Welcome to the North American Subaru Impreza Owners Club Sunday October 20, 2019
Old 01-06-2009, 04:04 PM   #1
Z3RO
Member#: 87542
2002 Bugeye
Default Does anyone have the wiring diagram for an 04 Sti cluster?
yes, I know theres thread (q356215374124123 of them) but none actually have a step by step process for an 04 Sti cluster into an 2002 WRX
everyone says the 04 cluster is a direct PNP ..WRONG!!!
and I been searching for about an hour now.
Z3RO is offline   Reply With Quote
Old 01-06-2009, 04:13 PM   #2
JavaBot
Member#: 156723
17 2.5i foz dgm
rip wrx/rs/2.5i/foz1
I think it is direct pnp but you have to cut off/file a tab on the new cluster plug so the pin can actually plug in. Try that, use pics from other threads. Hope it helps.
JavaBot is offline   Reply With Quote
Old 01-06-2009, 04:43 PM   #3
Z3RO
Member#: 87542
2002 Bugeye
thats the thing 04 cluster requires no cutting at all.. I had a short in the MIDDLE connector which is supposed to be left intact according to the write ups.
Old 01-06-2009, 04:49 PM   #4
JavaBot
Member#: 156723
17 2.5i foz dgm
Are you sure there was a short? I thought that you had to file a little plastic tab off the connector to actually make it fit into oem connection. Nothing to do with the actual wiring, but I'm not sure on all that so I would examine the two side by side and see if you can find a difference...
GL
Old 01-06-2009, 05:36 PM   #5
Z3RO
Member#: 87542
2002 Bugeye
heres the 2002 WRX cluster and 2004 Sti cluster .. NO CUTTING is required to connect the plugs on an 04 Sti cluster. However, the connectors are upside down on the Sti cluster as opposed to the wrx cluster.
So I turned the connectors upside down on the wiring harness..connected them, turned on the car and got a burning smell.
THESE ARE THE (2BURNED CONNECTIONS \/ \/ \/ \/
I need to know where these go.
Old 01-06-2009, 06:02 PM   #6
JavaBot
Member#: 156723
17 2.5i foz dgm
hmm thats very clear now. I wonder if you should have flipped all three? Perhaps when you flipped the 2 they then rerouted some of the pins back to a ++ or -- on the center plug to cause the short. I see it now, and honestly I'm not sure because I don't have direct experience with cluster work but maybe you have to flip the 3rd plug to keep all the circuits working the same direction. Thats all I've got my friend so I'll stay quiet now, but subscribed because I'm interested to know what you come up with. GL keep us posted
Old 01-06-2009, 06:10 PM   #7
Z3RO
Member#: 87542
2002 Bugeye
all three plugs were flipped...I need the diagram to see what those pins are.
Old 01-06-2009, 06:56 PM   #8
JavaBot
Member#: 156723
17 2.5i foz dgm
Cougar where you at!! haha someone help this man out!
Does anyone have cam gear wrenchs for an 05 STi near Sanford Fl 1/500yellowwrx South East Region Forum 8 10-16-2008 08:55 PM
Does anyone have a wiring diagram for a Kenwood WooX subwoofer ashwinearl Car Audio, Video & Security 4 02-28-2005 04:39 PM
Does anyone have the wiring diagram for the stock headunit? sbrcr267 Car Audio, Video & Security 0 09-16-2003 09:04 PM
does anyone have morette wiring diagram woohoosbru Electrical & Lighting 8 05-06-2003 06:39 PM
Does anyone have The wiring diagram for a wrx wagon??? GOsh General Community 3 02-22-2002 04:43 PM
