Welcome to the North American Subaru Impreza Owners Club Wednesday November 20, 2019
Old 07-07-2007, 12:01 PM   #1
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Default who's gone from no avcs to avcs?
I've read someone's thread awhile ago about going from no AVCS in their swap to having it. Besides your butt dyno telling you it's so much better does anyone have any dyno plots showing this? I just want to make sure before I tear my car apart again to rewire the mother...I'd like to SEE that I'ts actually worth it. I know that everyone has an opinion, and usually guys who have never driven a swapped car will post BS like AVCS FTW or whatever. I really just want to see the proof.
domestic_abuser is offline   Reply With Quote
Old 07-08-2007, 07:56 AM   #2
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
anyone?!
Old 07-11-2007, 01:16 PM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
on twinscroll its night and day
Hyper is offline   Reply With Quote
Old 07-11-2007, 10:04 PM   #4
sith
Member#: 66362
2015 WRX
Grey
yeah.. twinscroll avcs works well.. but really if you have an engine with the solenoids you should defiantly run it.. you could wire it up in an hour or two..
.sith.
sith is offline   Reply With Quote
Old 07-12-2007, 10:56 AM   #5
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
in an hour? wtf, how?
Old 07-12-2007, 11:08 AM   #6
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
using the SEARCH button
Old 07-12-2007, 11:26 AM   #7
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
I'm not an idiot, this is someting that I have been searching. Hydra, rewiring the whole car and possible selling the USDM AVCS heads to buy JDM heads and run a JDM ecu. If you're going to sit here and say there's a 1 to 2 hour process to get the AVCS running then tell me. If it was that simple everyone witht a swap would run it.
Old 07-12-2007, 11:48 AM   #8
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
WRX wiring to JDM ECU -> to get AVCS to work you have to add 9 wires (8 really, the shielding one is optional); they run direct from ECU pins to destination (solenoid or sensor)
simple, 1-2 hours
if you need diagram, pm me your email I will send you the schematics
Old 07-12-2007, 01:09 PM   #9
sith
Member#: 66362
2015 WRX
Grey
haha! thats funny! thanks for filling in for me hyper.. also what engine do you have? the way hyper explained is spot on.. but if you've got a good working usdm ecu and motor then what i would do is use ecuflash and a tatrix cable and add the vvt maps to your current ecu.. save some money. good luck.
.sith.
Old 07-12-2007, 03:47 PM   #10
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
I'm running the U.S. Legacy GT engine. I understand the way the tactrix cable works, somewhat. What I don't understand is if it's that easy for me to add vvt maps to my current set up why don't tuners do it?
Old 07-14-2007, 02:14 AM   #11
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
.sith.
AFAIK if your ECU is not AVCS capable you just can't flash it with AVCS maps to the current ECU, or I would have done that long ago.
wrxfactor is offline   Reply With Quote
Old 07-14-2007, 04:58 AM   #12
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
That what my understanding was also
Old 07-14-2007, 11:25 AM   #13
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
so you have a Legacy GT motor...so usdm avcs?...well, JDM avcs has a different sensor lay out...one is two sensor and the other three...one magnetic and the other hall effect...can't remember which is which...Andrew can make you a custom hydra to run it and then you have run 8 or so wires...or by jdm heads and ecu and plug it up then run the 8 or so wires needed.
Old 07-17-2007, 12:15 PM   #14
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
right on the spot
I was under impression that you had JDM engine, hence I doubt my diagrams would be any help
Old 07-17-2007, 07:18 PM   #15
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
From what I've been told magnetic is used up to the ver.7 sti, and Hall afterward. So really that's not the problem. I know I would have to run newer JDM heads with a newer ecu, and I don't feel like forking out 1600 dollars right not for a stand alone. I guess I'll just bite the bullet on this one and wire the car eventually. Thanks guys.
Old 07-18-2007, 12:31 AM   #16
zanderspeed
Member#: 72818
2002 Bugeye
EJ25 | FPGreen
I'm running an 02 ecu and left my AVCS disconnected due to the hall effect sensor issue ($$).
From my understanding, avcs or not, you'll reach the same peak hp. It's across the powerband wher the avcs in most beneficial.
zanderspeed is offline   Reply With Quote
Old 07-18-2007, 01:36 AM   #17
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
That is correct. AVCS mapping will almost always go to 0 advance at the top of the RPM range to make the most power. AVCS affects the overlap in earlier RPMs to help build boost and make power sooner.
Has anyone gone from v8 struts to Koni's or others? sjscooby Brakes, Steering & Suspension 2 10-18-2005 10:12 AM
For those who have gone from WRX/STi to EVO... opinion needed txl146 Off-Topic 7 09-26-2005 09:05 PM
OT has gone from ridiculously homophobic to a gay love-in almost every day. CandyO Off-Topic 41 06-17-2005 05:18 PM
Anyone gone from large turbo to small for city driving? Brian Broz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-24-2003 04:06 PM
Who's gone from unichip to utec and kept same mods? ezatnova Engine Management & Tuning 0 02-05-2003 07:14 PM
