Welcome to the North American Subaru Impreza Owners Club Tuesday September 17, 2019
Old 08-01-2019, 06:44 PM   #1
pcampbell
Member#: 437670
2005 2.5 SC OB
Default Cyl 1 misfire - changed plugs ,wires, coil
I have a supercharged ej253 which misfires on cyl 1 only above 5500rpm and 10psi (this is a WOT pull). I have swapped plugs with cyl 2 (no change), wire on cyl 1 (no change) and coil (no change).
Any ideas on what to try next? Compression is good, have not done leak down. Have also not tried swapping injectors left/right, etc.
It does not misfire at light load/high rpm.
WOT PULL LOG here. It's running a bit rich right now but the misfires were happening earlier.
https://drive.google.com/open?id=0By...JzNndnMnlVY0pJ
pcampbell is online now   Reply With Quote
Old 08-02-2019, 01:15 PM   #2
pcampbell
Member#: 437670
2005 2.5 SC OB
Gapping tighter seems to make the problem occur at higher RPM and higher boost level which makes me hopefully that going even tighter will make it go away. But I don't understand why it is cyl 1 only.
Old 08-02-2019, 06:03 PM   #3
pcampbell
Member#: 437670
2005 2.5 SC OB
Ok nevermind the plug gap isn't fixing it. I am back to being confused. Going to try swapping injectors next.
I need help with this but I think the fact that it only happens > 5500rpm and 10+psi is an indicator of something, I just don't know what exactly.
Old 08-02-2019, 08:04 PM   #4
pcampbell
Member#: 437670
2005 2.5 SC OB
I added 1 new ground strap today and ordered 3 more to install next week. I will try swapping #1 and #3 injectors.
Old 08-08-2019, 03:00 PM   #5
pcampbell
Member#: 437670
2005 2.5 SC OB
Still no luck...
Old 08-08-2019, 06:00 PM   #6
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
What's the compression and leak down numbers on all cyls? How's the valve lash?
yarrgh is offline   Reply With Quote
Old 08-09-2019, 07:42 AM   #7
pcampbell
Member#: 437670
2005 2.5 SC OB
Thanks. Compression was (cold):
1,3,2,4: 187,190,200,195
Leakdown on 1 was very low like 2% but Iíll check again on other cylinders.
These are not very high quality gauges so I am sure these some room for error in the compression numbers but the idea is there.
I have not checked valve lash adjustment yet although the heads and were done 15k miles ago, hopefully done correctly then but you never know. Do you think that would cause a high rpm high load misfire ? Thereís a decent amount of room to remove valve cover when I remove the SC so maybe that is next.
I should note that itís not strictly at 5500 plus. I might be at 5000rpm but only under WOT. At lighter throttle / load itís fine.
Old 08-10-2019, 02:07 AM   #8
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Did you swap injectors around yet?
CosmoTheCat is offline   Reply With Quote
Old 08-10-2019, 05:34 AM   #9
pcampbell
Member#: 437670
2005 2.5 SC OB
Yes sir, I swapped 1 and 3 including the pigtail for the Bosch injectors. Ecu still says misfire on 1 and only 1.
Old 08-11-2019, 10:55 AM   #10
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Could be valves getting burned, you can check if a valve guide has started to migrate.
Old 08-11-2019, 07:03 PM   #11
pcampbell
Member#: 437670
2005 2.5 SC OB
Hmmm how do I see that? Is it something you can see without dismantling? Look through exhaust port?? Wouldnít that affect leak down test results too?
Old 08-18-2019, 02:08 PM   #12
Freon-Peon
Member#: 505152
Are you getting any oil residue on the plug/wire? I had this happen due to valve cover gasket failure fouling the connection.
Freon-Peon is offline   Reply With Quote
Old 08-21-2019, 06:59 AM   #13
pcampbell
Member#: 437670
2005 2.5 SC OB
No oil that I can see. The spark plug tube seems dry.
Old 08-23-2019, 07:37 AM   #14
pcampbell
Member#: 437670
2005 2.5 SC OB
Going to check valve lash. Maybe it is a tiny bit tight.
