Welcome to the North American Subaru Impreza Owners Club Wednesday November 13, 2019
Old 09-19-2014, 02:46 PM   #76
farmerz24
Member#: 272368
first test rip for the non-believers.
http://youtu.be/UMEOvXD5aCY?list=UUq...1JVHj6MyTHwOAA
farmerz24 is offline   Reply With Quote
Old 09-23-2014, 01:40 AM   #77
hi5.0
Member#: 340456
2013 Impreza
burnout video pls.
hi5.0 is offline   Reply With Quote
Old 09-24-2014, 08:29 AM   #78
frank_ster
Member#: 362820
how crude :P
whats your plan for cooling fans ?
frank_ster is offline   Reply With Quote
Old 10-26-2014, 09:40 PM   #79
farmerz24
Member#: 272368
With paint
Old 11-01-2014, 12:58 PM   #80
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
That is hideous but if you like it then who cares. How's visibility with that thing?
geronimo81 is offline   Reply With Quote
Old 11-01-2014, 07:13 PM   #81
Hondaslayer
Member#: 4562
2014 Electric Datsun
2005 Adventure van
In his defense, it is slightly smaller than the 04/05 STI hood scoop........
Old 11-21-2014, 05:35 PM   #82
urawdisminem8
Member#: 406845
Honestly with this thread, make me feel that when i am out of college i can make my awd lesabre . i didnt think a 3.8 could mate to the subarus awd glory. coolest thing ever
urawdisminem8 is offline   Reply With Quote
Old 04-25-2015, 03:34 AM   #83
dahoseman
Member#: 330468
1932 Ford Model A
I'm curious how this has held up?
dahoseman is offline   Reply With Quote
Old 07-12-2015, 06:29 PM   #84
skanitz1
Member#: 184209
I'm curious to know how you got the tach working?
skanitz1 is offline   Reply With Quote
Old 07-22-2015, 08:18 PM   #85
Iliveforboost
Member#: 389699
Hope this is still progressing since I love out of the norm builds. Did you ever get an he351ve going on it? Im currently using one on a dsm and made my own controller for, also doing compound with a roots supercharger. Anywho, show some updates!
Iliveforboost is offline   Reply With Quote
Old 04-19-2016, 02:41 PM   #86
farmerz24
Member#: 272368
still going strong after 2 years.
havent even changed the plugs yet.
i think i documented the tach in this thread or the other in 60degrev6. link is in my posts somewhere.
next issue is sourcing a push type release bearing that will fit on the sti/spec b 6 speed clutch fork and work with the clutch im using..
i need the release bearing seen here, but cant seem to source it:
https://www.youtube.com/watch?v=gsiIShlvM04
Old 04-19-2016, 02:49 PM   #87
farmerz24
Member#: 272368
Originally Posted by 207STi View Post
I think that is going to last approximately 6 seconds, or until you launch it for the first time. Not trying to hate at all, this is a cool project, I just see you shredding that tranny almost immediately.
tranny still going strong.
Old 04-20-2016, 01:23 AM   #88
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Originally Posted by farmerz24 View Post
Anyone other thank frank_ster care to take a guess on how I did this. And no, it did not involve a Subaru 36-2-2-2 trigger wheel.
I am super curious... Just started building an AVCS controller for the exhaust cams in my 05 LGT so I need a crank signal of some sort. And I'm too chicken to tap into the factory crank sensor. Been hoping to use an optical sensor and a dab of white paint on a cam pulley, but haven't tested that yet.
Old 10-19-2016, 06:20 PM   #89
mwm_88
Member#: 437748
I have an L67...
and a 99 outback sport with 5mt. Thanks for making my day.
mwm_88 is offline   Reply With Quote
Old 03-02-2017, 03:09 PM   #90
farmerz24
Member#: 272368
NSFW: sorry for the late reply...
what i did was buy the TinyIO board from JBperf. this talks to my ms3-pro via CAN.
the MS3-pro sends rpm data to the tinyIO board. the tinyio board then generates a fake crank and cam signal, which is then wired directly into the stock subaru PCM.
this allows the factory tach to work properly, as well as running the fuel pump (fuel pump turns on when crank signal detected).
The cam signal isnt the correct pattern yet, there are like 3 or 4 notches on the cam and it is only outputting one signal per revolution. But this works for now....
Old 03-02-2017, 03:10 PM   #91
farmerz24
Member#: 272368
just working on getting parts for the turbo build, as well as testing out the MS3-pro ability to control the turbo through the CAN interface.
Old 10-02-2018, 10:18 PM   #92
bobglaub
Member#: 225662
2005 STI and LGT WGN
White and SWP
Updates?
bobglaub is offline   Reply With Quote
