Welcome to the North American Subaru Impreza Owners Club Thursday November 21, 2019
Old 12-18-2011, 10:54 PM   #1
omiotek
Member#: 272090
2006 Subaru Forester
SGM
Default Omioteks Supercharger Build
Exterior Mods
22b Style Hood Vents
Bakemono Imports Replica S201 Hood Scoop(carbon)
Bakemono Imports Replica S201 Mirrors
Bakemono Imports Front lip(22b Extension style lip for rs bumper)
- note: might try to find a OEM/JDM sport(22b style but for stock with fenders)
Bakemono Imports Side Skirts
Bakemono Imports USDM Rear Bumper Spats
Bakemono Imports Mesh Fog Light Covers
JDM STI Flat Fuel Door
17"x8.5" or 9"(undecided) Enkei Rpf1s
Omiotek Paintjob(Charcoal more then likely)
Omiotek Tinted Tails
Omiotek Black Housing Headlights
25% Window Tint
Interior
USDM STI Seats
USDM STI Carpet
NavigationZealus Interiors Shift Boot/Ebrake Boot
- 50/50 Blue/Black Alcanatara with reversed stitching
Zealus Interiors Door Card Cutouts
- Blue Alcantara
Lizard skin sound deadening(removed the old crap)
Battery relocation
all parts are going on my 2001 RS
Eclipse Navigation
Rockford Fosgate 6.5" speakers(doors and rear deck)
Rockford Fosgate Punch sub(came with the car so im gunna use it)
Rockford Fosgate Amp
JDM STI Hazzard Switch
JDM STI V6 Cluster(same as usdm but tachs in the middle and higher speed rating)
Pro Sport Green Gauges
- wideband, oil temp, oil pressure, boost, volt, fuel pressure
Engine
Stock EJ251 Block
EJ257 STI Crank
EJ257 STI Rods
EJ257 STI Pistons AAAB
ARP Headstuds
ARP Rod Bolts
ARP Block Bolts
ACL Race Bearings
Ported Heads
Delta Camshaft 1500 Grind Supercharger Cams
08+ OEM Subaru 11mm Oil Pump
08+ STI Blue 565cc Injectors
OEM STI Fuel Pump
OEM Gasket Overhaul Kit
Grimmspeed Crank Pulley
Gates Timing kit
Pro Sport Sandwich
Mishimoto Radiator
Moroso Aluminum Oil Pan
OBX Equal Length Headers
CNT Catback
Aeromotive Dual Inlet FPR
transmission
ACT Street Clutch
ACT Flywheel
Suspension
WRX Front and Rear Sway Bar
WRX Crossmember
WRX Trailing Arms
WRX Lateral Links
Tein Super Street Coilovers
JDM STI Strut Bar
Chassis Braces
STI Group N Bushing Set
The Fun
Eaton M90 Supercharger
Ford GT500 Heat Exchanger(made by garret)
WERKSCustom Blower/Idler Pulley Bracket
WERKS Parallel Fuel Rail Mod
WERKS Air to Water Setup
WERKS Throttle Body Relocation
WERKS Lightweight Battery Setup
will add to this more later and will add pics aswell.
so here it is as it came off the truck.. bought the car for 1k and it didnt run......threw a battery in it fired right up....sure enough had the typical subby rod knock..
omiotek is offline   Reply With Quote
Old 12-18-2011, 10:55 PM   #2
omiotek
Member#: 272090
SGM
after i finished up the outside.... havent gotten to given the inside a cleaning yet....
replica s201 scoop i got....never ever mounted payed half of what it costs new.
Old 12-18-2011, 10:56 PM   #3
omiotek
Member#: 272090
SGM
wrx suspension but not everythings there in the pic
motor all torn down
sti rods and mesh fog light covers
Old 12-18-2011, 10:57 PM   #4
omiotek
Member#: 272090
SGM
awww isnt it cute?
pro sport oil pressure(still need to get more gauges)
STI Seats and carpet
GATES Timing Kit
11mm Oil Pump
Flat Fuel Door Kit/JDM Hazzard Swithc
Gasket Rebuild Set
Old 12-18-2011, 10:58 PM   #5
omiotek
Member#: 272090
SGM
greddy emanage blue $88 shipped
STI Blue Injectors
Moroso Oil Pan(1k on it) $325 shipped and its normally a $700 pan. would like to put a special thanks out to moroso aswell for going out of their way. the dipstick design the pan had sucked. they had me ship them the pan. they welded in a new adapter that uses the stock dip stick and also cleaned and decked the pan to check for flatness and included new studs and gaskets of no charge to me and it was a 1k turb around including shipping days. amazing service.
Old 12-18-2011, 10:59 PM   #6
omiotek
Member#: 272090
SGM
before
after
got this heat exhanger from a shelby gt500 owner i recently did a clutch on...best price free
some painted parts
Old 12-18-2011, 10:59 PM   #7
omiotek
Member#: 272090
SGM
some painted parts
p://i905.photobucket.com/albums/ac253/boosted106/photobucket-3640-1321589176022.jpg[/IMG]
sorry for the crappy pics cant seem to get good enough light... will get some more when i finish the ac compressor.
Old 12-18-2011, 11:00 PM   #8
omiotek
Member#: 272090
SGM
andy from zealus(ript) interiors has been awesome to deal with. i was not happy with the previous color match he had sent me and he was more then pleasent at helping me find and sending me samples and what not. needless to say we got something REAL close to the sti seats.
out with the old and in with the new
also got my headlights apart today(glass lenses)
Old 12-18-2011, 11:00 PM   #9
omiotek
Member#: 272090
SGM
more painted parts
grimmspeed master cylinder brace
my ej251 block with complete sti internals.
shot of the cylinder head.... other one looks exactly the same lol..... cleaned up. mild porting and delta 1500 cams
ac compressor finished up so you get the idea with the black pullies on there with the color i chose for the engine and waht not.
Old 12-18-2011, 11:03 PM   #10
omiotek
Member#: 272090
SGM
ACT Street Cluthc
ACT Street - Lite Flywheel
Smoked Fender Markers
progress from today and yesterday.
ARP Headstuds Installed
Old 12-18-2011, 11:04 PM   #11
omiotek
Member#: 272090
SGM
got the motor all masked up and ready for wire brushing(ignore the purple valve cover....its a spare i used to test a color for the woman)
you can see the top portion i did compared to what it was previously.
started prepping the headlights for the retrofit project..... paint doesnt like to stick to chrome sound i made it a task to rid of it totally
before
after
Old 12-18-2011, 11:05 PM   #12
omiotek
Member#: 272090
SGM
more progress
finished cleaning up the underside of the block and heads.
alllll clean!
all prepped cleaned and final taped
primer
painted!
Old 12-18-2011, 11:06 PM   #13
omiotek
Member#: 272090
SGM
test fit pictures with my sti blues and zero drifts rails. another update coming in a couple hours.
Old 12-18-2011, 11:07 PM   #14
omiotek
Member#: 272090
SGM
painted the 11mm oil pump
painted the gates tensioner pulley
painted the gates water pump
got some parts from ajw today... grimmspeed crank pulley and phenolic spacers
Old 12-18-2011, 11:07 PM   #15
omiotek
Member#: 272090
SGM
couple better pics of the block
Old 12-18-2011, 11:14 PM   #16
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
WOW, never saw anybody paint a motor like that on a Subaru. Just wondering, why did you paint the timing belt tensioner?
dexterous is offline   Reply With Quote
Old 12-18-2011, 11:24 PM   #17
omiotek
Member#: 272090
SGM
in all honesty because if i pulled the timing cover ever and i saw a casted aluminum piece i would shoot myself in for not painting when i painted everything.
i know your not going to see it. the bushings, the pulley and what not where all completely masked up so none of that got painted just the tape you see in the pics..its little details like that to me that count and even though it wont be seen it took me a whopping 5-10 minutes of prep work and masking to just do it and make everything colored rather then leaving that one silly piece the aluminum color.
Old 12-19-2011, 12:05 AM   #18
Dpwhitehead1
Member#: 139996
2016 Silverado 1500
Deep Ocean Blue
looks good so far! i like it!
Dpwhitehead1 is offline   Reply With Quote
Old 12-19-2011, 12:16 AM   #19
omiotek
Member#: 272090
SGM
thanks
Old 12-19-2011, 12:54 AM   #20
LiCelsior
Member#: 182551
2004 STi
whew that is a lot of work! but damn i love builds like these. great job man.
LiCelsior is offline   Reply With Quote
Old 12-19-2011, 10:00 AM   #21
omiotek
Member#: 272090
SGM
thats for the compliments... the goal was to do this build on a budget but without cutting corners and doing it the way i wanted. i didnt give myself a budget because i know the budget rule too well and it usually goes over by 30-50%. also im not afraid to pass up good deals on certain parts like the moroso pan and pistons and stuff so ive spent some more money then what would of normally of been seen in a budget build but its going to be the car i want. thanks for the compliments
Old 12-19-2011, 12:28 PM   #22
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Looking Good! Your block color choice reminds me of the Legacy SS build I did a few years ago.
http://forums.nasioc.com/forums/show...light=crap+box
Im totally on the same page with your statement of doing a budget build without cutting corners.
dangerousatom is offline   Reply With Quote
Old 12-19-2011, 12:45 PM   #23
omiotek
Member#: 272090
SGM
thanks man ill check it out when im off work.
Old 12-19-2011, 12:45 PM   #24
Dpwhitehead1
Member#: 139996
2016 Silverado 1500
Deep Ocean Blue
i am plagued with that issue.
even if i am broke, if i find a good deal, i find a way to get the money so i would save 100+
Old 12-19-2011, 02:36 PM   #25
omiotek
Member#: 272090
SGM
exactly that how i look at it... i save money where i can but depending on the part i dont feel like skimping.
yeah ive built more cars then this so ive learned. the cobalt that made octobers issue of modified magazine is mine, then i have a drag car too. this is my first scooby do though lol. ive been around the cars a long time just never actually owned one.
My Supercharger Build Skidd Normally Aspirated with bolt-on Forced Induction Powertrain 150 09-08-2011 12:40 AM
WTB : Omiotek WTB Thread(motor parts) omiotek Private 'Wanted' Classifieds 3 09-06-2011 01:46 PM
VIsubi's Raptor Supercharger build LetItSnow Normally Aspirated with bolt-on Forced Induction Powertrain 57 02-12-2011 08:11 PM
A supercharger build with actual power(Not Mine) ToneWrx02 Normally Aspirated with bolt-on Forced Induction Powertrain 15 01-31-2011 04:09 PM
What's needed to tune supercharge build on a 2.2L? NC_OBS Normally Aspirated with bolt-on Forced Induction Powertrain 1 05-06-2009 03:00 PM
