Welcome to the North American Subaru Impreza Owners Club Sunday November 18, 2018
Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 08-10-2018, 09:49 PM   #1
WYSubaru
Member#: 154884
2005 Baja turbo
Default 09' Forester 2.5XT LTD known issues?
Looking at getting our daughter a 09' Forester 2.5XT LTD. The dealer that has it is having a new turbo installed because of leaking seals. Are there known issues with this vehicle? It was a one owner I believe and it has 129,000 miles on it.
WYSubaru is offline   Reply With Quote
Old 08-15-2018, 12:13 AM   #2
ProjectXT
Member#: 483233
09 is a good year, eventually you have to replace the turbo on all of these, 129k is about right.
ProjectXT is offline   Reply With Quote
Old 08-22-2018, 08:03 PM   #3
WYSubaru
Member#: 154884
2005 Baja turbo
We went and test drove it today and upon moderate to heavy acceleration there's a loud whistling noise. The dealership said that is normal noise for a turbo. I brought up the fact our 05' Baja turbo doesn't make that noise and he said its a different engine and the newer ones make the whistling noise. Any truth to this?
Old 08-24-2018, 11:49 PM   #4
WYSubaru
Member#: 154884
2005 Baja turbo
These are the Subaru's we're looking into.
1- 06' Outback 2.5XT Limited(122K)
2- 09' Forester 2.5XT Limited(129K)
3- 06' B9 Tribeca Limited 7 passenger(121K)
4- 2006 Subaru Outback 3.0 R L.L.Bean Edition(153K)
Any one better than the other?
Old 08-30-2018, 03:28 AM   #5
Jess06foresterBEAN
Member#: 490817
The car that whistles has a blow off valve that accentuates the sound. Itís like cosmetics for the sound and a little bit of increase in horsepower. Itís not a bad thing - your daughter is lucky to get this car, especially if the dealership is replacing the turbo.
Jess06foresterBEAN is offline   Reply With Quote
Old 08-30-2018, 03:34 AM   #6
Jess06foresterBEAN
Member#: 490817
Yes, the 09 Forester XT is the best out of the ones you are looking at. All should have the head gaskets redone at about 100k miles. When I bought mine in Nov Ď16 she had 101k and the dealer had just redone the head gaskets along with polished the heads and replaced the water pump.
Old 09-04-2018, 11:50 PM   #7
Fndragn
Member#: 470845
04 Fxt
There is absolutely nothing that says you need to change headgaskets at 100,000 miles. Timing belts need changed then. A blow off valve releases pressure and makes no noises on exceleration, just the opposite actually.
Anyhow, are these at a Subaru dealership? If not I’d higher recommend getting a PPI from an independent Subaru shop.
How old is she? If she’s young I wouldn’t encourage 7 passengers
The 06 outback 3.0 is honestly the best for a lower maintenance car. I have 3 turbo Subaru’s and they require ALOT of maintaining. If your paying someone to do that work you better have a lot of cash ready.
Fndragn is offline   Reply With Quote
