Welcome to the North American Subaru Impreza Owners Club Friday June 22, 2018
Closed Thread
Old 03-05-2008, 01:46 PM   #1
sonic03dz
Member#: 144056
03 wrx
sonic yellow stage 2
Question Anybody running kyb agx struts & gf210 spring combo?
trying to figure out what direction to go in
Kyb agx struts or coilovers?
thanks for your input
street use
sonic03dz is offline
Old 03-05-2008, 02:01 PM   #2
QuikWgn
Member#: 108557
2003 PSM WRXWgn STG2
05 OBM LEGACY SDN
Suspension Forum (From the STICKY) Rule #4 post what you intend to use the car for...Rule #6 Don't ask us to choose between 2 parts...We don't ignore rule #4 but we bend a little on Rule #6 sometimes....
QuikWgn is offline
Old 03-05-2008, 02:09 PM   #3
sonic03dz
Member#: 144056
03 wrx
street but i like the tight suspension feel
Old 03-05-2008, 02:44 PM   #4
QuikWgn
Member#: 108557
05 OBM LEGACY SDN
I haven't run AGX's, but I just got my set of Tokico D-Specs. The AGX's are generally regarded as good struts but, they have a very limited adjustment range and get harsh on stiffer settings. The Tokico D-Specs have a lot more adjustment range and can handle much stiffer spring rates. Since you have a bugeye like me, I'll tell you that unless you decide to switch rear strut tops to the 04+ style and run the TiC spacers, the spring choices are rather limited. The GF210's in 02-03 fitment are barely stiffer than stock springs. The one's for the 04-05's are significantly stiffer. Tokico makes a specific set of springs they sell with their struts as a kit PN#DSK-513, that are almost exactly 25% stiffer than stock.
As far as coilovers, I've never run them on a Scoob, but have had several sets on high HP RWD cars. A decent set new is going to run 2-3x as much as struts/springs. The $1k and under coilovers have limited suspension travel and most find them unsuitable for a DD, unless you don't care about the ride and just want to be able to say you have coilovers for the bling factor. There are plenty of threads about the inexpensive coilovers do a search. You might find a deal on a set of used "good" struts, but it will still be a lot pricier than struts/springs.
Aside from the D-Specs, everyone seems to love Koni's, but they are an insert and you have to cut up a set of stock struts to put them in. There are a lot of threads on that option too.
QuikWgn is offline
Old 03-06-2008, 07:28 AM   #5
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
+1 Tokico( for the money)
mw
RaceComp Engineering is offline
Old 03-06-2008, 08:56 AM   #6
Butt Dyno
Street's closed, pizza boy
Member#: 17301
2016 FoST ST3
2006 Evo #17 STU
3rd thread in 2 days about the same issue...
Butt Dyno is offline
Closed Thread
Stock struts, Top hats, KYB AGX struts,& springs smokeone954 Suspension/Brakes/Handling 47 04-11-2010 04:57 PM
NorCal : KYB AGX Struts & STi springs Lboogie Suspension/Brakes/Handling 13 10-17-2008 12:45 PM
socal: KYB AGX w/ Tanabe GF210 springs Subi114 Private 'For Sale' Classifieds 14 08-28-2005 08:30 PM
CA: 02-03 Impreza KYB AGX Struts & STI "Pink" Springs sbrcr267 Private 'For Sale' Classifieds 24 03-30-2004 07:43 PM
What does it take to install KYB/AGX Struts & Eibach Springs jhoffmann Technical Forum Archive 6 08-19-2000 12:45 AM
