Welcome to the North American Subaru Impreza Owners Club Monday November 18, 2019
Old 05-20-2013, 10:32 AM   #151
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by sexyyrex View Post
I don't necessarily have a problem with idle being rich, I just have a problem with the pump running 100% all the time and heating up the fuel for an inefficient burn with a high fuel pressure base.
Originally Posted by jockeygolfs View Post
I believe the ecu will trigger a code if the fuel were to heat up to a temp that is too high. I have yet to see that code pop up.
Anyone know what the limit is for fuel temp? What do people normally see with the stock pump and controller? Or aftermarket pump and controller?
xluben is offline   Reply With Quote
Old 05-29-2013, 11:03 PM   #152
Layvon
Member#: 195711
PART OUT. PM ME
02-07 Goodies
I heat up my fuel too much. I haven't seen an adverse affect yet. I will do some testing to see what I can find out. My ethanol sensor should give me some information on this.
Levon
Layvon is offline   Reply With Quote
Old 05-29-2013, 11:36 PM   #153
05_wRex
Member#: 170097
2007 WRX STi PTE6266
Levon
If the fuel starts to boil, the air fuel can start leaning out when you get over 50-60% of the pumps capability. I started leaning out around 60% duty cycle when mine started boiling. I let it sit for a while and all was back to normal. I was running out a tank of 93 so I could fill it will race gas. My hardwired pump (aero 340) overruns the stock fpr. Returning excess hot fuel from the engine bay while on the dyno will heat up 1/8th of a tank of 93 pretty quick. I don't have a temperature.
05_wRex is offline   Reply With Quote
Old 05-30-2013, 12:37 AM   #154
Layvon
Member#: 195711
PART OUT. PM ME
02-07 Goodies
All OEM tunes will have it (obd2 readable) so if you are on the AP you should have retained jt.
I need to rewire my ethanol sensor becuase link came out with a revision for it, it said fuel was 132 C. I know it wasnt that hot.
If anyone wants to donate so testing can happen this weekend id be willing to beta test lol.
Old 05-30-2013, 09:11 AM   #155
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
You could just use a low voltage amplifier and a solid state relay to direct wire your pump while retaining factory duty cycles. You need a voltage signal to amplify the control signal that comes from the factory FPR, and invert it, the solid state relay has a very low switching latency. There are some that are specifically designed for pump control that have current handling capacities in excess of 50A, if you know a little about electronics and have about $60 to spend this is a better option than 100% duty cycle and you can wire multiple pumps to the same relay. You can also wire a failsafe boost cut to a solenoid using the relay output and go to a solenoid normally off (bypass) that turns on and t's the wg to the compressor reference.
dstroy is offline   Reply With Quote
Old 05-30-2013, 09:36 AM   #156
jockeygolfs
Member#: 260868
2011 STI
Can you post a diagram and model parts? I'm not electrically inclined but have done all my own wiring so far.
jockeygolfs is offline   Reply With Quote
Old 05-30-2013, 09:35 PM   #157
dstroy
Member#: 283711
2012 STI sedan
http://www.digikey.com/product-detail/en/L165V/497-2933-5-ND/634697
You could use that to invert the factory pwm and pick one of the SSR's that will meet and exceed your total spike amperage for all of your fuel pumps by 1/3 at least.
Old 05-30-2013, 09:44 PM   #158
jockeygolfs
Member#: 260868
2011 STI
Hate to be a annoying but if you already did this can you just list the parts that you used? Model number etc. it will make life easier. If not then that is cool.
Old 05-30-2013, 09:50 PM   #159
dstroy
Member#: 283711
2012 STI sedan
The relay would be specific to your setup, all you need is that part I listed, and a fairly large heatsink for it and the SSR. If you look at the datasheet Vs+ and Vs- are the supply voltage in/return and you wire the factory pwm to the inverted pin, and the output to the + side of the input of the SSR, - input on SSR to GND. On the output side + is for 12v from the battery and - goes to the + side of the fuel pump then just ground the FP to the chassis.
Old 06-05-2013, 04:55 AM   #160
bettner12
Member#: 56179
05 LGT 407hp/372tq
Tuned by [email protected]
don't forget a diode...
bettner12 is offline   Reply With Quote
Old 06-05-2013, 09:28 AM   #161
jockeygolfs
Member#: 260868
2011 STI
Ok, so dstroy, you are probably right. I have now gone through a DW300 and a Walbro465 pump. 100% operation is most likely the cause. I have to try to figure out what you are trying to say to work this out. How are external pumps wired? I would assume that they are wired for 100% as well but maybe they do the same wiring as you have described dstroy?
Old 06-05-2013, 10:04 AM   #162
dstroy
Member#: 283711
2012 STI sedan
I'll use ms paint after work to draw you a schematic. You'll need to do this, or get an aftermarket fpc. The upside of the DIY is that it's easy to expand for multiple high amperage pumps, downside is that it's complicated. I actually used a Zener diode on the op amp out to limit v in to the SSR to +5v.
Old 06-05-2013, 10:54 AM   #163
jockeygolfs
Member#: 260868
2011 STI
Your help is greatly appreciated!!! What aftermarket FPC are out there? Is there a model that would work the best for what we are doing?
Old 06-05-2013, 10:56 AM   #164
dstroy
Member#: 283711
2012 STI sedan
Aeromotive and Weldon make them, somewhat expensive but less expensive than replacing your fuel pump every six months to a year.
Old 06-05-2013, 10:57 AM   #165
jockeygolfs
Member#: 260868
2011 STI
How about this:
http://dccdpro.com/zcart/index.php?m...&products_id=6
Ill look into the ones you listed as well.
Old 06-05-2013, 11:13 AM   #166
jockeygolfs
Member#: 260868
2011 STI
The DCCD pro seems to be what you are describing dstroy but already already put together. Could this be the simple solution?
Old 06-05-2013, 11:15 AM   #167
dstroy
Member#: 283711
2012 STI sedan
That will do the same thing, and it will end up costing only a little more. Just call them and ask them if it will be able to handle your fp.
Old 06-05-2013, 11:31 AM   #168
bettner12
Member#: 56179
05 LGT 407hp/372tq
don't mind the messy lines. but this is what the wiring should look like, based on my interpretation of everything.
Finding a SSR that had fast enough cycle times was tricky though, I found this waveform on another thread on here about the fuel pump controller. IF it is accurate, then only two SSR's will be fast enough to keep up with the factory controller.
the two SSR's that come closest to working, assuming that waveform is accurate would be:
1) $84.02
http://www.digikey.com/product-detai...859-ND/2780519
Spec sheet here: http://www.crydom.com/en/Products/Ca...c_ip20_100.pdf
^ notice the amp rating dies off above 9000Hz, and you will need to add that largest heat sink they make for it, $24 if I remember.
2) the power I/O HDD-06V75E, will do 20,000 Hz, ( if the waveform is accurate, this is the ONLY relay ive found that can keep up)
http://ww6.aitsafe.com/cf/add.cfm?us...oducts/hdd.htm
Specs:
http://www.power-io.com/products/hdd.htm
And the Diode i would use:
$0.54
http://www.digikey.com/product-detai...SCT-ND/1139945
Old 06-05-2013, 11:46 AM   #169
dstroy
Member#: 283711
2012 STI sedan
We could just use a clock divider to change the pulse width, if they're using more than one pump we might also consider a more rugged diode.
Old 06-05-2013, 12:14 PM   #170
jockeygolfs
Member#: 260868
2011 STI
Thanks guys, I just placed my order for the FPC from DCCDPro. I just liked how it was already built and in a case etc. Hope this is the real solution. The tricky part will be when I add the two pumps that go in the sump tank a few months from now
Old 06-05-2013, 12:23 PM   #171
bettner12
Member#: 56179
05 LGT 407hp/372tq
take some pics when you get it?
Old 06-05-2013, 12:40 PM   #172
jockeygolfs
Member#: 260868
2011 STI
Yes I will take pics when it gets here. Hopefully sometime next week since they are in Canada. I'm going back and forth with them to figure out how to wire this up.
Old 06-05-2013, 01:33 PM   #173
dstroy
Member#: 283711
2012 STI sedan
The wiring should be somewhat straightforward, if they said that it will handle the current demand from your fp then you're good to go, and it's nice to know that this exists because the other options have an inflated cost due to brand and packaging (billet cases).
Old 06-05-2013, 01:41 PM   #174
jockeygolfs
Member#: 260868
2011 STI
I don't know if you have taken a look at their product but there are five connections that need to be made. Pump (+), Pump (-), Source (+), Source (-) and ECU. Pump (+) and Pump (-) are easy. Source (+) is from the battery. Source (-) I assume connects to the negative that would go back to the OEM FPC. This would mean the source line that I currently have using for the relay will be connected to nothing now. So what wire is the ECU wire?
Old 06-05-2013, 01:45 PM   #175
dstroy
Member#: 283711
2012 STI sedan
Source + and - are definitely power in, so to battery and chassis. Pump + and - obvious. Ecu, not sure which wire they want.
