Welcome to the North American Subaru Impreza Owners Club Wednesday November 13, 2019
Old 08-29-2005, 09:49 PM   #1
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
Default IAC hook up? 2.2 harness(3prong)2.5 iac(6prong)
i have a 98 impreza L(2.2L). i have a 2.5L engine swapped in. i still have the 2.2 ecu and harness. running 2.5 engine. the IAC on the 2.5 is a 6 prong, but the 2.2 harness is a 3 prong plug. does ne one know how to hook them together without changing the ecu?(that would be the obvious most expensive way)
farrell is offline   Reply With Quote
Old 08-29-2005, 10:18 PM   #2
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Is the 2.2 IAC on the throttle body or on the intake manifold?
Old 08-29-2005, 10:45 PM   #3
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
throtle body
Old 08-29-2005, 11:29 PM   #4
JoshP
Member#: 94350
use the 2.2 TB, you may have to make a shim for it.
JoshP is offline   Reply With Quote
Old 08-29-2005, 11:51 PM   #5
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
dont have the 2.2L throttle body. and cannot find the one i need.
Old 08-30-2005, 02:12 AM   #6
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Well you need to find one or it wont work.
Old 08-30-2005, 12:04 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
i concur or use the 2.5 ecu/harness
Old 11-14-2005, 11:28 PM   #8
flat_iv
Member#: 56248
Farrell, Did you ever figure it out?
flat_iv is offline   Reply With Quote
Old 11-15-2005, 11:06 PM   #9
rabbitnutz
Member#: 51940
farrell: far as i know, you need to use the 2.2 TB, and make a block off plate for the port on the RS intake manifold(for the IAC)...that's all i've got.
rabbitnutz is offline   Reply With Quote
Old 11-15-2005, 11:18 PM   #10
flat_iv
Member#: 56248
What about a 1.8 TB? The IAC is on the TB, 3-wire and its the same bolt pattern as a 2.2.
98 2.2-> 01 2.5 iac solution? farrell Subaru Conversions 1 10-03-2009 02:39 PM
5/4 channel amp question w/ hooking up sub kirkeemonster Car Audio, Video & Security 11 11-19-2007 03:17 PM
Can You Hook Up a 6 Wire Fac Sub to a 5 Wires Set Up? AliBenn Car Audio, Video & Security 7 04-27-2007 02:54 AM
ok.. so i just hooked up w/ 2 girls.. Sauceboy01 Off-Topic 36 05-14-2004 06:55 PM
2.2 ECU on 2.5 motor.. IAC valve problem Murray Engine Management & Tuning 6 12-31-2002 12:01 AM
