01-17-2014, 02:02 PM | #451 | |
Member#: 117767
RMIC
Vehicle:2014 Audi S4 DP Stage 2 (~420whp) |
... Sadly, I'm not surprised that people do this.
01-17-2014, 02:05 PM | #452 | |
Member#: 361325
E. Canada
Vehicle:2010 STi Dark Gray Metallic |
Nice. |
01-17-2014, 02:28 PM | #453 | |
Member#: 356246
Vehicle:2013 STI Plasma Blue |
Thanks Clark. Your tune was great. It's been below zero to twenty degrees the past month in Chicago, so I'm not sure it's worth it to tune at the moment. I don't want to datalog in this weather. Although I suppose I could always just use a COBB LWG Map until it warms up in spring. At this point I'm not super worried about my warranty, because it's probably gone. I can't imagine getting anymore warranty work done given my engine blew at 5.7k miles on a brand new car. If anything else engine related goes I'm certain an SOA engineer will be brought in to scrutinize my ECU. I'd say "I should have bought an EVO" but I do not want an EVO! I test drove both and prefer the Subaru. And even then I'd just be swapping engine weaknesses for transmission weaknesses. |
01-17-2014, 02:32 PM | #454 |
Member#: 370658
NWIC
Vehicle:07 Hawkeye STI Black |
2011 STI stage 2 w/ catless tbe, cai, dw65c fuel pump and a pro tune. Noticed a knocking noise just like the op. Car runs and feels healthy..just knocking when reving around 3,000 rpms. I do drive the car pretty hard sometimes but take care of it. Oil is good no cel...what ya guys think??? New internals??? This is all happened as of last night this morning :/
01-17-2014, 02:44 PM | #455 | |
Member#: 117767
RMIC
Take some logs and send them to your tuner. He will obviously know more than we will and can probably make some adjustments to the tune. |
01-17-2014, 02:53 PM | #456 |
Member#: 370658
NWIC
I was gona do that...will data logs show a bearing is on its way out though??
01-17-2014, 02:57 PM | #457 |
Member#: 117767
RMIC
A datalog won't directly indicate if something is failing on the engine but it will give some good insight as to what is going on, especially to your tuner. Send the logs to your tuner and see what he says.
How much knock are you seeing? Is it at a consistent RPM every time? If you are really that concerned with it, go get a compression/leak down test. That's the only way you will know with certainty that your motor is healthy or on its way out. But I think this would be jumping the gun. Talk to your tuner. |
01-17-2014, 03:42 PM | #458 |
Member#: 370658
NWIC
Emailing him right now..seeing what he wants me to do. Im just preparing for the worst..I had plans to do an internal build with a 20g turbo just not under thses circumstances. I was gona take it to Subaru but i know there gona tell to F*** off cause the car is moded and pro tuned. Lets see what Clark Turner says.
01-17-2014, 06:29 PM | #459 |
Member#: 321321
Vehicle:2010 Ford SVT Raptor Tuxedo Black |
Clark will say the same thing as above. The Internet can only tell you so much. As above, email and work with your tuner, a log can only tell you so much. The only way to know what is mechanically wrong with an engine is a physical test. Compression and leak down will give you first hand knowledge where your engine is at.
Anything you are asking here is pure speculation. Best thing you can do is save up for the worst case scenario. |
01-17-2014, 08:48 PM | #460 |
Member#: 178047
SWIC
Vehicle:02 WRX STI Spec C Black |
Yeah... If its making noise, I would not drive it. Really, I would need to hear what noise it is before I could give any solid advice, Could be a noisy cam bucket, Or a failed tensioner. Its also possible its a rod bearing. Lots of 2013's failed with rod bearing issues. Most of which I believe are the result of a E-tuner. Light load knock will trash your bearings quick and that tuners map had 10 full degrees added over a stock timing map so the car is over advanced as you just drive to work and cruise knocking the hell out of the bearings.
There are lots of causes guys but the main thing is that the pistons are weak and anything out of the norm can damage them. |
01-18-2014, 03:02 AM | #461 | |
Member#: 219558
2011 same thing
01-19-2014, 12:20 PM | #462 |
Member#: 329884
SCIC
Vehicle:2012 WRX Limited 5dr Ice Silver Metallic |
I have a 2012 WRX and I too just had my short block and all of its components replaced due to engine knock at 20,500 miles. Now I'm 100 miles into the "break-in period" any suggestions other than a tune? After having an XT blow and now my WRX I wouldn't even think about voiding my warranty.
01-19-2014, 12:30 PM | #463 | |
Member#: 3251
NWIC
Vehicle:2009 WRX Hatch DGM |
01-19-2014, 10:32 PM | #464 |
Member#: 370658
NWIC
Im tearing my car apart as we speak and doing a rebuild..its bona be a beast after its done. I think the older STIs are stronger..I don't think the 2008 STI + have the same quality.
01-19-2014, 10:42 PM | #465 | |
Member#: 258857
South East
Vehicle:2012 Subaru WRX DGM |
01-20-2014, 08:44 AM | #466 |
Member#: 337158
South East
Vehicle:14 sti hatch white |
I'd be curious to see if Cobb has run any of these stock tune AFR/Boost graphs on the newer (12,13 or 14) STI's. Didn't the factory send down a flash a couple times after the 11MY? |
10-18-2014, 02:42 AM | #467 |
Member#: 56219
NESIC
Vehicle:2011 WRX STI Limited SPW |
I am back. Only to report how the car is going AFTER I sold it. The next owner is still getting terrible gas mileage and chewing up the tires. However he is beyond happy with it. Even though it gets the fuel economy of a dodge ram it is running perfectly. I am only following up to let anyone know how this went. I personally think most people on this forum are fantastic, wonderful even . But thanks to the complete jerk offs that just want to argue and start fights I haven't logged in in over a year. So for any of you that read this thread and actually contributed in a positive manner. Thank you. People may even learn form this. for all you others, kill yourself. No ONE joins an enthusiast forum to be called names and have some keyboard tough guy run their mouth. The STI is a overpriced disaster in stock form. SOA lost me forever ... I would rather buy a used Audi S4 . And I did . I bought a used 2010 S4 with 79,000 miles on the clock . I just hit 100,000 miles with ZERO tune issues. I have invested a pair of tires, $300 worth of bushings and $130.00 in gaskets and head cover bolts since I have owned it. I get 21-28 MPG .. and its beats the pants of a STI... in every category except steering feedback . In that department the STI is a complete dream. Have fun with your rattling panels, dog **** interior , pretend fender vents and your book shelf sized " wing " ..... oh an who could forget cylinder 3 ?
10-18-2014, 03:47 AM | #468 | |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
sweetie.....you better buy a lottery ticket before yer luck runs out |
10-18-2014, 02:55 PM | #469 | |
Member#: 158674
SCIC
Vehicle:'15 STi Limited DGM |
10-18-2014, 04:12 PM | #470 | |
Member#: 316364
Vehicle:2012 WRX |
I think the problem cylendars are generally #'s 2 and 4. Enjoy the Audi, but Scotty's right... that thing is going to turn into a much bigger money pit than the STi. |
10-19-2014, 12:26 AM | #471 |
Member#: 16200
10-21-2014, 08:01 AM | #472 | |
Member#: 250152
Vehicle:2006 WRX Limited OBP |
You went from mechanical nightmare to electrical nightmare... Sent from my SAMSUNG-SGH-I537 using NASIOC mobile app |
10-27-2014, 09:39 AM | #473 |
Member#: 401219
7500 miles oil change?
is 7500mile oil change schedule applicable if car is already in stage 2? using amsoil 5w30 at the moment. i don't track at the moment just occasional pulls here and there.
10-27-2014, 09:48 AM | #474 |
Member#: 358782
Vehicle:2013 STi DGM |
Plenty of people do it on T6. Get a UOA to see how its doing on that long of a schedule so you know.
Sent from my DROID RAZR using NASIOC mobile app |
10-27-2014, 12:33 PM | #475 |
Member#: 262418
Vehicle:2008 Impreza |
2008 STi Engine Blown @ 77k
Could anybody suggest where I could buy a longblock. Really disappointed with Subaru. Stock everything.
2011 STi Sedan 305/368 EFI Tuned | krotondo | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 1 | 09-22-2011 01:46 AM |
***PhatBotti Tuned: E85'ed 2011 STi, 330whp!! Per Gear Data + Tuning Discussed*** | PhatBotti Tuning TKR | Proven Power Bragging | 54 | 06-24-2011 10:58 AM |
2011 STI OTS map vs Pro tune | Jose Gordils | Newbies & FAQs | 6 | 05-09-2011 11:08 AM |
2011 STi V-Limited LIPS IN STOCK! Yeah we got them! | RallySport Direct | Vendor 'General Sale' Forum | 1 | 11-08-2010 03:03 PM |
07 STI Blown Piston or Ring? | 07stilover | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 49 | 01-25-2008 01:24 AM |
