#1 |
Member#: 211648
![]() There's a lot of information scattered about, but maybe having a master thread for what people are running/able to get may be a good source of information for those looking to dial their cars in.
Here's what we were able to dial in to: ![]() Thanks to HG Motorsport for the great work! All units in Degrees unless specified otherwise: FL: -1.5 FL Caster: 6.2 FL Toe: 0.05 SAI: 16.2 Included Angle: 14.8 FR CAmber: - 1.5 FR Caster: 6.0 Toe: 0.04 SAI: 16.1 Included Angle: 14.6 Cross Camber: 0 Cross Caster: 0.2 Cross SAI: 0.1 Total Toe: 0.09 RL Camber: -1.8 RL Toe: -0.06 RR Camber: -1.8 RR Toe: -.0.05 Rear Cross Camber: - 0 Rear Total Toe: -0.11 Rear Thrust Angle: -0.01 Hopefully this helps some folks out. Staggering the stock tire pressures at 36-40 helps with rear end rotation and front end grip. Car handles great with these settings we think!
#2 |
Member#: 406693
Vehicle:2015 WRX ice silver |
![]() Mine is simple:
Full negative front camber -- no point in measuring, I want it all regardless. 1/8" toe out front, zero toe rear. Nothing else is adjustable so measurements are moot. Tires (255 RS3's) 40/40. I wanted less front but the pyrometer said no. I'll eventually check out 1/8" rear toe out, but I'm happy for now. |
#3 | |
Member#: 211648
![]() Quote:
#4 |
Member#: 406693
![]() Yes on the 40 series. Can't say about more push because I started at 40/40 and the outer tread edge was way hotter than the rest of the tire, so I never even tried lowering the pressure. But I really had no push complaints except for a specific type of corner where I was coming in fast and then a decreasing radius turn. That sometimes caused a judder as I tightened the radius. I was able to change my line to drive around it.
#5 |
Member#: 100271
South East
![]() I just dialed in some negative camber on the front and set the toe to zero. Before my car would follow the crown with the road, now it still does. Justaddnos, does your car follow the crown of the road? I'm wondering if setting some toe out would help or hurt with turn-in.
#6 | |
Member#: 211648
![]() Quote:
#7 |
Member#: 164043
Vehicle:2015 WRX and FozzyXT White |
![]() so the only 2015 WRX adjustable settings are toe front and rear and front camber?
#8 |
Member#: 151461
Vehicle:2015 Forester / WRX QBP / GBP |
![]() Should be front and rear toe are adjustable and front camber.
#9 |
Member#: 280577
Vehicle:2017 WRX Limited Pure Red |
![]() Is there a writeup on how to make these adjustments?
#10 |
Member#: 338312
![]() i have -1.5 in the rear left and -2.18 in the rear rigth with rce yellow spring , This can be a problem? I made 2 alignments and the problem persists. Everything is properly installed. any help? or i need lca ? 2015 wrx.
#11 |
Member#: 164043
![]() this was the first thread i found in my search, and ive posted in it before.. lol
installed my 1" lift today. I plan to get my camber and toe adjusted. I didnt know the back had a toe adjustment also. But the real issue is caster. I lost some by lifting an inch. Prob lost 2-3 degrees of positive caster. I can't beleive there is no way to adjust it, ASIDE from getting the new fancy adjustable top hats. I wish someone made fixed length 3mm longer lower control arms like they sell for JK Wranglers. That would being me back perfect with a simple install. The lift video for kicks.. |
#12 | |
Member#: 421271
Vehicle:2015 WRX Galaxy Blue Pearl |
![]() Quote:
#13 | |
Member#: 484302
![]() Quote:
#14 |
Member#: 233053
![]() Any suggestions for front and rear toe for crowned roads? Having a lot of tramlining on the highway here in Florida but the roads have deep groves from trucks. Getting some tramlining but the alignment tech says the alignment is "within spec". That might be true because of the spec range but not necessarily the best settings.
