Welcome to the North American Subaru Impreza Owners Club Friday November 22, 2019
Old 04-15-2012, 12:22 PM   #1
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
Default 02 wrx with sti block..any mods needed?
i picked up a 02 wrx with a bad short block, rather then tear that engine apart and replace the internals, i have a spare sti block laying around from an old project. can i just bolt the wrx heads up to the sti block, tune for it and be good to go? im not looking for performance and dont wish to have anything aftermarket or change the boost or anything. just r&r and be able to drive it? its a 02 wrx and the block is an 04 sti block. thanks guys!
farrell is offline   Reply With Quote
Old 04-15-2012, 01:12 PM   #2
RexWagonWA
Member#: 221945
Default 02WRX with STi block
I have this engine combination. For long term reliability you need to have your WRX heads machined to match the STi block.
To those who do not believe this is needed. I have seen multiple WRX heads on Sti blocks without this machining. They do not work very well with the gas available on the West Coast.
Since you say you do not need high performance, keep the STi pistons if you need to save money.
GLWYB
RexWagonWA is offline   Reply With Quote
Old 04-15-2012, 02:04 PM   #3
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
thanks. is this modification something i could simply dremel out? the car is automatic and will be just a daily driven car for my wife. i doubt if she will ever even see 14.7 psi. this is more just a out of convience thing rather then rebuilding the wrx block. do you think i would be better off rebuilding the wrx block or be ok to use the sti block as a "oem" replacement?
Old 04-16-2012, 01:59 PM   #4
RexWagonWA
Member#: 221945
Default 02 WRX with STi block
This is not possible with a Dremel tool. You need a machine shop with lots of Subaru experience. The reason for modifying the head is to match the 257 bore and to eliminate the sharp edges and lips that can cause detonation.
04 wrx with lots of new mods needs tuned. Any suggestions? Jayme5793 Engine Management & Tuning 6 06-01-2011 05:50 PM
04 wrx with lots of new mods needs tuned. Any suggestions? Jayme5793 Open Source Reflashes 10 06-01-2011 02:14 PM
Simple Wire Question - 02 WRX with STI Block. - Dash - Built Motor Discussion 2 11-06-2009 01:48 AM
how do i hook up AVCS 0n 02 wrx 08 sti block with 06 wrx heads sgiord86 Built Motor Discussion 8 10-05-2009 10:36 AM
FS: WV: 2002 Black Wrx with Sti block, heavily modded BoostedSti Private Vehicle 'For Sale' Classifieds 13 06-29-2009 11:42 AM
