Welcome to the North American Subaru Impreza Owners Club Tuesday November 12, 2019
Old 04-21-2005, 12:05 AM   #1
othon
Member#: 18440
2004 WRX Wagon
Always need moar grip!
Default "Silver Sleeper"
Looks stock and that way OK with me. "Cause its inside that counts!"
::ENGINE::
Cobb Stage 2 California 91 oct.
Perrin Turbo Inlet hose
Perrin Intercooler hoses
Perrin radiator Shroud
K&N panel filter
Drilled the bottom of the stock air box
Ported Y intercooler inlet ports "DIYM"
Stock header with Heat Shield flanges and mounting points cut off and HEAT RAPPED
Invidia Uppipe HEAT RAPPED
PDE Down-pipe HEAT RAPPED
5 zigen Fireball cat-back Exhaust (FREEBEE)
::CHASSIS::
Tein FLEX - Front Spring Rate: 560 lbs/in :: Rear Spring Rate: 450 lbs/in
Front Reb/Damp: @ 9 clicks out from full hard
Rear Reb/Damp: @ 9 clicks out from full hard
Alignment settings::
Front camber 1.2 degrees +/- .5
Rear camber 1.5 degrees +/- .5
Front caster 3.75 degrees +/- .5
Toe +/- .5 all around
Cusco Front Anti-Sway bar
Cusco Rear Adjustable Anti-Sway Bar (set to full hard)
Cusco Lower sub-frame brace TYPE II
Whiteline Rear Anti-Sway bar hard mounts
Whiteline Rear end links
Whiteline Adjustable Rear strut tower bar (with quick release)
whiteline anti-Lift kit (sport)
Whiteline hardened steering rack bushings
::BRAKES::
Goodridge Steel lines
::ELECTRICAL::
Blitz FATT
::EXTERIOR::
Cleared head lights "DIYM"
::INTERIOR::
Kartboy shifter bushings
Window tint 34% all around
Not to toot my own horn or nothing ("toot toot") but i did my own work. [minus the alignment]
othon is offline   Reply With Quote
Old 04-21-2005, 12:17 AM   #2
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
Yes, it does look stock. Maybe you should consider getting a different muffler to keep the theme?
kennyvb is offline   Reply With Quote
Old 04-21-2005, 12:42 AM   #3
SQC120
Member#: 39677
2008 Land Rover
02 WRX
prodrive muff.
SQC120 is offline   Reply With Quote
Old 04-21-2005, 12:57 AM   #4
Bryan C
Member#: 38134
2003 WRX
Sonic Yellow
Nice, always a fan of a spotless car. Thumbs up!
Bryan C is offline   Reply With Quote
Old 04-21-2005, 12:58 AM   #5
othon
Member#: 18440
2004 WRX Wagon
hehe.. i got that muffler for free from an old friend.
The new PDE cat back is angled out like alot of the other ones out there like the RS-R Exmag GTII Exhaust, but has an angled oval tip to help make it look like the 05 single tip stocker.
Old 04-21-2005, 01:08 AM   #6
spooledwrx
Member#: 73611
And different tires....at least better ones than the RE-92's.
spooledwrx is offline   Reply With Quote
Old 04-21-2005, 01:14 AM   #7
othon
Member#: 18440
2004 WRX Wagon
Oh yah im with yah on the better tires for sure.
I just want to kill the stockers first. Then thinking of getting some Toyo Proxes 4.
I have them on my 02 special editon MX-5 AND LOVE THEM.
Old 04-21-2005, 04:29 AM   #8
markadopolus
Member#: 69586
just a suggestion, put the center caps back on the rims. They are there for a reason. You dont want too much dirt to get in there.
markadopolus is offline   Reply With Quote
Old 04-21-2005, 05:16 AM   #9
disaster999
Member#: 73197
^^ agree! they look a lot better with them on
disaster999 is offline   Reply With Quote
Old 04-21-2005, 09:37 AM   #10
wrx2k4blue
Member#: 59048
2005 Black S60R
w/ 18" Modas & Sport Body
Borla Hush for the axelback. You'll look way stock
wrx2k4blue is offline   Reply With Quote
Old 04-21-2005, 10:32 AM   #11
MR. STi
Member#: 69645
definitely a sleeper
MR. STi is offline   Reply With Quote
Old 04-21-2005, 10:34 AM   #12
SubyDuz
Member#: 80432
69 IchhateinAudi
Blutrot
nice suspension mods, now just crank the motor up to 300awhp and now were talkin sleeper , but other than that really nice clean car I like it.
SubyDuz is offline   Reply With Quote
Old 04-21-2005, 10:40 AM   #13
missdawn
Member#: 27369
2008 RED STI
74 IggPoints, no salt!
Beautiful job!
Do you have a little bit of tint on your windows?
missdawn is offline   Reply With Quote
Old 04-21-2005, 10:49 AM   #14
perkowskiforpope
Member#: 50618
2004 Crawford S2
FPgreen PSM Wagon
nice i got the same kind of sleeper theme on my 04 wagon but its running a VF22 and some wheels that surprises people. I like the cleared out headlights, how'd that mod go for you i've been trying to convince myself to do it for a while now.
perkowskiforpope is offline   Reply With Quote
Old 04-21-2005, 02:43 PM   #15
gasnutz
Member#: 85554
nice wagon!
gasnutz is offline   Reply With Quote
Old 04-21-2005, 02:59 PM   #16
flicky30
Member#: 74117
2004 VW R32
Black Metallic Pearl
Very impressive. Thank you for making it the epitome of cleanliness.
and yes, new tires asap.
flicky30 is offline   Reply With Quote
Old 05-29-2005, 07:19 PM   #17
othon
Member#: 18440
2004 WRX Wagon
Here some pics of the sleepers innards...
The Stock header with all the heat sheild flangs and mounting points all cut off and all rapped up
Rapped Invidia Uppipe
Rapped up header and start of uppipe
PDE downpipe rapped up as well...
Old 05-29-2005, 07:51 PM   #18
ydant
Member#: 43447
2009 STI
The Good Grey
Looks really nice. Not sure about the "stock" look, though - that muffler kinda stands out.
ydant is offline   Reply With Quote
Old 05-29-2005, 09:41 PM   #19
jarelee
Member#: 31506
05 Tacoma on TE37'
damn.....alot of heat wrap there, hahaa. just needs some simple rims.
jarelee is offline   Reply With Quote
Old 05-29-2005, 10:32 PM   #20
wReXeRw
Member#: 19542
05 GSX-R 1000
02 WRX Gold
sure is a sleeper, good stuff.
wReXeRw is offline   Reply With Quote
Old 05-29-2005, 11:39 PM   #21
NWWagon
Member#: 66769
05 Focus "ST"
'80 Honda CM400T
To be an even better sleeper ditch the "Can" and swap it out for a Borla Hush, then that'll really keep them wondering.
NWWagon is offline   Reply With Quote
Old 05-30-2005, 12:37 AM   #22
popcrux
Member#: 85829
2005 WRX Wagon
CGM
Very nice stuff. Only problem is that 5zigen cat-back. Get a twin-tip back there and you'll be flying under everyone's radar.
popcrux is offline   Reply With Quote
Old 05-30-2005, 12:50 AM   #23
wrxpaul
Member#: 83600
03 wrx wagon
Is there much of a benefit from the k&n oil filter?
wrxpaul is offline   Reply With Quote
Old 05-30-2005, 11:31 AM   #24
othon
Member#: 18440
2004 WRX Wagon
Intresting that you might ask that.......if i remember correctly and
( I DONT WANT TO START SOME DAMNED OIL "TAG YOUR IT" REPLY SESSION FROM THIS!!!)
But the K&n is a little bit bigger so that means more filter element and flows a little faster then stock some where around 7-10 psi more so when you flying at 5000 rpm the oil is moving just that little bit better.
It still has the same bypass value as the stock one and a spiffy nut attached to the bottom for super easy removal
Old 05-30-2005, 11:37 AM   #25
othon
Member#: 18440
2004 WRX Wagon
HEHEH yah it does huh??
Well its was a free hand me down from a friend that got rid of his suby.
So i wanted to keep the hope alive.
but im trying to figure out what im gonna do for a new catback maybe custom.
The Project "Silver Sleeper" Journal Dasani Member's Car Gallery 100 08-19-2019 01:47 AM
Pics of the "Silver Sleeper" STi Dasani Member's Car Gallery 99 08-09-2009 03:56 PM
Pics of the "Silver Sleeper" STi Dasani Texas Impreza Club Forum -- TXIC 42 11-11-2007 09:33 PM
"Automatic Sleeper" PSM WRX 2fast4uwrx02 Member's Car Gallery 48 07-26-2005 11:43 AM
Hey "silver boosted",......I've got an idea.... 944 turbo guy Mid Atlantic Impreza Club -- MAIC 1 01-09-2004 08:15 PM
