Welcome to the North American Subaru Impreza Owners Club Tuesday November 19, 2019
Old 08-02-2009, 02:25 PM   #26
SwiftShifter87
Member#: 208994
2009 Impreza WRX/STI
Camouflage Blue
how often do you guys clean ur engines?
SwiftShifter87 is offline   Reply With Quote
Old 08-02-2009, 02:31 PM   #27
el_guapo
Member#: 132038
funk er chicks
serious bidness
You guys have inspired me to finally clean under the hood on my cars. Mine really look like crap compared to these.
el_guapo is offline   Reply With Quote
Old 08-02-2009, 02:34 PM   #28
fzel07wrx
Member#: 150710
2012 SWP WRX Hatch
2005 Lotus Elise
If you clean it once and apply a nice protectant/sealer to the bigger plastic parts, it should last quite a long time. Like I said in my post above yours, it has been 5 months and I don't to anything more than a quick wipe down after washing the car. Looks just as clean as when I was finished going all out.
So at the rate I'm going, looks like I might need to clean it once a year... maybe longer?
fzel07wrx is offline   Reply With Quote
Old 08-02-2009, 02:56 PM   #29
MF-DIF
Member#: 62197
I'm really lazy about it. I don't cover anything, but I make sure not to drawn electrical components.
1) Cheapest degreaser I can find, and spray liberally.
2) Rinse with gardening bottle, you know those ones that look like pesticide jugs the exterminator carrys. I originally got it for autox to spray down the tires after hot runs. I fill that with water. You can buy one for liek $10. The spray has enough pressure to get the dirt off, but controllable so you don't soak electronics.
3) Hit everything I want to shine with CD2 engine detailing finish. I've had the same can for like 5 yrs.
I only do this like 1x a year. Engine looks new when I'm done, and all the plastics have a nice gloss. Also bonus, CD2 directions say to run the engine for 20mins after application for set-in. I typically just take a few runs around the neighborhood...steam bellows out of the hoodscoop. The looks from ppl are hilarious.
MF-DIF is offline   Reply With Quote
Old 08-02-2009, 03:37 PM   #30
Dstretch33
Member#: 157211
2k4 stg. 2 WRX sti
Good info. I need to clean the hood insulation soon.
Dstretch33 is offline   Reply With Quote
Old 08-04-2009, 08:53 PM   #31
96zj
Member#: 190290
2003 WRX Wagon
What does everyone use on the WRX intake manifold (aluminium)??
96zj is offline   Reply With Quote
Old 08-05-2009, 04:14 PM   #32
SubySal
Member#: 43011
2004 Impreza RS
PacificaBlue/BlackTarmacs
Simple Green that's all. I wash the engine about every other time I wash the car and have been since I bought it in '03. The only thing I cover up is the breather filter on the air/oil separator.
SubySal is offline   Reply With Quote
Old 08-05-2009, 04:32 PM   #33
ShaneInHisRoom
Member#: 148737
I use Simple Green, and an engine detailer called "CD2". It basically makes all your plastic and rubber look new, turns dull to shiny. I definitely recommend it.
ShaneInHisRoom is offline   Reply With Quote
Old 08-06-2009, 10:48 PM   #34
obyone
Member#: 16523
I don't use Armour All on any exterior parts. I use this instead on my tires and ground effects as I still have them in ABS black.
Simply spray and forget or wipe away for a faster shine. Non sticky and it doesn't attract dirt like Armour All.
obyone is offline   Reply With Quote
Old 08-06-2009, 11:06 PM   #35
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
That is an Armor-All product
yamahaSHO is offline   Reply With Quote
Old 08-06-2009, 11:30 PM   #36
snobrder_ad
Member#: 129203
2004 WRX Aspen White
StgII
Simply spray and forget or wipe away for a faster shine. Non sticky and it does attract dirt like Armour All.
Fixed
snobrder_ad is offline   Reply With Quote
Old 08-19-2009, 11:31 AM   #37
nayeliesuncle
Member#: 165137
Some people also use WD40 instead of Armor All.
nayeliesuncle is offline   Reply With Quote
Old 08-19-2009, 11:35 AM   #38
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....and some people use neither.
Kean is offline   Reply With Quote
Old 08-22-2009, 10:18 PM   #39
STIADAM
Member#: 220578
2006 STI
dark grey metallic
I wash mine at car wash with pressure washer.
Leave car running cover intake if you have aftermarket and just spray everything down=]
havent had any problems with it and done it quite a few times works great for me.
STIADAM is offline   Reply With Quote
Old 08-22-2009, 10:36 PM   #40
ShaggyTR
Member#: 197159
89 SR20 30r Coupe
Aspen White 05 STi
Simple Green FTW i tried it after seeing this thread and it works wonders
ShaggyTR is offline   Reply With Quote
Old 08-22-2009, 10:50 PM   #41
gopsu
Member#: 96448
02 WRX VF34
any problem with water finding its way into fuel injector areas?
gopsu is offline   Reply With Quote
Old 08-23-2009, 12:37 AM   #42
gopsu
Member#: 96448
02 WRX VF34
I just washed my engine bay with degreaser - I covered alternator/battery/MAF sensors with food wrap.
I went for 15 min drive afterward and car threw low oil pressure light. Think it will go away after a few days.
Old 08-23-2009, 02:12 AM   #43
litowrx
Member#: 132418
2004 EJ207
Did you checked your oil?
litowrx is offline   Reply With Quote
Old 08-23-2009, 04:11 AM   #44
gopsu
Member#: 96448
02 WRX VF34
yes it's at FULL
Old 08-23-2009, 03:50 PM   #45
jaypt802
Member#: 149730
2002 Impreza WRX
if i remember correctly the oil pressure sensor is under the alternator, dont quote me on this though. Maybe be something is wrong with the sensor?
EDIT: here is a picture of it on a older model
jaypt802 is offline   Reply With Quote
Old 11-01-2009, 04:37 PM   #46
goat630
Member#: 214779
2004 wrx
Mr. San Remo
so would you not recomend getting it steam cleaned at a detail garage?
goat630 is offline   Reply With Quote
Old 11-03-2009, 07:06 PM   #47
White out
Member#: 46277
** LP640
Viper GTS
At self wash;
Engine de-greaser, high pressure soap, engine de-greaser, let sit.
High pressure rinse, high pressure soap, high pressure rinse, spot free rinse.
Towel dry, then drive home.
From this:
To this:
Nick
White out is offline   Reply With Quote
Old 11-03-2009, 07:22 PM   #48
Badler
Member#: 133597
Water got in the connection most likely. Heard of it happening before. Dry it out and you should be fine.
Badler is offline   Reply With Quote
Old 11-03-2009, 07:42 PM   #49
swiftarrow
Member#: 228882
Originally Posted by Kean View Post
Personally, I've never had any issues with hosing down the engines on both our '08 Forester and my '03 WRX. Most of the sensitive areas/components in your bay are water resistant and are generally protected by design, gaskets, etc. If your intake is stock, there is really nothing to worry about in that respect. Just use a little common sense when rinsing (i.e. don't shoot a strong stream of water into sensitive looking areas, etc.). In my case, the nozzle I have has a variety of selections. I find the "shower" setting provides enough pressure and volume to rinse away any soap/cleaner while keeping the risk low for water seeping into areas I donít want it to go. ....keep in mind however that vehicle age, particular layouts, modifications, etc. may be factors in whether or not you decide to cover certain areas. Also, there is nothing wrong with taking extra precautions. If you feel the need to do so, then donít hesitate to cover the sensitive areas.
Below are a couple shots of my '03. I typically wash with Meguiars APC+ (diluted 4:1) and use a variety of detail brushes I have on hand to agitate/scrub (soft nylon & boars hair). After a final rinse I use a leaf blower (again, using a little common sense & caution) to help chase off some of the water followed by a towel to wick up whatever is left (to prevent water spots). My last step is to dress the plastics, hoses and rubber trim pieces. ....typically with 303:
That is a seriously clean engine dude.
swiftarrow is offline   Reply With Quote
Old 11-03-2009, 07:52 PM   #50
PleiadesSTi
Member#: 194132
2009 WRX Sedan
SSM
So I would be safe in washing out the engine bay then I guess. I'm still leery about putting water near electrical components, but I guess they are sealed from the elements anyway.
PleiadesSTi is offline   Reply With Quote
Cleaning engine bay Eggas Interior & Exterior Modification 36 09-22-2004 09:44 AM
Cleaning engine bay Matty Interior & Exterior Modification 10 02-16-2003 07:57 PM
how to clean engine bay fookiethedookie Car Care & Detailing 24 09-16-2002 04:04 PM
How to Clean Engine Bay and Underbody? Josico Interior & Exterior Modification 1 04-20-2002 08:49 PM
cleaning engine bay ?? redbaron Interior & Exterior Modification 2 05-03-2001 06:52 AM
