Welcome to the North American Subaru Impreza Owners Club Wednesday November 13, 2019
Old 05-04-2004, 09:22 PM   #1
Farabomb
Member#: 36534
96 GC8 Panda L
00 GM6 Silver
Default 96L Rear disc conversion
Car: 96 2.2L 5-sp non-ABS w/WRX front rotors/calipers
Donor: 03 WRX wagon
Three questions:
1: Can I reuse the axles from my non-ABS L in the swap or do I have to get new axles. I'm pretty sure I can't use the WRX wagon axles.
2: What parking brake cable do I need?
3: What about the brake proportioning? I see lots of posts about the ABS versions but little about the non-ABS.
Thanks.
Farabomb is offline   Reply With Quote
Old 05-05-2004, 12:06 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
1: yes.
2: the one attached to the disk brake hub, in your case wrx wagon
3: dunno
Old 05-05-2004, 01:41 AM   #3
Farabomb
Member#: 36534
96 GC8 Panda L
00 GM6 Silver
Thanks for the reply.
I'm going to have to order one. The lines are clipped so I'll have to order one.
Old 05-05-2004, 02:18 AM   #4
redwagon
Member#: 2181
2003 Forester XS
You may find this helpful.
Yes, the driveshafts will fit.
You need disk brake Impreza e-brake cables, any one will do. Legacy ones are way too long.
AFAICT the prop valves are the same.
As you aren't using the ABS sensors, either leave them installed in the backplate and crop the lead, tie it somewhere out of harms way, or block the hole off. You want to try and keep the muck out of your e-brake
Oh, the disk brake hoses are different also.
redwagon is offline   Reply With Quote
Old 05-05-2004, 03:32 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
i did not find this to be the case they fit just fine ..??? wacky ledgend of some sort..
Old 05-05-2004, 06:18 PM   #6
Farabomb
Member#: 36534
96 GC8 Panda L
00 GM6 Silver
Yea, kinda like the RS rear sway bars are bigger than the ones on the L.
I'll probally order or find cables lying around the shop. I allready have the SS line kit for the WRX. The ABS sensors are there and clipped .5in from the sensor.
Old 05-05-2004, 07:04 PM   #7
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
The ABS hubs will work fine. Just clip the sensor lead wherever you like -- the tone wheel can stay in there and doesn't bother anything. Otherwise treat it just like any other non-ABS disc brake hub.
As for the parking brake cable, I tried a Legacy cable and it was too long. You can tie a knot in the exposed part of the cable, clip the sheath and shorten it that way, but these are your emergency brakes and you're getting new cables anyway so I'd just go down to the Subaru dealer and order up a set of GC disc brake cables...
Necromancer is offline   Reply With Quote
Old 05-05-2004, 08:40 PM   #8
Farabomb
Member#: 36534
96 GC8 Panda L
00 GM6 Silver
Thanks a bunch guys.
Now if only I could find a damn WRX engine bulkhead harness.
Old 05-06-2004, 12:00 AM   #9
redwagon
Member#: 2181
2003 Forester XS
Maybe the cables were routed differently on some model years..
FS SoCal: LGT front brakes, LGT rear brakes. Ver. 4 rear disc conversion (complete) DiscoWagon Suspension/Brakes/Handling 34 10-26-2006 05:46 PM
Rear disc conversion how-to wac Brakes, Steering & Suspension 4 04-17-2001 08:32 AM
rear disc conversion pornie Brakes, Steering & Suspension 4 04-10-2001 07:44 PM
Parts for rear disc conversion! Should I bring? webkris New England Impreza Club Forum -- NESIC 11 02-21-2001 05:01 PM
rear disc conversion for 95 L ins8ibl New England Impreza Club Forum -- NESIC 4 09-04-2000 09:00 AM
