switching to the stiffer Pink springs, but it was BMW type smooth. In fact, it was a little too smooth for my tastes, so I cranked the struts up another 10 clicks. That was just a bit too harsh, but the car handled like it was on rails. So I turned the struts down 3 clicks and it's perfect, for me.
I have put a little over 1000 miles on this setup and I have zero suspension noise, even with all the hardened and solid mounting points throughout the suspension (BTW: my stock struts never had the 'clunk' problem either). The struts can be easily adjusted by reaching under the car and turning the knob, the car doesn't need to be lifted at all. And the 'bobble head' is completely gone!
Suspension & Driveline Modifications:
Ohlins Struts (Front & Rear)
STi JDM Pink Springs
Racecomp Engineering Camber Plates (Front)
STi Group N Strut Mounts (Rear)
Cobb Sway Bars (Front & Rear)
Perrin Sway Bar End Links (Front & Rear)
Kartboy Crossmember Bushings
Turn In Concepts Differential Mount Bushings
BBS RE 18x8 Wheels
Yokahoma Advan Neova AD07 235-40-18 Tires
Gratuitous pics:
Old 06-27-2008, 10:58 PM   #4
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
(April 7, 2006)
This is my daily driver with a nice conservative tune from MZM Performance (Austin, TX). I drive over 100 miles everyday back and forth to work. The car is absolutely wonderful to drive around with almost instant boost. So, I wanted to know what the car would do in the same form it's driven in every day.
The APS DR725 FMIC is probably too much intercooler for the 20G and the car actually made 20 ft/lbs more torque previously with a APS DR500 FMIC. But the DR500 was injured and is now on the permanently disabled list.
Drove 35 miles to the track, went through tech and spent about 5 minutes in the staging lanes before making a pass. Zero race prep done, nothing removed, nothing changed, no cool down, no tire pressure change etc. Launched easy, no clutch dumping or riding the clutch.
Track Conditions: 86F / 83% humidity / 7mph headwind
Car weight: 3565 with driver and half a tank of 93 octane pump gas
Code:
R/T   ...   .454
60'   ...  1.875
330   ...  5.108
1/8   ...  8.001
MPH   ...  91.54
1000  ... 10.296
1/4   ... 12.408
MPH   ... 111.40
2004 STi
Modifications:
APS 65mm cold air intake
Deadbolt TD06H-20G turbo
APS DR725 front mount intercooler
Cobb catted downpipe (with 2.5 inch neckdown)
Borla Hush cat-back exhaust
NGK LFR7AIX spark plugs
MZM Performance 720cc injectors
EcuTek reflash tuned by MZM Performance (Austin, Texas)
Boost at 21psi
Dyno:
Old 06-27-2008, 10:59 PM   #5
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
(May 22, 2006)
The car is a 2004 STi
Front seats are 2004 stock STi seats with a Katzkin leather kit.
Rear seats are 2006 stock WRX seats with a Katzkin leather kit.
Carpet is 2006 stock WRX
Door panels are 2006 stock WRX Limited leather
Steering wheel/air bag/shifter knob are 2006 stock STi
Center console is 2006 stock STi
Shifter trim is STi S204 "type"
Leather boots are from Redline Automotive
And everything works
Thanks to Jamie from SubaruGenuineParts.com for her help!
--- 2004 STi to 2006 STi/WRX interior swap---
Cliff notes on the install (from memory):
Re-use all of the 2004 switches except the mirror control
Use 2005/2006 brackets on everything except the rear console mount
Steering wheel and air bag:
- direct swap
- electrical connections are plug and play
WRX rear seats:
- direct swap
Front door panels:
- use 2005/2006 handle brackets
- use 2005/2006 mirror control
- move tweeter mount and rotate
- trim tab on passenger side window/lock switch
- electrical connections are plug and play, except
- mirror control wiring needs to be run from console to drivers door
Rear door panels:
- move rear screw/clip mount
- trim tab on window switches
Console:
- use 2005/2006 brackets, except
- use 2004 rear bracket and grind to clear the parking brake cable
- small notch to fit the 2004 DCCD roller switch
Climate controls:
- direct swap
Price:
- depends on how much you swap, trade, sell, and spend on new parts
I'm sure I left something out, but that's pretty much it.
Note: This is a STi to STi conversion, a WRX will probably have differences that I'm not aware of (climate control, cruise control, etc).
Old 06-27-2008, 10:59 PM   #6
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Old 06-27-2008, 11:05 PM   #7
minhha2006
Member#: 154914
2005 WRX
UGM
omg I am very impressed after reading this thread...and kind of depressed too haha
minhha2006 is offline   Reply With Quote
Old 06-27-2008, 11:12 PM   #8
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
Sick... love the S10... and the mustangs... you can see how it translated into a clean-kept STI
very IWSTI-ish post with the "journals" haha
silverF4turbo is offline   Reply With Quote
Old 06-27-2008, 11:18 PM   #9
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Thank you very much.
Yeah, sort of... It's just nice to keep every thing all in one thread for easy reference.
-D
Old 06-27-2008, 11:12 PM   #10
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
(June 2, 2008)
Roger Clark Motorsports Titanium Exhaust Cam Pulleys:
Old 06-28-2008, 01:01 AM   #11
pDubs
Member#: 149317
'95 BMW M3 (E36)
'05 Kawi ZX6R, '73 CB350F
Very impressive.
pDubs is offline   Reply With Quote
Old 09-25-2008, 02:00 PM   #12
sleepersy
Member#: 122427
Default Fantastic Read
Fatastic car - so understated -
I love sleepers - especially Silver ones.
sleepersy is offline   Reply With Quote
Old 06-27-2008, 11:33 PM   #13
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Very good talking to you at the meet Charles, hope to come down again with a larger turnout.
Old 06-28-2008, 12:22 AM   #14
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Nice wasting away a Saturday with you. Good thing it didn't rain.
-D
Old 06-27-2008, 11:37 PM   #15
JREPeru
Member#: 98033
2003 wrx wagon
great build
JREPeru is offline   Reply With Quote
Old 06-27-2008, 11:46 PM   #16
SUBYDOODIE
Member#: 71490
05 cgm wrx
rubbing axles haha
so now you're hitting 10.5?!
SUBYDOODIE is offline   Reply With Quote
Old 06-27-2008, 11:57 PM   #17
scby rex
Member#: 104878
02 wrxbastardchild
10.55s
Old 06-28-2008, 12:23 AM   #18
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Yes, it ran 10.5's back in September of 2007.
-D
Old 06-27-2008, 11:49 PM   #19
manookie
Member#: 125495
06 Wrx
SGM stg 5+4-7
Mother of god that is awesome. Great job!!! I'd love to see some vids of you at the track.
manookie is offline   Reply With Quote
Old 06-28-2008, 12:08 AM   #20
Dash_Martino
Member#: 78728
04 STi
god almighty thats a nice car!
Dash_Martino is offline   Reply With Quote
Old 06-28-2008, 12:24 AM   #21
scby rex
Member#: 104878
02 wrxbastardchild
you and the rain, hahahahaha
Old 06-28-2008, 12:41 AM   #22
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
It will melt in the rain.
-D
Old 06-28-2008, 12:33 AM   #23
caseyfoster
Member#: 141100
2013 WRX
cute..
caseyfoster is offline   Reply With Quote
Old 06-28-2008, 12:35 AM   #24
Fail Wagon
Member#: 133584
2003 Honda S2000
i hate people like this guy^^^ mod please delete
Fail Wagon is offline   Reply With Quote
Old 06-28-2008, 12:39 AM   #25
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
That user has been deleted and taken care of (not caseyfoster).
-D
Totaled 2006 WRX repair project ''DIY style'' Journal with pics scoobydoo666 Member's Car Gallery 97 06-07-2010 12:54 PM
Pics of the "Silver Sleeper" STi Dasani Member's Car Gallery 99 08-09-2009 03:56 PM
Project STI Member Journal hspn Member's Car Gallery 49 07-18-2009 12:28 PM
Pics of the "Silver Sleeper" STi Dasani Texas Impreza Club Forum -- TXIC 42 11-11-2007 09:33 PM
"Silver Sleeper" othon Member's Car Gallery 35 05-31-2005 03:12 PM
